| Forum topic by clieb91 | posted 1976 days ago | 788 views | 0 times favorited | 9 replies | ![]() |
1976 days ago |
Topic tags/keywords: milling wood Ok, so I have a novice’s question about downed trees.. where I work we are almost always cutting down limbs or trees after a storm rolls thru and I think it is a true waste to see us just toss the logs in a pile to rot. My goal is to hopefully, someday talk the someone into buying a milling set up. In the meantime; however, with the lack of tools I have. Using smaller limbs lets say 6-8” around what is the best way for me to be able to use this wood. I would of course love to be able to mill it into boards for small boxes and other stuff, but that will have to wait for decent bandsaw. Thanks All. I am sure I will have more questions about this topic in the future. CtL -- Chris L. "Don't Dream it, Be it." |
9 replies so far
#1 posted 1976 days ago |
I don’t do alot of woodturning but with an inexpensive lathe you could do alot with those size pieces and the best part is you can turn them still green most turners prefer it.I would check and see if there is a local woodturning group in you area. -- Scott NM,http://www.shangrilawoodworks.com |
#2 posted 1976 days ago |
Sometimes we need to be reminded that boxes grow on trees. -- "The way to make a small fortune in woodworking- start with a large one" |
#3 posted 1976 days ago |
Cil: It is not recommended that large wood boards be made from branch wood. A tree trunk grows straight and tall, Where as a branch grows out from the tree. The wood in branches have what is called reaction wood. It grows under the forces of gravity which causes the branches to bend. When you cut boards the bends try to come out. And in some cases it comes out as you try to make furniture. If you are talking about making boxes you should be OK. But I wouldn’t use 1 X 8 – 10’ long from a branch they will surly bend on you and bow and cup. It would almost be imposable to keep them straight. -- I've been blessed with a father who liked to tinker in wood, and a wife who lets me tinker in wood. Southern Delaware karson_morrison@bigfoot.com † |
#4 posted 1976 days ago |
What Karson said. But short pieces for small work is doable, so is turning stock like was mentioned. If you cut off disks (cookies) soak them with Tung oil as soon as you cut them, that is my trick to keep them from busting when they dry. |
#5 posted 1976 days ago |
As Karson said, branch wood will almost always give you problems. You also have to be sure to cut the pith out it or it will almost surely split. This drying reaction starts almost immediately, so you have to act fast when the limbs are cut. You will have to experiment with cutting disks and drying them w/o splitting. Thickness, species of wood, time of year all have an effect on this. Believe it or not, microwaving in short bursts will dry smaller pieces. It helps to have a digital scale to use this method. You never get the pieces hot. You are just cooking the water out, with resting times between to cool. Stop when the piece doesn’t lose weight any more. |
#6 posted 1975 days ago |
LONGHAIR is right about the microwave, I do it all the time. Sounds odd, but you can boil wood dry too, in a big pot of water. I have boiled it dry just to prove it works, but prefer the microwave. I have done much with cross sections, for years people said PEG (Polyethylene glycol ) and other expensive/pain in the rear blah,blah. Tung oil has worked best for me, and it can be finished over. I cut cross sections for taxidermists, clockmakers…the best way to cut them is on a slight angle, you have more of an oval than a circle. But you will also have more strength, longer fibers not just all endgrain. Endgrain is hard to dry without checking. |
#7 posted 1974 days ago |
Daren, I checked out your website, now I understand the question. You have a lot of great stuff there. I take it from what I read that you are in IL? I am in Columbus Oh. I will have to look further into your stock. |
#8 posted 1967 days ago |
I have cut and used a lot of Oak, Maple and Walnut limb wood and found that the amount of warpage and defects are not enough to be detoured from making wide or long boards. You will always find it easier to dry straight saw logs compared to logs with bends or twists. Some of my favorite projects come from limb wood, short logs or were twisted, other sawyers would not even look at a second time at these. Until you have a band saw it may be hard to process the limbs other than with a chain saw (thats where I started). I air dry all my lumber and you will most always have some kind of problems with a percentage of the wood but that is to be expected. It will all need to be hand picked to meet your needs and if there are defects that wont work for you just continue sizing the material smaller to eliminate the defects until you have a piece that suites your needs. I have cut some nice Red and White Fir saw logs that make all nice boards with no drying problems, so it all has to do with each individual piece of wood you have and trial and error. -- Ron, Twain Harte, Ca. Portable on site Sawmill Service http://westcoastlands.net/Sawmill.html http://westcoastlands.net/SawBucks2/phpBB3 http://www.portablesawmill.info |
#9 posted 1965 days ago |
Everyone Thanks for all the good feedback. I am going to give some of these ideas a try and see what I can come up. I am also going to be takinga pen turning class at the local Woodcrafters next week, so who knows I may just get hooked on that and decide to use the downed wood to make pen blanks, I have pushed around the idea of a chainsaw milling attachment before. CtL -- Chris L. "Don't Dream it, Be it." |
| Forum | Topics |
Woodworking Skill Share
8791 |
Woodturning
220 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
78 |
Finishing
1530 |
3547 |
15768 |
Hand Tools
2034 |
Jigs & Fixtures
495 |
Wood & Lumber
2837 |
808 |
Focus on the Workspace
901 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6157 |
