How do you create the rough cut mill looking texture?
Forum topic by Danestar posted 1095 days ago 3201 views 0 times favorited 17 replies Add to Favorites Watch
View Danestar's profile
Danestar
30 posts in 1217 days
1095 days ago
Without running boards to a mill are there methods used to create the rough cut and rough scraped wood. Similar to the texturized hard wood flooring seen in custom homes. Was curious how people are achieving this on hard wood. Anyone know the process?
Thanks
17 replies so far
View lew's profile
lew
8979 posts in 1923 days
#1 posted 1095 days ago
How about sand/soda blasting the surface?
-- Lew- Time traveler. Purveyor of the world's finest custom rolling pins!
Danestar
#2 posted 1095 days ago
Ahhhh now that makes sense.
View uffitze's profile
uffitze
197 posts in 1123 days
#3 posted 1095 days ago
There are probably a lot of different systems all of which give a slightly different look.
Some ideas …
  • When you flatten the initial face of a board on the jointer, take just enough passes to get the board to sit flat. (That’s proper jointer technique anyway.) Then when you plane the board to thickness, take all of your passes off of the other side. This will leave a board with some mill marks, and some smooth spots on your show side. The obvious drawback to this idea is that the board cup/twist/bow due to the taking all of your planing passes from the same side. But, then again, if you T&G it, and nail it to a floor, it’s probably not going anywhere.
  • Build yourself a “surfacing” machine not unlike the drum sanders that some of the guys here have built, but with a circular arbor, and some sort of cutting or grinding attachment to give the sawmill look. (Sounds dangerous.) Joint/plane as normal and send your boards through your surfacing machine.
  • A variation on the surfacing machine idea … get yourself a crappy table saw with a dull blade that will leave lots of marks, set up some featherboards so you can run your stock through on edge, put the guards on the saw. Again, joint/plane as normal to get even stock.
  • Use standard distressing methods (chains, rocks, hammers, sandblasting) in conjunction with whatever idea you use to get the regular “sawmill” pattern.
View GregD's profile
GregD
597 posts in 1304 days
#4 posted 1095 days ago
How do I achieve rough cut and rough scraped wood? I’ve been working for the past year or so to not achieve rough wood when I work it. Making good wood look bad is no-problemo for me. I must be a natural! 8-)
-- Greg D. -- the price of freedom is tolerance
87068 posts in 1745 days
#5 posted 1095 days ago
You can make the rough cut look buy setting up your fence on a band saw and running the board backwards so it rubs against your blade.
View SCOTSMAN's profile
SCOTSMAN
4309 posts in 1753 days
#6 posted 1095 days ago
please write this down carefully, whack the wood at regulo mark 99 for twenty four hours beating constantly with a sock full of cold grits ,and the rub down with an elderly naked lady for four hours on both sides .Then when allowed to cool down,a final wipe down with a dirty diaper full of wet sawdust and donkey fur .Then a final pass over with scalding hot leg irons or chains to texturise the surface, then soak the completed project red beetles urine about forty gallons should do for a week,then leave over the next forty years to dry out in the desert sun.And if that doesn’t work I really have nothing better to suggest.PS please don’t block this message as it may one day save a few bucks to someone.and as a half live morphined Scotsman this is ultra important. Alistair
#7 posted 1095 days ago
Your great Alistair!
SCOTSMAN
#8 posted 1095 days ago
I always new it but am too shy to shout or proclaim it from the rooftops .That is till I discovered Morphine loosened the tongue somewhat, or in this case the keyboard LOL .Alistair
#9 posted 1095 days ago
Keep shouting it works
Danestar
#10 posted 1095 days ago
Thanks guys… I am trying to find the image on my phone showing what I’m talking about specifically. As soon as I locate it I will post up.
View poroskywood's profile
poroskywood
612 posts in 1532 days
#11 posted 1095 days ago
I have to say the old circle mills are becoming a thing of the past. First off the running of one and care for the saw (Sharpening, Hammer, Swedging) are becoming a lost art in this modern era of band milling. Also Circle saw mills not being able to compete with modern efficiency are slowly going out of business or upgrading to band saw. Lumber with circle saw marks from the saw mill surely are harder to find. This will become more of a prominent question as time continues to pass.
-- There's many a slip betwixt a cup and a lip.--Scott
View Dan Lyke's profile
Dan Lyke
1366 posts in 2293 days
#12 posted 1095 days ago
For the scraped floor look, several of the power planers actually have alternate blades to help with that. Not my aesthetic, but perhaps a tool you could use.
View Gary's profile
Gary
3546 posts in 1601 days
#13 posted 1095 days ago
Hey fellow Texan…...come home. We’ve got lots of mills where you can buy it that way!!
View Les Casteel's profile
Les Casteel
147 posts in 1227 days
#14 posted 1095 days ago
In the past I’ve taken an old 10” sawblade, laid it on the bench and tapped down one tooth just a little with a wood mallet. then skip 4 or 5 teeth, bend another, then run the wood through and it somewhat simulates the old sawmill look. Of course the sawblade is useless for real work after that so mark it in some way.
-- Les, Arkansas, www.woodthatrocks.com
View Tim Lawson's profile
Tim Lawson
17 posts in 1119 days
#15 posted 1094 days ago
Go back to the original surfacing method – a hand adze? It’s on my agenda to make one and learn to use it. The demonstrations I’ve seen are remarkably fast. Not rough cut but still a random hewn look. Wouldn’t scale to production but could be fun (and quiet) in a smaller shop.
Tim
-- Tim Lawson http://www.ptwoodschool.com http://www.timlawson.net
