Craftsman 113 table saw with damaged trunnion
Forum topic by one19 posted 08-03-2016 06:38 PM 1550 views 0 times favorited 7 replies Add to Favorites Watch
View one19's profile
one19
65 posts in 1504 days
08-03-2016 06:38 PM
Greetings fellow sawdust makers.
I have a problem that requires your expert input: ​I bought a used U.S. made Emerson/Craftsman 113.299315 (model number added after original post) table saw manufactured in or around 1995 that’s in very good shape except for one issue. The trunnion is jacked up. The gear for the height mechanism is so worn that it may as well be sheared off. It’s frozen stiff and there’s obviously no fixing it.
My question is this: are all trunnions for this style and era of Craftsman contractor saw interchangeable? If so, I’ll look for another used saw that I can part out. Does anyone know of a good source that sells this kind of part?
I realize it’s a tough question and there may only be a few individuals that have this kind of knowledge, but I’m hoping there’s a lumberjock out there who can help. I’ve attached a photo of a saw that looks exactly like mine.
Thanks!
7 replies so far
one19
#1 posted 08-03-2016 07:45 PM
Guess I should be more accurate when I say “trunnion”. It’s the height adjusting gear in the cradle/arbor/trunnion assembly. Hopefully, I’m describing this accurately.
View MrUnix's profile
MrUnix
7050 posts in 2401 days
#2 posted 08-03-2016 07:49 PM
What is the exact model number? With the parts diagram, you can pinpoint what it is you need, and the part number can be cross-referenced to other models which may be suitable. Emerson made quite a few different saws, so just saying it’s a ‘113’ is not very helpful.
one19
#3 posted 08-03-2016 08:13 PM
I’m recalling this off the top of my head but I’m pretty sure it’s 113.299315. Thanks for your help!
View 01ntrain's profile
01ntrain
259 posts in 1272 days
#4 posted 08-03-2016 08:19 PM
Shouldn’t be hard to replace, if it’s needed. eReplacementparts.com would have it in stock, I would think. You can also try EBay, as well.
one19
#5 posted 08-04-2016 02:17 PM
Actually, a quick search at ereplacements.com reveals that the part is obsolete and no longer available. Does anyone have knowledge/experience mixing and matching parts from different models to rebuild a cradle/arbor/trunnion assembly?
Thanks!
View knotscott's profile
knotscott
8149 posts in 3577 days
#6 posted 08-04-2016 04:05 PM
Find an inexpensive donor saw on CL. Most of the similar Emerson made saw parts should work. Take the part you need, sell the other parts to offset your costs.
one19
#7 posted 08-04-2016 04:29 PM
Yep, this is the course I believe I will take. Thanks!
