| Forum topic by Douglas Bordner | posted 2003 days ago | 8283 views | 1 time favorited | 80 replies | ![]() |
2003 days ago |
Topic tags/keywords: humor question wobble dado heads I’ll start. My name is Douglas Bordner, and I’m powerless over the fact that I purchased a Craftsman “Excalibur” wobble dado. I used it to built something that I am rather proud of. As it was something I built long ago with my first contractor’s saw (Yup, a Craftsman with an Aline-a-cut yellow plastic implant ahead of the throat), I can’t remember specifically things being so bad. What is the part of using one of these that is so infamous? Rough cut, splintering, not crisp bottom of the cut? -- "Bordnerizing" perfectly good lumber for over a decade. |
80 replies so far
#1 posted 2003 days ago |
I just lied to myself. I was typing that I’ve never owned one of those sear’s blades. I am a bold face lier. I’ve owned one. Used it on a radial saw. Don’t know where it is and for that I’m glad. I will never do that again. I am cured, I don’t know if there was 12 steps in there but I’ve learned how much I’ve sinned in buying and using. -- I've been blessed with a father who liked to tinker in wood, and a wife who lets me tinker in wood. Southern Delaware karson_morrison@bigfoot.com † |
#2 posted 2003 days ago |
fellow lumberjocks I confess I had one also …but I never turned the machine on! -- Dusty |
#3 posted 2003 days ago |
I contemplated buying one, but embarrassingly enough, couldn’t figure out how it was supposed to work so I didn’t buy it. -- You can discover more about a person in an hour of play than in a year of conversation. (Plato) |
#4 posted 2003 days ago |
I had a wobble blade and the raidial arm saw to go with it, sold the two as a pair. I still have and use the contractors table saw with the yellow implant. I don’t know whether to be embarrassed or insulted. A new saw is on my wish lis however my wife’s wish list is bigger. -- Ron Central, CA |
#5 posted 2003 days ago |
I had one that came with my shopsmith… and desperately needed it for a project (mostly due to time not skill level) unfortunately i misplaced (or never took ownership of) whatever held it in place on the shopsmith’s arbor…. and since it diddn’t fit my tablesaw I ventured out to pick up a good “real” dado set. Liked the look of the ones you could dial in the width, and not fuss with shims… but as only owned (and still do) a cheap portable Delta jobby, I (to add insult to injury) had to by another wobble dado that was specifically for the short arbor on my saw (the ONLY option I could find). The project was all made in PT, and came out quite good (considering the materials). I don’t regret the purchase for time saved. But I won’t put it to anything close to furniture grade. Shop grade stuff… but nothing going above ground. I suppose it’s just as well I didn’t put a $200 dado set on a $70+ saw. -- I am always doing what I cannot do yet, in order to learn how to do it. - Van Gogh -- http://blanchardcreative.etsy.com -- http://snbcreative.wordpress.com/ |
#6 posted 2003 days ago |
Ron, I’m even beginning to suspect that that saw is actually a Jet tool, made for Sears. -- "Bordnerizing" perfectly good lumber for over a decade. |
#7 posted 2003 days ago |
I’ve still got a wobbler, but only because I seldom throw anything out. It has been replaced with a decent stackable set. |
#8 posted 2003 days ago |
woo hoo !!! for the first time ever i can get through a confession and have not sinned !! well unless thinking of it is a sin in which case im quite guilty. |
#9 posted 2003 days ago |
But what about ‘em sucks so badly? -- "Bordnerizing" perfectly good lumber for over a decade. |
#10 posted 2003 days ago |
oh no . are you considering another one ? call farther karson! |
#11 posted 2003 days ago |
Well for me the thing was used on my Craftsman table saw. I can’t bash that saw too badly. After 20+ years it still makes a decent cut as long as I take the time to truly set the fence – but that’s another story. (I’ll take any unisaws that are on the give away list – hint hint) -- CaptnA - "When someone hurts you, write it in the sand so the winds of forgiveness will scatter the memory... " |
#12 posted 2003 days ago |
Sounds like we need a contest to see who can best enshrine their wobble dados in a well deserved display case (plus gives added benefit that nobody ever tries to use them). This has potential to turn into the “wobbly dado” award given to the crappiest things we’ve ever built. -- "The way to make a small fortune in woodworking- start with a large one" |
#13 posted 2003 days ago |
Douglas – the problems with the wobble dado, like CaptnA said, are sloped sides and rough sides and bottom. The blade is held at a slight angle to the arbor, which makes it nearly impossible to acurately measure the distance between the cut and the fence. On the plus side, at any given moment you are only removing 1/8” of material, instead of removing the full width of the dado, so a wobble dado is not so likely to bog down a lower powered saw. -- http://www.peteroxley.com -- http://north40studios.etsy.com -- |
#14 posted 2003 days ago |
Peter, I love your optimism. In my weakness (or stupidity, they look alike sometimes) I bought a wobble dado thinking that one blade was better than stacking 2,3 or 4. However, like you’ve said, the bottom and sides were less than … well less, and it was impossible to tell where the silly thing was actually going to start cutting. And yet, in your generosity you have found a “plus side” to a wobble dado. My hat’s off to you. -- Working at Woodworking http://www.VillageLaneFurniture.com |
#15 posted 2003 days ago |
Plus – the bottom is actually an arc, not a flat cut. Ok for slipping in a 1/4 inch panel, but not ideal for wide dados… you have to either go deeper than you’d like (and add on edge banding to hide it, (and have a less than tight glue surface) or use a chisel or router to square off both sides of the groove. A good idea on paper… but a nightmare to measure accurately. -- I am always doing what I cannot do yet, in order to learn how to do it. - Van Gogh -- http://blanchardcreative.etsy.com -- http://snbcreative.wordpress.com/ |
| Forum | Topics |
Woodworking Skill Share
8844 |
Woodturning
246 |
Woodcarving
32 |
Scrollsawing
68 |
Joinery
96 |
Finishing
1599 |
3593 |
15974 |
Hand Tools
2094 |
Jigs & Fixtures
501 |
Wood & Lumber
2906 |
813 |
Focus on the Workspace
925 |
778 |
Woodworking Trade & Swap
2773 |
LumberJocks.com Site Feedback
1553 |
Coffee Lounge
6131 |
