LN No.4 Smoothing Plan vs LN 62 LAP
« back to Hand Tools forum
Forum topic by Civilsurf posted 08-02-2016 10:16 PM 883 views 0 times favorited 16 replies Add to Favorites Watch
View Civilsurf's profile
Civilsurf
11 posts in 930 days
08-02-2016 10:16 PM
Topic tags/keywords: hand plane
I am a beginner woodworker and have the budget for both No. 4 and No.62. Is it really necessary to get both planes at the same time? Any recommendation?
-- Shawn, Singapore
16 replies so far
View bbasiaga's profile
bbasiaga
1242 posts in 2233 days
#1 posted 08-02-2016 10:44 PM
What kind of power tools do you have? The common advice is that if you are working with material that has been jointed and planed by power tools, the jack plane is less of a need, as you’re basically ready to start smoothing with your No 4.
If you work a lot with slabs or wide panels that you need to flatten or adjust but you can’t fit through your planer/jointer, then the jack is more useful.
Brian
View jdmaher's profile
jdmaher
440 posts in 2818 days
#2 posted 08-02-2016 11:03 PM
Get the No. 4. Wait on the 62.
Smoothing (the No. 4) is a task common to almost all projects, and a very satisfying activity. The 62 is a “jack-of-all-trades”, IF you buy and maintain a variety of blades for different tasks. But each of those tasks might not be required very often, depending on how you choose to work. I have both. I use the No.4 at least weekly. I use the 62 two or three times a year.
Much depends on what lumber sources you have access to and what equipment you have and what you want to do.
As a new woodworker, I recommend that you try to buy wood that is “S4S” (surfaced on all four sides). That will minimize your uses for a 62. Just build something; get a few projects done and see how you enjoy it.
As you build your experience, you might decide that you want to do work with rougher lumber, but you can use either power tools or hand tools (or both) to mill that wood. For me, milling wood is less satisfying than other aspects of the craft, and I don’t really use my 62 that often. But I DO use my No. 4.
-- Jim Maher, Illinois
View TheFridge's profile
TheFridge
10817 posts in 1724 days
#3 posted 08-02-2016 11:52 PM
I’d say the 4.
View Don W's profile
Don W
19050 posts in 2806 days
#4 posted 08-03-2016 12:05 AM
I agree with the #4. The #62 would be good if you were making a lot of end grain cutting boards or something like that. I’ve got a #62, its one of my least used Planes.
View Logan Windram's profile
Logan Windram
347 posts in 2700 days
#5 posted 08-03-2016 01:02 AM
I’d go 62, a little different reasoning from others. As a new woodworker, you’ll probably benefit from the ability to flatten and rough lumber that the 62 offers, unless you have jointer, planers and TS. To be honest, I rarely use a smoothing plane, I cleanup machine marks quickly with my 62 and spend a lot of time with a cabinet scraper and even more so sanding for surface prep. Some might argue you can use a 4 to get a piece ready to finish and skip sanding, maybe you can, but IMHO finish looks best on a surface with a consistent 220 scratch pattern. Also, as a new woodworker the ability to use that 62 on a shooting board is priceless, so I’d get the shooting board handle on the 62 when you buy it. There is a great article in FWW on buying extra blades for the 62 for different uses.
I don’t know, I can see the smoother argument, but for me the 62 is so versatile for a first plane (and heavy enough to ease use) that it would be my first purchase. Again, no right or wrong, just preference and method of work.
Logan Windram
#6 posted 08-03-2016 01:07 AM
As you build your experience, you might decide that you want to do work with rougher lumber, but you can use either power tools or hand tools (or both) to mill that wood. For me, milling wood is less satisfying than other aspects of the craft, and I don t really use my 62 that often. But I DO use my No. 4.
- jdmaher
S4S will still likely need a flattening and squaring to make it furniture building ready…. But it sure will get him closer than rough sawn, point well taken.
View OSU55's profile
OSU55
2029 posts in 2228 days
#7 posted 08-03-2016 02:09 AM
You don’t mention if you’ve ever used a hand plane or have any others. If you’re made of $ nothing wrong with starting with LN, or Veritas, but it’s a major investment, although either brand resells very well if you decide planes aren’t for you. For smoothing, a 4 or 4-1/2 (my preference). If you decide to go the premium plane route, get steeper frog for figured wood along with the 45° “standard”. LN offers 55°, Veritas Custom planes can be ordered with any frog angle 40°-65° in 1/2° increments.
If you’re going to do rougher “jack plane” work, you want a Stanley Bailey #5 (probably the most plentiful and lowest cost used plane on the planet). The LN and Veritas LA jack planes don’t work as well as a #5 for jack plane work. Where they shine is end grain/shooting board work, final panel flattening and smoothing if desired, and jointing, though a little short. Multiple blades at different angles depending on the work. I have the Veritas BU LAJ. Here's my opinion on 1st planes.
View Kirk650's profile
Kirk650
585 posts in 987 days
#8 posted 08-03-2016 04:18 AM
I have a couple of 4’s, a 4 1/2, a 3, and a 5 and some others. My two best planes are a LN Bronze 4 and a Veritas 4 LA smoother. If I really need smooth I reach for the old Stanley Bailey 4 1/2. Took me forever to get that rascal to working like I wanted it to, but now it cuts super nice. After that I suppose the LN 4 would be my choice of a smoother. That said, the Veritas 4 LA plane gets used the most for general work and smoothing. I really like the way that Veritas is set up, with the set screws to hold the iron in place and the adjustable mouth. Great design.
Didn’t answer your question that well though, did I? Ok, different approach. The plane I would most hate to lose is the Veritas 4 LA smoother.
TheFridge
#9 posted 08-03-2016 04:43 AM
http://contrib1.wkfinetools.com/rittnerB/sUpCapIron/sUpCapIron-01.asp
Watch this video. Very informative if a little boring. Changed my views on planes without a cap iron not used for end grain.
View rwe2156's profile
rwe2156
3230 posts in 1719 days
#10 posted 08-03-2016 11:59 AM
Definitely the smoother first.
BTW I opted for the LN 4 /12. I like it better for face planing.
Something to consider.
Civilsurf
#11 posted 08-08-2016 09:49 AM
What kind of power tools do you have? The common advice is that if you are working with material that has been jointed and planed by power tools, the jack plane is less of a need, as you re basically ready to start smoothing with your No 4.
If you work a lot with slabs or wide panels that you need to flatten or adjust but you can t fit through your planer/jointer, then the jack is more useful.
Brian
- bbasiaga
Hi Brian, thanks for your advise.
1) Can i say that Jack plane are those with longer body i.e. 14” and above? As such, they are more suitable for flattening longer timber?
2) I still can’t fully understand the difference between the use between a standard Jack Plane vs a LA Jack Plane?
3) kind of plane should l use to remove timber that has paint on it?
Shawn
-- Shawn, Singapore
Civilsurf
#12 posted 08-08-2016 09:54 AM
I d go 62, a little different reasoning from others. As a new woodworker, you ll probably benefit from the ability to flatten and rough lumber that the 62 offers, unless you have jointer, planers and TS. To be honest, I rarely use a smoothing plane, I cleanup machine marks quickly with my 62 and spend a lot of time with a cabinet scraper and even more so sanding for surface prep. Some might argue you can use a 4 to get a piece ready to finish and skip sanding, maybe you can, but IMHO finish looks best on a surface with a consistent 220 scratch pattern. Also, as a new woodworker the ability to use that 62 on a shooting board is priceless, so I d get the shooting board handle on the 62 when you buy it. There is a great article in FWW on buying extra blades for the 62 for different uses.
I don t know, I can see the smoother argument, but for me the 62 is so versatile for a first plane (and heavy enough to ease use) that it would be my first purchase. Again, no right or wrong, just preference and method of work.
- Logan Windram
THanks Logan,
my intention is to get a 62 but just want to be sure before getting one. I have a few years of handon experience with plane during my school date and consider myself as a beginner for now.
What do you mean by TS and IMHO?
What brand will you recommend for a 62?
Shawn
-- Shawn, Singapore
Don W
#13 posted 08-08-2016 10:49 AM
http://www.timetestedtools.net/2016/01/26/what-bench-planes-do-i-need/
View mike02130's profile
mike02130
170 posts in 911 days
#14 posted 08-08-2016 11:22 AM
LN tools are nice. A bit pricey for most. Not that they charge so much but because most of us are underpaid. I’ve used Stanley planes all my life. Never complained about them. For the price you’re going to pay, you you can pick up a Stanley #3, 4, 5 and a block.plane and a couple of Hock or LN blades and have a lot of fun experimenting and using them. The one LN plane that is a must have for me is their low angle block plain. The 102.
-- Google first, search forums second, ask questions later.
bbasiaga
#15 posted 08-08-2016 03:28 PM
Brian
- bbasiaga
2) I still can t fully understand the difference between the use between a standard Jack Plane vs a LA Jack Plane?
Shawn
- Civilsurf
1. Yes, that’s about right for a jack plane length…maybe 14” max. A little too long for good smoothing, a little too short for good jointing. But reasonable at both. Hence the ‘jack’ of all trades. It is not really for jointing long timbers. It is more for getting them close to final dimension and reasonably flat. Then you come in with a No 7 jointing plane to make flat and true, and a no 4 to smooth. So if you use power tools to get flat and true, you may not need the jack as much.
2. They do mainly the same thing. The advantage of the LA jack is that it is possible to sharpen the blade at different angles for different work. 25 degrees for end grain shooting, 38 degrees for reduced ear out while working face or long grain. A regular jack will always cut at the angle of the frog. LA jack planes also have an adjustable mouth to open for rough work, or close for reduced tear out. Really it is the flexibility of the LA jack that makes it useful to some. Others prefer the regular.
3. For this you could get a toothed blade or scraper blade for the LA jack, but you might also consider just getting a No 80 cabinet scraper to take the abuse.
Being in singapor, I’m not sure if the used market for old stanley is as cost effective for you, but it is something to consider.
Brian
