Is restoration possible? Is it worth it?
« back to Woodturning forum
Forum topic by mike02130 posted 08-01-2016 01:45 PM 1022 views 1 time favorited 10 replies Add to Favorites Watch
View mike02130's profile
mike02130
167 posts in 578 days
08-01-2016 01:45 PM
I just picked up an old leather belt driven lathe. It is missing the motor and pulley. It is made to be used with flat belts. The countershaft(?) is missing. I found a very brief description and pictures on Vintage machinery’s web site. Can this be done or reworked to run? What parts would I need? http://www.vintagemachinery.org/photoindex/detail.aspx?id=14291
The pictures are not of my lathe, it is the same as mine but mine is disassembled.
Thanks,
Mike
-- Google first, search forums second, ask questions later.
10 replies so far
View jwmalone's profile
jwmalone
769 posts in 608 days
#1 posted 08-01-2016 01:53 PM
Not an expert on lathes, but that stuff had very simple designs, an electric motor from anything can be made to fit, belts no problem. There will be guys on here shortly tell you all about it. Looks like a really nice find ive been looking for something like that myself.
-- "Boy you could get more work done it you quit flapping your pie hole" Grandpa
View BigYin's profile
BigYin
406 posts in 2321 days
#2 posted 08-01-2016 02:14 PM
if it has been made it can be made – so the answers yes, it can be restored.
babbit bearings can be recast and scraped to fit
worn shafts can be built up and ground down to dimension
bushes can be turned
ball/roler bearings can have cups turned to fit a loose housing and bushes to fit a loose shaft
-- ... Never Apologise For Being Right ...
View MrRon's profile
MrRon
4632 posts in 3149 days
#3 posted 08-01-2016 10:30 PM
An old lathe like yours is an antique and worthy of restoration. From the picture, it appears that most of what you need is there and looks to be in pretty good shape. It looks heavy which is a good thing in a lathe. You can contact John Knox at 847-384-1146. He custom makes belts for any machine. He is a great person to talk to and his prices are very reasonable. Looks like you will need to mount the jack shaft above the lathe to suit whatever length belt you wish to use. A vee belt pulley at one end of the jack shaft can be fitted to be driven by an electric motor; 3/4 horse would be a good choice.
View MrUnix's profile
MrUnix
6351 posts in 2104 days
#4 posted 08-01-2016 10:36 PM
A motor, pulley, v-belt (motor to countershaft pulley) and serpentine belt (coutershaft pulley to lathe). If you don’t have the countershaft, one can be made from wood if needed. The serpentine belt is used ‘inside out’ in place of a leather belt – something frequently done on old metal lathes like my South Bend.
View Rick_M's profile
Rick_M
11109 posts in 2285 days
#5 posted 08-03-2016 07:20 AM
Before restoring it, ask yourself if you really want to. Restoring old lathes is more a labor of love because very often they are not friendly to the modern turner. They can have oddball threads, oddball tapers, or no threads or no tapers. Yours apparently dates to the 1880’s which means plain bearings that will limit you to low speed turning. I wouldn’t be surprised if the tapers are something other than Morse. Restore it because you love old machines and consider yourself a caretaker that will eventually pass it on. It’s a museum piece not a daily driver. If you are looking for a cheap way to get into woodturning, post it for sale on OWWM and buy something made after about 1950.
http://thewoodknack.blogspot.com/p/how-to-buy-vintage-lathe.html
-- http://thewoodknack.blogspot.com/
View becikeja's profile
becikeja
841 posts in 2718 days
#6 posted 08-03-2016 10:17 AM
I say restore it. I agree, it may not be as effective as the modern machinery, but it will look sharp in the shop.
After all, isn’t part of the wood working hobby simply an excuse to collect tools? And this could be a show piece.
mike02130
#7 posted 08-08-2016 12:37 AM
Thanks guys for all your recommendations and advice. Now that I lugged it out of my driveway and put it together, I realize it’s not the same lathe as in the above pictures.
It seems all there except the motor and belts. I’ll figure something out as far as a counter shaft goes. What about a pulley from the countershaft to the lathe? I guess I just need to keep my out. The tailstock center is tapered. It is smaller than a #2 Morse taper. I’m missing the center for the headstock. The spindle measures 1 1/16 with 10 TPI.
Rick_M
#8 posted 08-09-2016 05:36 AM
The tailstock center is tapered. It is smaller than a #2 Morse taper. I m missing the center for the headstock.
- mike02130
Oh that sucks. Not to doubt you but you sure it isn’t a 1×10?
I read a good tip once, to determine an unknown female machine taper, make a casting of the inside and then measure it. The tailstock taper must be tiny, could be 0MT, if it is Morse.
mike02130
#9 posted 08-11-2016 12:47 PM
Yes, you’re right, It is a 1” spindle with 10 TPI. Here is a picture of the taper next to a Morse #2. Does any one have a line on where to get a motor pulley for this thing?
Thanks,
View canadianchips's profile
canadianchips
2600 posts in 2902 days
#10 posted 08-11-2016 02:58 PM
Old tools are always worth restoring. Keep them from going to scrap.
Try looking for that motor pulley from the “AMISH”. They have resources for this !
If not they will make one for you.
