Lock Rabbert for Cabinet Carcass
« back to Joinery forum
Forum topic by Spitfire1 posted 08-08-2016 03:43 AM 651 views 0 times favorited 3 replies Add to Favorites Watch
View Spitfire1's profile
Spitfire1
57 posts in 792 days
08-08-2016 03:43 AM
Topic tags/keywords: joint question lock rabbet upper cabinets
I am wondering if anyone has used lock rabbets to hold together the cabinet carcass. I am building some upper cabinets to hang in my garage. This is my first real attempt at cabinets. The plans I have simply calls for pocket screws but I’ve seen in one of my woodworking books using lock rabbets. Since these are garage cabinets I thought I might give them a try but I am curious if anybody else has any experience using this joint for anything other than drawers and what are some considerations?
3 replies so far
View nightguy's profile
nightguy
213 posts in 716 days
#1 posted 08-08-2016 04:14 AM
I have used them for drawers and love them, cant go wrong with pocket screws either. I use shop projects to experiment with, be it joinery or dies and stains, finishes. So go for it, live and learn, for use in a real project if it works in the shop cabinets, it will work in a commission project, if not you learned what not to do.
View rwe2156's profile
rwe2156
3002 posts in 1534 days
#2 posted 08-08-2016 12:13 PM
Not worth the time & effort IMO.
I’m not a pocket screw guy, so if you think they work, use them.
For shop cabs (really all my cabs), I use butt joints and screws. All you’re doing is screwing boxes together.
On end cabs or where screws will show, plug holes..
View JBrow's profile
JBrow
1365 posts in 974 days
#3 posted 08-08-2016 03:33 PM
Spitfire1,
I like to use the locking rabbet joint on cabinet carcases, especially at the back. I like to mechanically join the back to the sides, since the cabinet back is used to hold the cabinet to the wall.
The only issue I have found is that it takes more time to spread the glue on the two mating pieces and the glue can begin to skim over. When I suspect this will be a problem, I will, for example, only glue the back to the sides and dry assemble the rest of carcase and then ensure the assembly is square. Once the glue has cured, I finish gluing the carcase together. Glue with a longer open time than typical PVA glue could allow the entire carcase to be glued together at one time.
