Repairing hole drilled through face
Forum topic by DBordello posted 08-06-2016 11:41 PM 820 views 0 times favorited 24 replies Add to Favorites Watch
View DBordello's profile
DBordello
132 posts in 1278 days
08-06-2016 11:41 PM
Although I was aware (and dreading) of the possibility, while drilling through the edge of a board, I punched out the edge.
What are my repair options? I am planning on finishing it with BLO & Arm-R-Seal. Unfortunately, this is for a crib, and I am under a bit of a time crunch.
Ideas?
24 replies so far
DBordello
#1 posted 08-06-2016 11:49 PM
To respond to my post, I have two issues:
1) The burn marks
2) The opening.
Upon further inspection, the hole was too deep anyways (doh!). Therefore, if I can seal the opening, it is okay if I block the opening there.
View ChuckV's profile
ChuckV
3131 posts in 3579 days
#2 posted 08-06-2016 11:55 PM
Not to make light of your problem, but I was greatly relieved to find that you were not seeking medical advice on a woodworking web site. I was prepared to write, “Get to the ER!”.
-- “Big man, pig man, ha ha, charade you are.” ― R. Waters
DBordello
#3 posted 08-07-2016 12:07 AM
Fair point :)
DBordello
#4 posted 08-07-2016 12:32 AM
The best idea I have so far, is to cut out the damaged material, and (attempt) glue in a replacement block?
Thoughts?
View MadMark's profile
MadMark
979 posts in 1505 days
#5 posted 08-07-2016 12:55 AM
Cut 2” off the end …
M
View JBrow's profile
JBrow
1365 posts in 972 days
#6 posted 08-07-2016 01:13 AM
DBordello,
There are probably several repair options, though I am not sure any option will completely erase the record of the mistake from the work piece. But my first thought is to find a dowel ideally of the same material as the work piece. If necessary, sweeten the hole so that the dowel will be a nice fit and glue in place. Chisel, plane, scrape, and/or sand the protruding ends of the dowel flush. After the repair, re-drill the hole. While the repair may blend well with the surrounding wood, unfortunately it will probably remain visible, but hopefully only to you.
DBordello
#7 posted 08-07-2016 01:18 AM
JBrow,
Not a bad idea. I happened to have a 3/8” plug cutter chucked in the drill press. However, the hole is 13/32”. That being said, a good idea, and not a bad result:
I am going to guess a 13/32” walnut dowel doesn’t exist (or plug cutter). Excellent idea, I think I am going to glue this in place and try sanding it down.
MadMark
#8 posted 08-07-2016 01:27 AM
Kreg plug?
M
DBordello
#9 posted 08-07-2016 01:29 AM
Kreg plug?
M
- MadMark
What diameter are those?
I am currently scouring the internet for a 13/32” plug cutter. OR, wondering if I should enlarge it to 7/16”, since those are more common.
JBrow
#10 posted 08-07-2016 01:48 AM
DBordello,
The hole looks fairly long and I suspect that after the repair the hole will be re-drilled in the same place. If that is the case, I would think better results would be achieved by purchasing a ½” walnut dowel. A ½” drill bit should follow the existing hole fairly well, so after the defective hole is re-drilled at ½”, the ½” dowel could be glued in place. Doing the repair in this manner would make re-drilling the new hole a little easier and there would be full support around the new properly drilled hole for whatever will go into that hole. I suggest ½” dowel since a 7/16” walnut could be hard to find, but these folks may carry 7/16” walnut dowels.
http://woodproducts.caldowel.com/Dowel-Rods.aspx
My concern with a plug cutter is that the repair would only be at the surface, since the plug will be of limited length. But if you only need a surface repair and the required hole can be drilled in another location, the plug probably would be fine.
DBordello
#11 posted 08-07-2016 01:50 AM
DBordello,
- JBrow
Thanks for the suggestion. It appears I drilled the hole longer than it needed to be. Therefore, if I can repair the breached area with a plug, redrilling will not be necessary.
At this point, I am thinking about ordering a 13/32” plug cutter.
View jbay's profile
jbay
2421 posts in 951 days
#12 posted 08-07-2016 01:54 AM
Maybe a design change. Cut off 2” off each end and add an end piece.
DBordello
#13 posted 08-07-2016 02:28 AM
I kind of like this…
View Kirk650's profile
Kirk650
525 posts in 800 days
#14 posted 08-07-2016 03:02 AM
I’d use my inlay gear to make a patch.
View GR8HUNTER's profile
GR8HUNTER
4096 posts in 764 days
#15 posted 08-07-2016 03:19 AM
- jbay
DITTO
