Eliminating play in heel of plane tote
« back to Hand Tools forum
Forum topic by wood2woodknot posted 08-02-2016 02:17 AM 577 views 0 times favorited 6 replies Add to Favorites Watch
View wood2woodknot's profile
wood2woodknot
97 posts in 2176 days
08-02-2016 02:17 AM
I have had several planes with some degree of play at the heel of the tote. (One is a Sargent #4 and one a Stanley #4). I have tried several things to eliminate the play, none of them successful. I can tighten them, but they soon loosen up again. In some cases the movement is slight, in some a little more so. So is this common? Is there a cure?
Some of the “cures” I have tried are:
a) tightening the long bolt in the tote,
b) adding a washer under the bolt head to account for wear,
c) flattening the bottom of the tote,
d) adding a thin compression shim (piece of thin rubber; paper/index stock) under the tote,
e) adding glue (don’t remember if it was pliable like hot glue, or more rigid) – not epoxy.
The only other option I can think of is to make a totally new tote, but then I’m not sure that would solve the problem either.
Does anyone have any suggestions based on your experiences with your own planes?
-- ajh
View bondogaposis's profile
bondogaposis
5093 posts in 2554 days
#1 posted 08-02-2016 02:28 AM
I’ve shortened the bolt.
-- Bondo Gaposis
bandit571
21775 posts in 2886 days
#2 posted 08-02-2016 02:32 AM
Totes will shrink over time…
You can grind off a couple threads on the bolt itself, shortening it by..1/8” or less.
Options #2: Get a roll of that poly stuff they use as drawer liners for tool boxes. Cut out a bit to mat the bottom of the tote. little undersized won’t hurt. Apply it to the bottom of the tote. May have to trim a bit around where the bolt attaches to the base.
View Don W's profile
Don W
19014 posts in 2770 days
#3 posted 08-02-2016 11:08 AM
I’ve heard shelf liner works well for this. You can also wax the base good and add some epoxy, but it depends on what type of base it is. Post a few pictures. This sin’t a rare problem, but shortening the bolt or adding some washers typically takes care of it.
View rwe2156's profile
rwe2156
3171 posts in 1683 days
#4 posted 08-02-2016 12:49 PM
How about the bottom is not mating well with sole? or slightly rounded?
If its dead flat and mating up well, it has to be screw tension.
View JayT's profile
JayT
5961 posts in 2413 days
#5 posted 08-02-2016 12:55 PM
I’d try the bolt &/or shelf liner first. If that doesn’t work, one thing I’ve thought of, but never done, is to take a small piece of wood and fit it to the small void in the center of the casting under the tote. Once it’s shaped and has a good, tight fit, glue it to the bottom of the tote.
View OSU55's profile
OSU55
1972 posts in 2192 days
#6 posted 08-02-2016 06:57 PM
The tote mount flange needs to be flat, and the bottom of the tote needs to be flat. I add washers under the nut until the bolt doesn’t bottom out in the nut. It’s possible the bolt is hitting the tote hole and not allowing the tote bottom to sit on the flange, allowing the tote to rock and getting loose again. I’ve had to remove some wood on the inside of totes due to interference. Here's drawings for custom totes I make for my planes.
