Gluing parts together after finishing?
Forum topic by Duckarrowtypes posted 05-24-2010 02:29 PM 2374 views 0 times favorited 7 replies Add to Favorites Watch
View Duckarrowtypes's profile
Duckarrowtypes
68 posts in 3813 days
05-24-2010 02:29 PM
I have parts that overlap and require finishing separately. Is it acceptable (and as strong) to glue them together after finishing or would I get the strongest result by gluing before finishing? I’m planning to use titebond III.
7 replies so far
View Cozmo35's profile
Cozmo35
2200 posts in 2944 days
#1 posted 05-24-2010 02:41 PM
If you only put finish on the parts that will be exposed, you should be alright. The the finish will ge into the pores of the wood an limit the strenght of it’s bond.
-- If you don't work, you don't eat!.....Garland, TX
View Sawkerf's profile
Sawkerf
1730 posts in 2977 days
#2 posted 05-24-2010 03:09 PM
Mask your glue surfaces before you finish, and wipe off any squeeze out when you glue up. You should be fine.
116912 posts in 3486 days
#3 posted 05-24-2010 04:58 PM
I second the masking aproach
Duckarrowtypes
#4 posted 05-25-2010 03:24 AM
Thanks for the tips! I think I’ve figured out a way to assemble prior to finishing now. Phew!
View 8iowa's profile
8iowa
1569 posts in 3670 days
#5 posted 05-25-2010 03:31 AM
I often use Elmer’s white glue for repairs on finished furniture. It cures completely clear.
View Dark_Lightning's profile
Dark_Lightning
3074 posts in 3017 days
#6 posted 05-25-2010 03:47 AM
Finishing first is an acceptable technique (often better), as long as you don’t cover up the wood that needs bonding. It can save you some serious inside corner sanding.
-- Random Orbital Nailer
View thatwoodworkingguy's profile
thatwoodworkingguy
375 posts in 2838 days
#7 posted 05-25-2010 03:52 AM
Like Jim said. Mask off the areas you plan to glue.
-- thatwoodworkingguy.com ~Eagle America~ ~Woodcraft~
