Can a blade be the cause of out of square?
Forum topic by skatefriday posted 08-07-2016 06:41 PM 1268 views 0 times favorited 9 replies Add to Favorites Watch
View skatefriday's profile
skatefriday
424 posts in 1654 days
08-07-2016 06:41 PM
I spent a good portion of yesterday trying to figure out why my
table saw decided to stop cutting square. Checked miter slot to blade
and it’s about .004” out with a dial gauge. Couldn’t get it any closer,
checked the incra miter to it’s slot still got cuts that were not square.
Today I swapped out the blade and I got a square cut. Both blades
are quality, but the first was sharpened recently by a local sharpening shop.
9 replies so far
View waho6o9's profile
waho6o9
8477 posts in 2748 days
#1 posted 08-07-2016 07:12 PM
I had a similar problem and put the blade in question on a marble slab and used
feeler gauges to find out I bent the blade. Oops
skatefriday
#2 posted 08-07-2016 07:19 PM
Interesting.
I wonder if the sharpening shop could have knocked it out of square? It’s a Freud Industrial 80 tooth. The other blade (that’s cutting square) is a CMT 80 tooth that’s never seen a sharpening shop.
View MrRon's profile
MrRon
5130 posts in 3415 days
#3 posted 08-07-2016 07:49 PM
What do you mean by “square”? blade 90° to the miter gauge or 90° to the table top?
skatefriday
#4 posted 08-07-2016 07:50 PM
Professional. I saw his shop.
View pete724's profile
pete724
68 posts in 980 days
#5 posted 08-10-2016 08:54 AM
- MrRon
Explain!
Rip cut not straight?
crosscut not 90 degree to edge?
Saw marks on the cut edge?
MrRon
#6 posted 08-10-2016 07:52 PM
If switching blades fixes the problem, then the blade is obviously the problem.
View jbay's profile
jbay
2735 posts in 1070 days
#7 posted 08-10-2016 09:05 PM
A bent blade is only going to cut a wider kerf. It may try to push the board aside but I don’t think so, could depend on how bent the blade is. (Think wobble dado blade)
If your using a miter gauge then I would attribute it more to your not holding the wood tight against the miter gauge and it’s moving as your making the cut.
Possible that the new blade is cutting cleaner so it’s easier to hold true?
Hard to say without being there and seeing what you are doing.
-- “Hanging onto resentment, is letting someone you despise live rent-free in your head.” (Ann Landers)......
skatefriday
#8 posted 08-11-2016 12:24 AM
Crosscut not 90 degree using an incra miter gauge. The bad blade should be sharper than the CMT that’s cutting straight. Yeah, I can’t really explain it either.
pete724
#9 posted 08-12-2016 09:04 AM
Crosscut not 90 degree using an incra miter gauge. The bad blade should be sharper than the CMT that s cutting straight. Yeah, I can t really explain it either.
- skatefriday
That helps actually.
Blade is either bent OR
not fitting on the arbor properly.
As Jbay said;
It SHOULD just make a wider kerf BUT the wobble will push the workpiece “sliding along the miter fence” then spring back.
Under those conditions (wobbling) it would be near impossible to hold the workpiece fixed to the fence with just your hands. Especially so if the blade is thin and raised higher than it needs to be. (flexing blade combined with wobble).
