Table Saw for DIY
Forum topic by axam posted 08-03-2016 05:15 PM 1619 views 0 times favorited 27 replies Add to Favorites Watch
View axam's profile
axam
16 posts in 717 days
08-03-2016 05:15 PM
Topic tags/keywords: question tablesaw
Hi
I have been looking at different table saw’s originally I was going to go for the cheapest bunnings had to offer. which is the ozito at $170 then I thought better upgrade a but to the other ozito $210
https://www.bunnings.com.au/compare?...290286,6290539,
so then I was thinking well what about the Makita at $630 or the Ryobi.
Looking through reviews it seems that the best of the lot is the Bosch GTS 10 J cheapest i can find it is $629 but thats not in WA (where I am at) i found it here for $650 tools )
so I guess I am wondering which Table saw should I go for?
i do not have a big shed. so space is a big factor.
I am also wondering if I should spend $600 odd on a table saw (as this is a lot of money!) or save some buying the cheaper stuff. i am thinking that if I buy cheap it will cost me more with the inevitable improvements that i will need to make.
what do you think?
27 replies so far
View JBrow's profile
JBrow
1365 posts in 975 days
#1 posted 08-03-2016 05:45 PM
axam,
I have no specific recommendation, just some general comments that I hope may be helpful.
I personally believe that an inexpensive tool is inexpensive for several reasons which add up to a tool that will be difficult to use. An inexpensive tool may be difficult to setup and then hold its settings. It is likely to have a small motor that will struggle when making rip cuts in dense woods. A table saw that will hold its setting, with a decent fence that can be and remain set parallel to the blade and one with reasonable power, is required to avoid the aggravation of cuts that are not straight or difficult to complete. I find the sting from writing big checks for tools fades from memory pretty quickly, but a tool that is difficult to use or consistently produces poor results is a lasting aggravation.
On the other hand, if the tool is a one-time use tool, renting or buying cheap could be the way to go. Also bargains can be had if a good used saw can be found.
View MikesProjects's profile
MikesProjects
172 posts in 1957 days
#2 posted 08-03-2016 06:15 PM
I recommend DeWalt table saws above all other portable table saws. If you can get dewalt in your location read on, if not skip to the next paragraph…I have them all & prefer the DeWalt by far. Better fence, better design. Lots of power although the makita table saw is very powerful as well. If you want a good moderately priced saw look up the dewalt 745 or DWE7480 , the difference is the rip capacity. A step up would be Model # DWE7490X. The first one I mention is an excellent DIY table saw, its what I like using on job sites.
I used to use Ryobi table saws 10 years ago, they worked okay, the switches would have to be replaced after a while but they were inexpensive back then. I have a makita that doesnt quit, I purchased it used. If its your first DIY table saw look for something with a decent rip capacity & a good fence, the fence makes the saw, good luck.
-- -Mike, Southern California, YouTube User ( Give & Take )
View mako1's profile
mako1
20 posts in 850 days
#3 posted 08-03-2016 06:41 PM
“I have them all & prefer the DeWalt by far” No kidding.I’d like to see a pic of that.Guess your a real expert?I’ve been doing this daily for 45 years and have yet to own or try “them all” The best tool of any kind is the tool that works best for you and fits your budget.
You can always upgrade when you feel you need to and have the extra cash.
mako1
#4 posted 08-03-2016 07:00 PM
To reiterate on this point so I don’t seem like a complete d#$%. I have been doing custom cabinets and furniture and been in the remodeling business for 45 years.
I own a Powermatic 66 TS that was built in TN in the early 90’s.I also own a Bosch jobsite saw with a gravity stand for jobsite work.Also have a old Craftsman contractor saw from the 80’s.Belt drive with cast iron wings that I took for some money a man owed me. $125.00 I have around $3500 in the Powermatic in the early 90’s and $125 in the old Craftsman .When well tuned and a good blade I can do the same quality of work on either.One is just more enjoyable to use than the other.
View bigJohninvegas's profile
bigJohninvegas
470 posts in 1517 days
#5 posted 08-03-2016 08:00 PM
What sort of projects are you looking to do? And will a small table top saw be ok. I started with the small ryobi saw. Huge mistske for me. Typically, your table saw is the number one tool in the wood shop. My work bench and saw work together to form an outfeed and assembly table. I put a piece of carpet on the saw or bench when sanding, cardboard when doing glue ups or finishing. Totally understand the limited space issue. I spent $600 on a hybrid saw. After selling the ryobi. Could have spent the same money and bought an old powermatic off craigslist. With little effort that saw would be good as new, and way better. The little tsboe top my be good for you though. Depends on what you want to be able to do.
-- John
View axam's profile
axam
#6 posted 08-04-2016 01:05 AM
I am thinking of making a table and a work bench. working out of a small shed. not really intended as a workshop.
so small, compact & portable would be prefred
do you have any blade recommedations. i understand that the stock blade would not be very good. i have no ideas of blades.
dewalt 745
I would live to get a Dewalt but it’s waay over budget, the cheapest Dewalt the 745. is going for $840.
I personally believe that an inexpensive tool is inexpensive…
I completely agree with you. was thinking if I got the cheapest of the cheap it would be more trouble then it’s worth.
View Kirk650's profile
Kirk650
525 posts in 804 days
#7 posted 08-04-2016 01:55 AM
Look at the Ridgid at Home Depot. The one with the collapsible support frame. I had an older version that worked great for me for 5 or 6 years.
MikesProjects
#8 posted 08-04-2016 04:09 AM
QUOTE: “I have them all & prefer the DeWalt by far” No kidding.I’d like to see a pic of that.Guess your a real expert?I’ve been doing this daily for 45 years and have yet to own or try “them all” The best tool of any kind is the tool that works best for you and fits your budget.
You can always upgrade when you feel you need to and have the extra cash. END QUOTE
Yes, No Kidding, Im not an expert, just an expert table saw user & abuser. You caught me ;), I dont own a bosch but a guy at work has one that I often use. A photo? I don’t have that but heres a video I did several years ago reviewing a bunch of my table saws .. Im now more into cabinet saws but have acquired several more portable table saws since I shot the vid. If you’d like to, I believe you can view the first several seconds of the video to see the saws, its really not a big deal.
https://www.youtube.com/watch?v=idenTvNNdB0
I hope I didn’t come off sounding like some kind of know it all , just trying to help.
Yes I have a lot of real world experience with table saws & wood working. I have been eying the sawstop job site saw. Its a little pricey & bulky but one day I may get one. Since I like the dewalt Im pretty much over purchasing any more jobsite saws…
axam, sorry to hear the dewalt is so expensive over there, Perhaps you could swing the Makita, they are good quality. Also don’t be afraid to purchase second hand.
I agree about the craftsman belt saws, I have several & do enjoy using the one with the upgraded biesemeyer fence.
Axam, where are you located?
bigJohninvegas
#9 posted 08-04-2016 01:39 PM
http://www.grizzly.com/tablesaws?rankBy=price+asc
Check out this link to grizzly table saws. They have dewalt for under $500. And ship to your door.
As far as saw blades. One of the best would be the forest woodworker 2 blade. They are around $120.
I started out with the freud diablo blade thst you csn get at home depot. They are ok, but don’t last as long.
Good luck.
-- John
View axam's profile
axam
#10 posted 08-05-2016 02:38 AM
grizzly table saws.
That looks awesome thanks for that…
But I am in Australia WA so that’s a bit further for delivery and cost!!
Do you think that the MAkita MLT100 is better then the Bosch GTS 10 J?
bigJohninvegas
#11 posted 08-05-2016 03:28 PM
Sorry axam, I was not thinking on a global scale. Not sure if they even ship to Australia.
I saw your location as WA and went right to Washington state, USA. Lol
-- John
View axam's profile
axam
#12 posted 08-06-2016 03:24 AM
No worries, easy mistake to make in this day and age.
Any recommendation on saw blades?
View LoyalAppleGeek's profile
LoyalAppleGeek
160 posts in 950 days
#13 posted 08-06-2016 06:46 AM
As for Saw Blades, Freud all the way. They hold an edge very well, never get hot, stay clean for a long time, and with a diamond file can easily be re-sharpened to factory sharpness. The cheapest go for about $40 USD from Amazon.com
Also helpful is this video from John Heinz, the simplest way in the world to sharpen a blade, no jig required and FAST: https://m.youtube.com/watch?v=HVxHa-4X2YQ.
Lowes has several very good options for small table saws, among them Delta, Dewalt, Kobalt, Ryobi and Bosch, the cheapest being $279, pictured below. I use that saw frequently, and after a few adjustments, it performs very well.
Here’s the international shipping request form to fill out from Lowes: http://www.lowes.com/cd_International+Sales_776316152_
View axam's profile
axam
#14 posted 08-06-2016 08:13 AM
cool thanks for that, it is always handy to have/know of other places to source things from.
But I kinda want it yesterday!!
that Kobalt saw looks really good mind.
Thanks for the Freud saw blade tip as well !! i will try to source some locally. do you know if they go buy another brand name?
View knotscott's profile
knotscott
8080 posts in 3431 days
#15 posted 08-06-2016 11:39 AM
Best bang for the buck in blades is usually the Freud Diablo or Irwin Marples blades. Both made in Italy, both high quality blades for the money. Sometimes closeouts can lead to better deals if you know what you’re looking for. Good quality is important, but so it the condition of the blade….clean and sharp is the only way to go. A high quality blade that’s gummed and dirty, will cut poorly, and will soon be a dull blade. Dirty blades cause excess heat, which causes premature dulling. Keep them clean.
Sharpening and honing your own blades can be a very risky venture. Do it wrong, and you can ruin a perfectly good blade. The Youtube video mentioned above about honing the face of the blade works well in that particular scenario, but if the tooth face isn’t 90° to the sharpening stone, you’ll change the hook angle, and likely make the blade perform worse. Proceed with caution! (professional sharping typically costs ~$15-$20, which may not make sense for a $20-$30 blade, but makes a lot of sense for a $60-$130 blade)
Portable saws are great for portability, but they give up a lot in comparison to a full size saw with a belt drive induction motor. Many times it’s just not feasible to go with a stationary saw on wheels, but if there’s anyway possible to make it work, you’ll end up with a more robust long term saw. The ABCs of Table Saws
Compare the landing zone area in front of the blade, which is the area that allows you to get a board settled and flush with the table surface before the board contacts the blade:
