Round Wood Inlay
« back to Joinery forum
Forum topic by docspencer posted 08-09-2016 03:15 PM 660 views 0 times favorited 7 replies Add to Favorites Watch
View docspencer's profile
docspencer
374 posts in 2145 days
08-09-2016 03:15 PM
This may not be the right forum. If its not, please let me know.
Here goes: My wife wants a circular inlay in a bench I’m building. I plan to use a forstner bit to cut the round hole and a hole saw to cut the round piece of wood to fit snugly in that hole. Do any of you know what sizes of each cutter I need to pull this off. I’ve tried to look up the inside dimensions of hole saws but to no avail. Help!
7 replies so far
View MadMark's profile
MadMark
979 posts in 1652 days
#1 posted 08-09-2016 03:25 PM
Your inlay will have a hole in the center if you user a piloted hole saw. The wall thickness is typically 1/16”+- so 1/8” smaller dia should work. However your edges may be very rough.
M
View HerbC's profile
HerbC
1790 posts in 3059 days
#2 posted 08-09-2016 03:55 PM
I agree with Mark that the hole saw will leave a very rough edge on the inlay piece, even more likely to be problematic if you remove the pilot bit.
Maybe Paul (LumberJock Shipwright) can provide a better method since he is a true expert in veneering and inlay…
Good Luck and
Be Careful!
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
Gerald Thompson
1118 posts in 2434 days
#3 posted 08-09-2016 10:09 PM
I do not know how thick the inlay is but I have used Whiteside’s router inlay kit to inlay bow ties and other inlays that were as thin as 1/16’’.
http://www.woodcraft.com/Product/09I16/Whiteside-9500-Solid-Brass-Router-Inlay-Router-Bit-Set.aspx
-- Jerry
View MrUnix's profile
MrUnix
7042 posts in 2398 days
#4 posted 08-09-2016 10:14 PM
I’m with Gerald – use a router with templates/bushings to get a virtually perfect fit.
View shipwright's profile
shipwright
8165 posts in 2997 days
#5 posted 08-10-2016 04:10 AM
+1 on the inlay bushing set. Doesn’t have to be an expensive one. It will give you a perfect fit.
All the inlays in these projects were done with that kind of set. I think mine cost about $15.
http://lumberjocks.com/projects/38909
http://lumberjocks.com/projects/37787
View pintodeluxe's profile
pintodeluxe
5798 posts in 3013 days
#6 posted 08-10-2016 05:07 PM
1+ inlay bushing set for the router. Use a large forstner bit to make a pattern of the hole you want to use (or buy a plexiglass template). The inlay kit accounts for the bit diameter by using a removable bushing. As long as you center your router baseplate first, you will have a perfect fit. It is one of a select few woodworking techniques that feels like magic.
I use the Whiteside inlay bushing kit.
View TMGStudioFurniture's profile
TMGStudioFurniture
55 posts in 1018 days
#7 posted 08-10-2016 05:47 PM
You can also get a router inlay kit at Harbor Freight.
You can make your own template from a piece of MDF.
-- https://www.etsy.com/shop/TMGStudioFurniture
