Glue
« back to Hand Tools forum
Forum topic by Gerald Thompson posted 08-03-2016 07:49 PM 453 views 0 times favorited 4 replies Add to Favorites Watch
Gerald Thompson
869 posts in 2136 days
08-03-2016 07:49 PM
I was given an old socket chisel about 1.5 in. wide and about 3 in long. The handle came out of it in its entirety.
What glue would be best to use to reattach it? I have hot hide glue and all of the usual suspects of Titebond.
There seems to be some gappossis in the handle tenon which is round. Would it be advisable to use a thin strip of hardwood veneer to snug it up?
-- Jerry
View MrRon's profile
MrRon
4627 posts in 3145 days
#1 posted 08-03-2016 08:01 PM
Normally, I think a socket type chisel doesn’t need glue as it depends on a taper fit; but since the handle is a “loose” fit, I would use an epoxy cement like JB Weld.
View Kazooman's profile
Kazooman
931 posts in 1854 days
#2 posted 08-03-2016 08:04 PM
The handle should be a press fit so it can be changed when desired.
https://www.youtube.com/watch?v=k6_oV072iio
If the handle is too loose to seat properly, you could try gluing some shim material to it and then the press fit. If you have a lathe you could extend the taper just a bit and cut a little off the original tip, effectively creating a slightly larger diameter tapered shank.
View KelleyCrafts's profile
KelleyCrafts
2705 posts in 640 days
#3 posted 08-03-2016 08:20 PM
If it’s too loose I would glue some veneer on and then compression fit the chisel with a coat of hairspray.
Actually I would probably turn a new handle but that’s because I just got a lathe and it’s fun.
-- Dave - http://kelleycrafts.com/ - pen blanks - knife scales - turning tools
Gerald Thompson
#4 posted 08-03-2016 08:38 PM
I don’t have a lathe. I will give the veneer hair spray a shot. I seems to me that the wood has shrunk a great deal.
Thanks.
-- Jerry
