Dust Extraction Jig For Lathe
Forum topic by Grumpy posted 08-06-2016 06:20 AM 720 views 0 times favorited 7 replies Add to Favorites Watch
24045 posts in 3907 days
08-06-2016 06:20 AM
Topic tags/keywords: lathe jig dust extraction unit
I just bought a 2hp dust extraction unit after the old one carked it.
I now have almost twice the suction power 700cfm to 1200cfm.
Time to deal with dust at the wood lathe.
After several hours thinking how best to do it I came up with something that suits the job.
Like many of us I tend to hold onto bits of stuff for a rainy day (some of it’s been there 30 years or more just waiting for a chance to bounce into action).
I had an umbrella arm that fixed on to a wall that came in very handy and a heavy duty corner bracket.
I ground & drilled the corner bracket to fit the end of the lathe so I could remove the tail stock if needed.
The Umbrella Unit was handy because it had two arms, one above the other which allowed for a slider to go between and hold the Vacuum unit.
The end product seems like it will do the trick (yet to be tested). Can’t see why it won’t work.
It can be adjusted up, down, left, right, in & out.
Thanks for looking.
7 replies so far
View Mark Wilson's profile
Mark Wilson
2172 posts in 1119 days
#1 posted 08-06-2016 10:48 AM
You’re too clever by half, Tony.
-- Mark
View rwe2156's profile
rwe2156
3003 posts in 1537 days
#2 posted 08-06-2016 10:58 AM
I’ll stick with a broom…...
View ralbuck's profile
ralbuck
4720 posts in 2323 days
#3 posted 08-06-2016 04:46 PM
I think I may have to try something like that, THANKS for the idea on how.
I do not do a lot of lathe work, but it is always messy.
-- Wood rescue is good for the environment and me! just rjR
#4 posted 08-07-2016 04:04 AM
Thanks for the comments Jocks.
It’s more for catching the fine dust before it gets into the lungs than the mess on the floor.
View lew's profile
lew
12154 posts in 3812 days
#5 posted 08-07-2016 02:00 PM
Cool! I like the re-purposed umbrella arm!
View doubleDD's profile
doubleDD
7498 posts in 2099 days
#6 posted 08-07-2016 05:26 PM
Clever way to help keep the shop cleaner. I made a set up similar to yours for the lathe. Like you said, the dust is the worst part.
#7 posted 08-07-2016 09:33 PM
Right on Dave. Will be much better than a mask on a hot day
