Sometimes its just a dirty blade
Forum topic by rhett posted 05-21-2010 12:58 AM 1719 views 0 times favorited 16 replies Add to Favorites Watch
View rhett's profile
rhett
742 posts in 3668 days
05-21-2010 12:58 AM
I have an old friend who is starting down the woodworking path. He called me stating that his tablesaw was producing severely burnt looking cuts. Wanted to know if I could help tune up his saw. Knowing that I would get free run of his homebrew, this was a no brainer.
Conclusion, the saw is fine. The blade was simply covered in gum and pith. So, quick lesson to any beginners, cleaning your saw blades helps to lengthen their life and makes for nicer finished cuts.
Cheers!
-- Doubt kills more dreams than failure.
16 replies so far
View live4ever's profile
live4ever
983 posts in 3011 days
#1 posted 05-21-2010 01:41 AM
Wow, you really had to earn that brew, huh?
Thanks for the tip!
View Gene Howe's profile
Gene Howe
10479 posts in 3429 days
#2 posted 05-21-2010 01:49 AM
“Will clean blades for Beer”
rhett
#3 posted 05-21-2010 02:40 AM
I’ve done more for less
View TomHintz's profile
TomHintz
207 posts in 3399 days
#4 posted 05-21-2010 08:30 AM
I had a fellow who makes/sells table saw blades tell me years ago that nothing sells new blades like pitch buildup on otherwise perfectly good blades.
It seems that most people know that a clean blade cuts better yet we constantly hear of people being surprised about how well cleaning blades works. Maybe this is one of those things that just never really makes sense, yet there it is.
-- Tom Hintz, www.newwoodworker.com
View knotscott's profile
knotscott
8018 posts in 3376 days
#5 posted 05-21-2010 12:11 PM
Clean blades cut better and last longer. A dirty blade cuts like a dull blade, and ensures that it will become one way too soon!
View Mary Anne's profile
Mary Anne
1058 posts in 3209 days
#6 posted 05-21-2010 12:42 PM
Thanks for the tip. I was thinking, for $100 blade, mine had gotten dull pretty quick. I’ll spend some cleanup time before my next project.
View Knothead62's profile
Knothead62
2584 posts in 2962 days
#7 posted 05-21-2010 11:05 PM
Ok, what is the best way or cleaner stuff for a blade. I’m should clean mine, I guess.
117095 posts in 3578 days
#8 posted 05-21-2010 11:09 PM
To clean a blade you can use a commercial blade cleaner or goof off (works good) and I’ve read a post that suggested wash soda (I haven’t tried it yet)
View uffitze's profile
uffitze
199 posts in 2956 days
#9 posted 05-21-2010 11:26 PM
Oven cleaner is supposed to work good too.
rhett
#10 posted 05-21-2010 11:52 PM
Kaaboom bathroom cleaner is amazing effective along with a stiff bristle tooth brush. Its also cheaper and not as caustic as oven cleaner. It will however take off some of the teflon coating on certain blades. I have found that my Forrest blades get slight discoloration on the metal but none of this effects the performance. Lay your blade on a nonpourous surface, melamine, spray then flip and spray again. Let it set for about 30 seconds and scrub away the gum. Rinse with water and towel dry. Cut out a set of cabinets and repeat.
Knothead62
#11 posted 05-22-2010 02:17 AM
Thanks. My to-do list keeps getting longer.
View SnowyRiver's profile
SnowyRiver
51457 posts in 3481 days
#12 posted 05-22-2010 02:35 AM
Good advise rhett.
-- Wayne - Plymouth MN
Rick Dennington
5864 posts in 3195 days
#13 posted 05-22-2010 07:54 AM
Greetings all,
You can also use Formula 409, Simple Green, any pitch and gum remover from any of the woodworking supply stores, but just go to WalMart and pick up the above mentioned items, and you’re good to clean…uur,go…...... I use the stuff from Rockler… I foget the name, but it sure works good….....
View oldhickory's profile
oldhickory
9 posts in 3060 days
#14 posted 05-22-2010 04:12 PM
I found that for a 10” blade turn a 5 gal. bucket upside down the blade fits perfect spray with oven cleaner and let set spray off with garden hose no scrubing and no getting dirty wipe dry and reinstall it takes me about 10 min. best way i found.
good luck
View juanabee's profile
juanabee
109 posts in 3009 days
#15 posted 05-26-2010 10:24 PM
Some of these higher-end blades are coated with a special anti-friction finish. Won’t the oven cleaner take it off and degrade the blade?
-- "Life's nonsense pierces us with strange relation." Wallace Stevens
