RESAWING
Forum topic by rbm328 posted 08-02-2016 12:52 PM 796 views 0 times favorited 4 replies Add to Favorites Watch
View rbm328's profile
rbm328
13 posts in 1115 days
08-02-2016 12:52 PM
i have available to me, an almost unlimited supply of 2×6x8’ rough poplar. most of the boards have some bows and a few have crooks.
my question is: i want to resaw most of them in half lengthwise (i’d cut into smaller pieces first), do i follow the bow then plane to flat? or saw close to flat and plane minimally?
thanks
rich
View Gene Howe's profile
Gene Howe
11135 posts in 3663 days
#1 posted 08-02-2016 01:38 PM
Cross cut, joint flat, then resaw. Planer will only make the boards thinner. It won’t flatten them.
View KelleyCrafts's profile
KelleyCrafts
3389 posts in 973 days
#2 posted 08-02-2016 03:50 PM
Gene is right. Joint it flat, then resaw then co-planer the wood. The wood will be a different width once you joint it. Jointing will take the bow out.
People get this confused often but I will do the HIGH LEVEL overview here.
Jointing = making the board flat (taking out bows, etc.)
Planing = making the board the same thickness over the length of the board
Definitely you want the board flat before you resaw otherwise you won’t really know the thickness of the final piece if you resaw the bow and then joint it flat. You might end up with veneer.
-- Dave - http://kelleycrafts.com/ - pen blanks - knife scales - turning tools
View GR8HUNTER's profile
GR8HUNTER
5363 posts in 947 days
#3 posted 08-02-2016 04:53 PM
Cross cut, joint flat, then resaw. Planer will only make the boards thinner. It won t flatten them.
- Gene Howe
TRUE THAT DITTO
View Jon Hobbs's profile
Jon Hobbs
147 posts in 939 days
#4 posted 08-02-2016 07:45 PM
Do you have a specific project in mind for these boards? I’m not sure I’d go planing, resawing, or jointing anything until I had specific final dimensions in mind. You might find out later that you needed it thicker, longer or wider than what you’ve done to it already.
-- Jon -- Just a Minnesota kid hanging out in Kansas
