Resawing Question?
Forum topic by miserybob posted 05-19-2010 03:33 AM 2651 views 0 times favorited 19 replies Add to Favorites Watch
View miserybob's profile
miserybob
88 posts in 3278 days
05-19-2010 03:33 AM
I’ve done very little resawing on my 14” bandsaw, but every time I do, the two pieces bow so badly that they’re practically unusable.
What gives?
Is this:
a) poor technique
b) bad choice of materials
c) totally expected
d) other
Thanks!
19 replies so far
View EricRFP's profile
EricRFP
106 posts in 3327 days
#1 posted 05-19-2010 03:36 AM
Is the wood bowed right after your cut or does it bow over time? If it starts to bow within a few hours or days, your wood is not dry enough.
-- Eric, NorCal www.rocklinforestproducts.com
miserybob
#2 posted 05-19-2010 03:56 AM
It bows immediately. I’ve only used kiln-dried wood, although my storage area is pretty high humidity.
View live4ever's profile
live4ever
983 posts in 3244 days
#3 posted 05-19-2010 04:01 AM
If it happens right away, it’s totally expected. Much depends on the grain orientation of the original board but it’s sort of hard to predict – maybe someone who understands wood science better than me will chime in. The bottom line is a cutting operation like resawing releases a lot of stress in the board. The resawn boards will move as a result of this.
I had a beautiful, beautiful piece of beech laying around that I had been planning to resaw for a special project. It bowed right after I resawed it the other day – approximately a 1/4” bow on a resawn board 3/8” thick. :( Somehow I have a feeling the more beautiful the board the more likely it is to warp after resawing!
117416 posts in 3811 days
#4 posted 05-19-2010 04:29 AM
If the wood bows as you saw it it’s internal stress on the wood and or being to wet. If it bows afterward it’s due to not drying equally on both sides .you also need to make sure your band saw is set up to allow for drift. Also a sharp blade is important.
EricRFP
#5 posted 05-19-2010 04:30 AM
Not to get too much off topic but just because wood was kiln-dried does in no way mean it’s still at 6-8% MC. Why do you use only kiln-dried wood?
miserybob
#6 posted 05-19-2010 04:38 AM
Hi, Eric – I sometimes use air-dried wood (although it’s harder to find, it seems), I just haven’t tried resawing any of it yet. It may well be that my not-so-climate-controlled garage is making my stock moist.
miserybob
#7 posted 05-19-2010 04:40 AM
Jim – is there a way to tell if wood is going to bow (grain pattern, etc)? Are certain kinds of wood (highly figured, or certain species) more apt to warp?
Thanks!
View Bill Davis's profile
Bill Davis
226 posts in 4158 days
#8 posted 05-19-2010 04:48 AM
Sounds to me very much like case hardening. You can test for that before re-sawing by cutting off a smaller piece and bandsawing it a particular way.
#9 posted 05-19-2010 04:52 AM
Bob any wood can have internal stress , if wood is in a stress such as being wind blown and after being sawn it will move to regain it’s original shape
View fussy's profile
fussy
980 posts in 3284 days
#10 posted 05-19-2010 06:27 AM
Bob,
Is the wood bowing, or are you getting what is called a “barrel cut”? Bowing is warping or twisting. In a barrel cut, if you look at it edge-on, one side is curved (CONVEX), and the other side—from the other side of the blade is convex. This is easy to fix. Make certain the saw is set up correctly; ie. the blade tracks in the center of the upper wheel, the table is square to the blade, and upper and lower guides are properly adjusted. If all this is done and you still get a barrel cut, you have a dull blade. They don’t last forever, and even new ones sometimes have problems.
Michael Fortune had a very informative article on bandsaw set up in Fine Woodworking a few years ago. I followed his advice, and now I love my bandsaw. If you’d like, pm me and I’ll e-mail a copy.
Hope this helps,
Steve
#11 posted 05-19-2010 06:30 AM
Interesting fussy do you know what issue?
miserybob
#12 posted 05-19-2010 06:45 AM
Fussy – Yeah, I used that article to setup the saw! It’s in FWW #173, Jim.
The boards come out like closed parens if you’re looking down at them standing on edge, () . I think what you’re describing is when they come out like this: (( ?
The blade is new.
#13 posted 05-19-2010 06:47 AM
Thanks Bob
View bill merritt's profile
bill merritt
203 posts in 3523 days
#14 posted 05-19-2010 06:59 AM
Thanks for that info. now I have to find it.
-- Bill Merritt -Augusta Ga. woodworker
View Dragonsrite's profile
Dragonsrite
136 posts in 3630 days
#15 posted 05-19-2010 07:44 AM
Could the tension be too loose or maybe feeding too fast?
-- Dragonsrite, Minnesota
