Router Stacked Rail/Stile Bit Question
Forum topic by jay443 posted 07-31-2016 12:12 AM 739 views 0 times favorited 4 replies Add to Favorites Watch
View jay443's profile
jay443
16 posts in 858 days
07-31-2016 12:12 AM
So, I purchased a stacked Shaker rail/stile set from MLCS and I’ve been trying to figure out how to dial it in. I am using a coping sled to cope the ends. I am finding that no matter how careful I am with the cut that the joint has a few thousands of open space. I am beginning to wonder if the cutters are designed to work this way…perhaps to leave room for glue? I don’t know. Does anyone have suggestions or experience with a stacked set? Thanks.
View MadMark's profile
MadMark
979 posts in 1510 days
#1 posted 07-31-2016 12:41 AM
Step #1: remove all shims
Step #2: invest in a dial indicator or DHG:
Step #3: make sure all your stock is dead-on 0.750”, any error in this measurement is doubled in the joint.
Step #4: use feed hold downs to make sure there is no ‘bouncing’
To align you have to remember the cuts are inverse with the stiles being fed face down & rails face up. So the piece of cutter that was 1/8” (.125”) from the bottom cutting stiles will be 5/8” (.625”) from the bottom cutting rails, assuming dead on 3/4” (.750”) stock.
Mind your reference edges and the setup is a lot easier.
M
View ChefHDAN's profile
ChefHDAN
1070 posts in 2906 days
#2 posted 07-31-2016 02:33 PM
Jay, Mark has the way to get there, I think I got the same set, I think from MLCS… Old age… It was my first shot at using a R&S set and I killed beaucoup stock working to set it up and was PISSED with myself, but after careful adjustment I got it sweet. I took some of the stock that finally was correctly milled and saved a 3” piece of each bit set up and now use them when I do doors.
Sometimes patience is the difference between furniture and firewood LOL
jay443
#3 posted 07-31-2016 02:50 PM
Mark, thank you so much for the tips. I will work on your suggestions and hopefully can get to making some nice-fitting joints.
MadMark
#4 posted 07-31-2016 03:45 PM
I went thru the frustration phase trying to follow the manufacturers instructions to the letter and never getting a correct fit. Once I figured it out, it was obvious! LOL
M
