dovetails in 1/2 in plywood
Forum topic by jtlighting posted 05-24-2010 01:11 AM 4096 views 0 times favorited 18 replies Add to Favorites Watch
View jtlighting's profile
jtlighting
27 posts in 3166 days
05-24-2010 01:11 AM
well im in the process of making a dresser for my son (who by the way is a human wrecking ball) its made out of 3/4 plywood but heres my question i was thinking of making the drawers out of 1/2 in plywood but i dont know what type of joinery to use i was thinking dovetails that i could cut on my bandsaw to make them a little wider apart but i really dont have a clue i want something that he wont be able to pull apart or break easily any suggestions would be great thanks
-- TO CUT IS TO CREATE.....
18 replies so far
117416 posts in 3812 days
#1 posted 05-24-2010 01:17 AM
How about 1/4” plate welded together LOL I think the dovetail idea is good . If your really consered go with 3/4 sides and 1/2” bottom and if it’s all ply you can glue the bottom in.
View acrollet's profile
acrollet
9 posts in 3253 days
#2 posted 05-24-2010 02:50 AM
I just made drawers for a changing table from 1/2” plywood, and they worked great – used a jig. Here are a couple pics:
Dovetails, 1/2
Closeup of Dovetails
jtlighting
#3 posted 05-24-2010 03:32 AM
thanks sfor the jig tip but im not that good with a router yet and i thought i could use my bandsaw instead seems easier to me what do you think
View thatwoodworkingguy's profile
thatwoodworkingguy
375 posts in 3165 days
#4 posted 05-24-2010 03:35 AM
If he pulls those apart ill personaly build you a new dresser and changing table
-- thatwoodworkingguy.com ~Eagle America~ ~Woodcraft~
thatwoodworkingguy
#5 posted 05-24-2010 03:36 AM
Arent they backwards? dont the pins usualy go on the drawer face so that you can pull it apart? Just my observation i could be wrong.
thatwoodworkingguy
#6 posted 05-24-2010 03:37 AM
NVM i was looking at the photo wrong. ignore me
View ,'s profile
2387 posts in 3782 days
#7 posted 05-24-2010 04:02 AM
We dovetail almost all of our drawers for our kitchens with 1/2” baltic. I think a 1/2” russian or baltic would do well. We also use solid maple dovetail and if I were doing this for myself I would certainly go with a solid maple wood because I just think it looks much better. Although the baltic dovetail still looks nice and is very strong in my opinion.
jtlighting
#8 posted 05-24-2010 04:47 AM
ok just to reiterate (not being a jerk) its for my son whose 13 yrs old and doesnt care about taking care of stuff if i could make it out of steel i would i dont care for looks or anything of that sort i just want a joint that will be strong enough to handle “the human wrecking ball” i mean i could literatelly contract this kid out for demo work just by letting him play on the jobsite lol…...how bout box joints how does that work with plywood is it strong
acrollet
#9 posted 05-24-2010 05:46 AM
Dovetails are about as strong as it gets for a box, you could use 5/8” or even 3/4” plywood for extra strength. You should be able to cut the dovetails with your bandsaw, along with a coping saw and a chisel…
View Eagle1's profile
Eagle1
2066 posts in 3299 days
#10 posted 05-24-2010 01:52 PM
If you think that he really tear up the drawers that are dovetailed. I would make a small triangle block for each inside corner. Just cut them put some clue on them slide them up and down to creat a suction on them and let them dry. I really dont think he would break them apart.
-- Tim, Missouri ....Inside every older person is a younger person wondering what the heck happened
View FirehouseWoodworking's profile
725 posts in 3508 days
#11 posted 05-24-2010 04:34 PM
I’ve never had any problem with dovetailing 1/2” plywood for drawers. All the kitchen cabinets I ever built had dovetailed drawers. I guaranteed my work and have never had a callback. If you’re overly concerned, you could drive a couple small pins through the pins at each corner from opposing sides, but I think that might be overkill.
-- Dave; Lansing, Kansas
View Dan Lyke's profile
Dan Lyke
1520 posts in 4360 days
#12 posted 05-24-2010 06:57 PM
What do you guys do about tear-out with cutting the dovetails in plywood? I tried dovetails in ApplePly with a router on a Leigh Super jig, and even with the sides taped and all sorts of blocks to help stop splintering I eventually broke down and did my joints another way (Domino).
But I like dovetails more…
jtlighting
#13 posted 05-25-2010 05:16 AM
thats what im worried about tear out and splintering thats y i think cutting them on a bandsaw would help with this so ill give it a shot and post the pics when the project is done
#14 posted 05-25-2010 05:51 AM
Make sure you keep the bit clean and sharp. I used a carbide, 1/2” shank, bearing bit. Remember to never get any of the cleaner on the bearing! Don’t let gum and pitch build up on the carbide edge.
If there is any splintering, putty works fine on plywood to fill it as well as any “oops” on the dovetails. Use putty that matches the plywood.
View cbMerlin's profile
cbMerlin
100 posts in 3655 days
#15 posted 05-25-2010 02:41 PM
Huh, never tried doing dovetails in plywood….......always thought it would be really hard on the bits? Never done dovetails on anything but a jig so I may not know what I’m talking about but it sure seems like it would be easier/quicker than a band saw? I’ve got some vacation time coming up, I see some experimentation in my future!!!!
-- Sawdust looks better in the garage than cars, explain that to your wife!
