Incra Ibox jig
Forum topic by loiblb posted 08-04-2016 11:06 PM 813 views 0 times favorited 16 replies Add to Favorites Watch
View loiblb's profile
loiblb
143 posts in 1107 days
08-04-2016 11:06 PM
Anyone have any time using one of these. Are they easy to set up?
Thanks
16 replies so far
View KelleyCrafts's profile (online now)
KelleyCrafts
2937 posts in 790 days
#1 posted 08-04-2016 11:12 PM
Yes they are easy if you use it all the time. Forgetting just how to set it up is the problem. I’ve used mine for literally thousands of cuts. I made an out feed table with large pull out drawers with box joints and then 62 little boxes within that are all box jointed. It was a lot of work.
Do I think it’s worth it over building your own?? Yes and no. If you plan to use box joints in several sizes then yes, if not, then no.
I have moved more to hand joinery now days so I don’t really use mine anymore.
-- Dave - http://kelleycrafts.com/ - pen blanks - knife scales - turning tools
View Woodchuck2010's profile
Woodchuck2010
707 posts in 909 days
#2 posted 08-05-2016 12:45 AM
I don’t really use mine. If you’re interested, I’ll sell it to you.
-- Chuck, Michigan,
View Gene Howe's profile
Gene Howe
10598 posts in 3479 days
#3 posted 08-05-2016 12:53 AM
As the guy above said, they are easy to use but remembering how to set it up is another thing. Mine came with a video that I use each time.
View ScottM's profile
ScottM
658 posts in 2198 days
#4 posted 08-05-2016 05:01 PM
- Gene Howe
Same here…. Works well but don’t use it that much to remember how!
View CharleyL's profile
CharleyL
222 posts in 3415 days
#5 posted 08-05-2016 09:13 PM
I use mine frequently, like every month or so. If you do this a few times and set it up for different box joint sizes, it becomes second nature. About 8 minutes is about all it takes me now to change sizes and be ready to cut. If cutting the same size joint, maybe with a different thickness of wood, but with the same blade, it takes much less than that. I rarely do dovetails any more, unless the appearance of them is important, and I have a Leigh D4R. Box joints are just so much easier to do with the I-Box jig and they are as strong or stronger than the dovetails.
Charley
View AandCstyle's profile
AandCstyle
3093 posts in 2308 days
#6 posted 08-05-2016 09:48 PM
I have one and had a terrible time getting it set up for 1/4” so have never even tried a different size. I am probably a slow learner because I watched the video, called customer support and still don’t understand. :/
-- Art
KelleyCrafts
#7 posted 08-05-2016 09:52 PM
All 62 of my little boxes are 1/8” so it’s definitely possible. I didn’t say it was fun though.
View TheFridge's profile
TheFridge
9694 posts in 1537 days
#8 posted 08-05-2016 09:54 PM
If making box joints of lengths 6” or shorter, William Ng’s jig works great. He’s on YouTube.
Woodchuck2010
#9 posted 08-05-2016 11:39 PM
I have one and had a terrible time getting it set up for 1/4” so have never even tried a different size. I am probably a slow learner because I watched the video, called customer support and still don t understand. :/
- AandCstyle
It’s too fussy and confusing. I did a couple of tests with it and didn’t care much for all the adjustments. It’s supposed to be easier, but I don’t think so.
-- Chuck, Michigan,
View Kelly's profile
Kelly
2044 posts in 2995 days
#10 posted 08-06-2016 12:14 AM
Another positive vote for the jig.
I find the thing to be far superior to most home made units. It does what it says it’ll do and it isn’t difficult to set up, if you use it regularly. Otherwise, a quick refresher gets you going again.
View SenecaWoodArt's profile
SenecaWoodArt
435 posts in 1670 days
#11 posted 08-06-2016 04:18 AM
I have never had a complaint with Incra products and I own several. The IBOX is an outstanding jig in my opinion. I don’t use it a lot, but when I do it’s far superior to anything else I have tried. Money well spent in my opinion.
-- Bob
View playingwithmywood's profile
playingwithmywood
422 posts in 1648 days
#12 posted 08-06-2016 04:24 AM
I have the IBox and like it but it does have some limitations on material thickness while I have never used this type of system it seems like it is a better option maybe https://woodgears.ca/box_joint/jig.html
loiblb
#13 posted 08-07-2016 07:59 PM
I just got my Incra I Box
Two things
Why does both spacers move as I turn the silver wheel holding the red wheel so it does not?
My cuts are too loose but board fits the spacers tight.
Why is the silver wheel magnetic?
Thanks
View RandyinFlorida's profile
RandyinFlorida
256 posts in 2119 days
#14 posted 08-08-2016 11:49 AM
own it, love it.
-- Randy in Crestview Florida, Wood Rocks!
View rwe2156's profile
rwe2156
2997 posts in 1532 days
#15 posted 08-08-2016 11:52 AM
Its like a lot of tools if you don’t use them much theres a learning curve each time you pull it out.
I don’t use mine very much so I keep the manual very handy!!
