Transpower 6" Jointer question...
Forum topic by Jim Dawson posted 08-09-2016 02:03 AM 1054 views 0 times favorited 21 replies Add to Favorites Watch
View Jim Dawson's profile
Jim Dawson
108 posts in 831 days
08-09-2016 02:03 AM
I ran across a Transpower 6” Jointer on Craig’s list for a reasonable price It seems like a decent jointer except it has no provision for connecting a dust collector. Does anyone know anything about the jointer and if there is a way to do it?
Thanks,
Jim
21 replies so far
View bigblockyeti's profile
bigblockyeti
5120 posts in 1720 days
#1 posted 08-15-2016 10:28 PM
Do you have a link or picture or model?
Jim Dawson
#2 posted 08-15-2016 11:29 PM
- bigblockyeti
No, but it’s too late, I missed it.
But thanks.
Jim Dawson
#3 posted 08-16-2016 12:48 AM
I was wrong, it’s still available.
- bigblockyeti
bigblockyeti
#4 posted 08-16-2016 01:10 AM
Jim, got your PM. Unfortunately I don’t know anything about that jointer specifically. What I can tell in the pictures is that it seems fairly robust and it’s been kept clean & free of rust so you should be able to hit the ground running without having to do any rehab work before hand. I have heard of Transpower machines before and while I don’t think they ever gained much of a market share, it is good to see that it’s made in Taiwan vs. China. It’s likely very similar to others from different manufacturers coming from the same factory which should make wear items like bearings and belts available instead of something proprietary and impossible to source. As for the dust collection, it’s likely something could be fabbed up to fit over or into where it dumps the chips and really wouldn’t have to be very complicate as you’e already got gravity working with you. If you do move on it, post pictures and let us know how it works out for you.
Jim Dawson
#5 posted 08-16-2016 01:58 AM
I’m going to go look at it later this week and will keep you posted.
Thanks,
Jim
View AlaskaGuy's profile
AlaskaGuy
4136 posts in 2308 days
#6 posted 08-16-2016 02:06 AM
There should be plenty of used 6’’ around. Why not wait for a more well know brand brand with a track record.
View nightguy's profile
nightguy
213 posts in 661 days
#7 posted 08-16-2016 03:25 AM
$150 max a China/Taiwanese clone, close up the ends and bottom, with 1/4, plywood and put a 4” dust,chip collector on the back side been there, done it.
Jim Dawson
#8 posted 08-16-2016 11:28 AM
The only other $150 6” jointers I’ve found are either junk or bench top ones.
There should be plenty of used 6 around. Why not wait for a more well know brand brand with a track record.
- AlaskaGuy
View dhazelton's profile
dhazelton
2767 posts in 2296 days
#9 posted 08-16-2016 11:49 AM
Gotta be a Delta clone. If it’s cheap go for it. But I would NOT enclose the base – the vents are there to keep the motor cool.
18180 posts in 1856 days
#10 posted 08-16-2016 12:29 PM
Where do the chips go? Most have a little ramp where the chips drop down and fall out the side. You can get a plastic fitting to screw over that opening and attach dust collection.
View Stewbot's profile
Stewbot
199 posts in 1083 days
#11 posted 08-16-2016 04:25 PM
my 6” jointer is a Transpower, but with a cantilever style fence (would rather have the center mount like the one pictured). The left hand side of mine has a ramp that funnels the chips but is otherwise open.
I got mine for a pretty reasonable price and it has worked out well for me. It’s not the smoothest sounding machine but the tables are flat and with a little shimming and tweaking it does what I need it to.
I think I read a while back that the company was located in southern CA and is no longer in existence.
-- Hoopty scoop?
Jim Dawson
#12 posted 08-16-2016 06:46 PM
That’s encouraging. I’m going to look at it this afternoon and hopefully bring it home.
I got mine for a pretty reasonable price and it has worked out well for me. It s not the smoothest sounding machine but the tables are flat and with a little shimming and tweaking it does what I need it to.
- Stewbot
Jim Dawson
#13 posted 08-17-2016 04:28 AM
Well, I went to look at the jointer and it looks nearly new. I brought it home for $100. One knife has a small nick in it so l guess I’ll search for a set of knives next. I even got a manual with it. The manual only says 6” knives but no other dimensions so I guess I’ll have to pull one out to measure it.
I’m happy!
bigblockyeti
#14 posted 08-17-2016 11:08 AM
That seems like a pretty good deal for a c note. Most knives of that width are usually between 1” & 1 1/4” wide and 1/8” thick, hopefully yours is the same to make sourcing additional knives easy. Keep us updated as to how it performs and if you’re able to rig up the chip chute to a dust collector.
#15 posted 08-17-2016 11:35 AM
Nice job Jim. That will probably serve you well. Get your new knives and install them. Then take the old ones to get sharpened. Then you’ll always have a sharp set on hand. They’re probably 6 1/8” long. Pictures or it didn’t happen.
