New Delta 36-725 trips breakers, occasionally starts
Forum topic by Dagobah posted 08-02-2016 12:51 PM 1806 views 0 times favorited 17 replies Add to Favorites Watch
View Dagobah's profile
Dagobah
71 posts in 660 days
08-02-2016 12:51 PM
Topic tags/keywords: tablesaw
A few weeks ago I got a new Delta 36-725. It wouldn’t start when using my 50’ extension cord. After switching out the cord for a shorter/heavier one, the saw started and I thought my problem was fixed. A few days pass and this weekend I built a crosscut sled, but ran into the same problem. On startup it would just buzz, move an inch and never start. I tried multiple outlets and finally got it to start after using an outdoor outlet.
I went ahead and made a few cuts on 3/4” pine plywood, but it was slowing and requiring some effort to push the workpiece through towards the end of the cut. I’ve used a cheap portable contractor saw before, and this wasn’t cutting nearly as easy as that did.
I’ve read that the factory blades that comes with saws are usually pretty bad, so I attributed it to that and bought a Diablo 50T Thin Kerf combo blade from Woodcraft. It didn’t help. :(
After making a few more cuts, I went to turn on the saw and it wouldn’t start at all. I looked on my wall panel and it had just tripped the 20amp breaker.
Tonight I tried plugging it into my Washing Machine outlet to see if it’d work on a dedicated breaker. Then this happened: https://www.dropbox.com/s/f7sny6bw1f4rykq/VID_20160801_224940.mp4?dl=0
The first click at the end is the saw tripping it’s own internal breaker. This is the first time that’s happened.
At this point I assume it’s either a problem with my wiring or the saw. I’ve never had issues running anything else off these outlets before, so I’m starting to think it might be the saw.
Any ideas? I’m new to this, so there may have been something else I’ve overlooked.
17 replies so far
View johnstoneb's profile
johnstoneb
2914 posts in 2170 days
#1 posted 08-02-2016 01:13 PM
It’s still under warranty return it.
-- Bruce, Boise, ID
View WhyMe's profile
WhyMe
1013 posts in 1558 days
#2 posted 08-02-2016 01:36 PM
Call Lowes about returning it, but I got a feeling they will say to contact Delta for the warranty. I hope you did register it with Delta for the warranty?
View Kirk650's profile
Kirk650
524 posts in 746 days
#3 posted 08-02-2016 02:11 PM
Your saw has a blade brake. Could it be the problem?
View knotscott's profile
knotscott
8013 posts in 3373 days
#4 posted 08-02-2016 02:49 PM
Could have a bad capacitor….possibly caused by excess current flow due to the 50’ extension cord. Should be under warranty….if that’s the culprit, it’s an easy fix even if not covered under warranty.
WhyMe
#5 posted 08-02-2016 02:50 PM
- Kirk650
It does have a blade brake. Dagobah, just for curiosity with saw unplugged turn the blade by hand to see if there is a lot of resistance.
WhyMe
#6 posted 08-02-2016 02:52 PM
Could have a bad capacitor….possibly caused by excess current flow due to the 50 extension cord. Should be under warranty….if that s the culprit, it s an easy fix even if not covered under warranty.
- knotscott
Yeah.. that was a bad move to run that saw on a 50’ cord. It could have damaged the motor.
Dagobah
#7 posted 08-02-2016 02:53 PM
- Kirk650
- WhyMe
I can spin the blade when unplugged. It doesn’t spin freely, but has some resistance.
Dagobah
#8 posted 08-02-2016 02:59 PM
- knotscott
Yeah.. that was a bad move to run that saw on a 50 cord. It could have damaged the motor.
- WhyMe
Keep in mind the saw never actually ran on the long cord. I plugged it in, wouldn’t start and got another shorter cord. I’d hate to think that damaged the motor. I had no idea.
Dagobah
#9 posted 08-02-2016 03:26 PM
Just got off the phone with Delta and Lowes. Delta said it sounds like a bad starter capacitor or possibly the motor. They didn’t think the long cord could have done it. Lowes was great, and said they’ll sell me a new one, deliver it for free and pickup the old and do a return at the same time.
I didn’t have an easy way of returning the saw, so this helps a ton.
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3710 days
#10 posted 08-02-2016 03:41 PM
That sounds like a good solution! It is to be hoped the next saw will be MUCH better.
View avsmusic1's profile
avsmusic1
257 posts in 683 days
#11 posted 08-02-2016 05:36 PM
Why/How?
avsmusic1
#12 posted 08-02-2016 05:37 PM
Why/How?
View MrUnix's profile
MrUnix
6710 posts in 2196 days
#13 posted 08-02-2016 06:53 PM
- WhyMe
Why/How?
- avsmusic1
The use of an improperly sized extension cord will cause the motor to overheat, eventually causing the motor to fail due to the breakdown of insulation. However, it would require a bit of use under that condition to get to that point, so if you just plugged it into one and it didn’t run, I doubt that caused any damage.
WhyMe
#14 posted 08-02-2016 11:28 PM
It wasn’t said how long the saw was used on the 50’ cord before it would no longer start. Depending on the voltage drop it could damage the motor in short order.
MrUnix
#15 posted 08-02-2016 11:36 PM
It wasn t said how long the saw was used on the 50 cord before it would no longer start.
- WhyMe
<evil-grin>
Go back and read response #8 above. But it’s irrelevant at this point, since it’s being replaced under warranty.
