Tips on plunge router cutting on 3\16" masonite hardboard
Forum topic by eegor posted 05-27-2010 01:04 AM 5729 views 0 times favorited 12 replies Add to Favorites Watch
View eegor's profile
eegor
8 posts in 2888 days
05-27-2010 01:04 AM
Topic tags/keywords: router
Hi, I’m really a noob when it comes to knowing all there is to about routing. I just know how to do my specific task but don’t know why I started getting this particular problem. I frequently cut out shapes on 3/16” masonite board (squares, circles, hearts) I’ve only been doing it for a couple months and I use a makita 3612 plunge router with a Freud1/4-Inch Diameter 2-Flute Down Spiral bit.
Now I ussually route over a spoil board and clamp the masonite down. I ussually will cut out everything in one pass. Lately I’ve been noticing that the cuts aren’t coming out as clean in the sense there is this papery residue left around the edges which I have to scrub off with a towel. (I can’t sand it because I need the surface of the masonite to stay smooth)
My question is, is it time to replace my bit already? I’ve only had it for 2 and half months and I paid 20 bucks for that thing. Or maybe its the masonite I’m buying, or is it just my technique of cutting? Any pointers? I just noticed it happening recently.
12 replies so far
117063 posts in 3543 days
#1 posted 05-27-2010 01:21 AM
Hi eegor Welcome to ljs
I think the problem your having is because you router bit is starting to dull because Masonite tends to dull blades fairly quick. I would suggest you get a diamond hone and when you start see the paper tear out hit the router bit with the hone.
View CyBorge's profile
CyBorge
79 posts in 3141 days
#2 posted 05-27-2010 01:51 AM
Is there any chance the bit is simply dirty? There was a similar thread about table saw blades just the other day.
-- "How can I be lost if I've got nowhere to go?"
eegor
#3 posted 05-27-2010 02:30 AM
Thanks for the tip guys. I would have never guessed it. I will try these first before going out and spending another 20 bucks.
eegor
#4 posted 05-27-2010 02:45 AM
Just wanted to let you guys know what I did. I tried cleaning the bit with some WD40 and no luck. I then decided to try cutting higher up on the bit by plunging down a lot further than where I would normally go and sure enough like a hot knife through butter. So it was a dull bit. I can’t believe it got dull that quick. I’ll probably buy a new one and get a diamond hone at the same time so I can try my luck at sharpening my own bits. Thanks again.
#5 posted 05-27-2010 02:51 AM
Your may not need a new bit if you use the hone, A better cleaner for router bits is goof off and a tooth brush.
eegor
#6 posted 05-27-2010 04:59 AM
a1Jim, the bit i have is a 1/4” spiral bit. Will I be able to hone that?
#7 posted 05-27-2010 05:03 AM
you could try it’s all carbide
View PurpLev's profile
PurpLev
8534 posts in 3614 days
#8 posted 05-27-2010 05:19 AM
+1 for honing. you may also want to use a brush, or scraper to scrape he gunk off the carbide tip as WD40 won’t really do much on it’s own.
#9 posted 05-27-2010 05:23 AM
Like I said Goof off and a tooth brush works great
View Ger21's profile
Ger21
1074 posts in 3097 days
#10 posted 05-27-2010 06:02 PM
There are places that will sharpen spiral bits, but they can cost $15 to get sharpened. With 1/4” bit’s it usually a better idea to just replace them.
And 2-1/2 months isn’t bad. On our CNC at work, we can go through them in a few hours. :-)
-- Gerry, http://www.thecncwoodworker.com/index.html http://www.jointcam.com
eegor
#11 posted 05-28-2010 04:07 AM
@Ger21, Wow every few hours! I guess I shouldn’t complain then lol. That’s good to know since I’ve been planning to do a DIY CNC router hopefully by the end of the year.
Ger21
#12 posted 05-29-2010 04:45 AM
We route a lot of laminates and melamine, which is very abrasive. We also route at very high speeds. I can route about 60-80 4×8 sheets of parts a day. We change the bit every day, and they’re $80-$100 each. If we’re cutting laminated sheets, the bit will have a deep groove worn into the carbide after 3 or 4 hours.
Keep in mind, though, that in one day we route more than my homebuilt router will do in 6 months.
