Fixing a bad polyurethane job
Forum topic by Gwell posted 08-04-2016 09:19 PM 777 views 0 times favorited 3 replies Add to Favorites Watch
View Gwell's profile
Gwell
2 posts in 716 days
08-04-2016 09:19 PM
I built a mini arcade with my son and painted it black. I applied some water based polycrylic on it but didn’t come out too well. There are some uneven spots. As if some spots are smoother than others. I did sand after the first coat. I also used an HVLP gun to get smoother results. But I think I had the pattern set to small. As is I applied too much finish in certain spots. And ideas how to fix?
3 replies so far
View MadMark's profile
MadMark
979 posts in 1508 days
#1 posted 08-04-2016 09:23 PM
Belt sander?
M
Gwell
2 posts in 716 days
#2 posted 08-04-2016 10:33 PM
Are you asking if I used a belt sander? No just by hand. Nothing too aggressive either
View OSU55's profile
OSU55
1737 posts in 2045 days
#3 posted 08-05-2016 01:11 AM
Not to be a smarta**, but #1 practice with the gun and selected finish before using it on a project. Kraft paper, cardboard, thin plywood all work. #2 MW polycrylic is about the softest, most useless wb finish out there – get something decent. To salvage this, add a couple more coats (after practicing) and then see what you got. Don’t remember if you have to sand polycrylic between coats – don’t think so. If you using satin, you might get away with the finish off the gun. If using gloss, it will require finishing the finish.
