72 1/2" bandsaw blade... will 72" work?
Forum topic by Todd Clare posted 05-17-2010 09:25 PM 2785 views 0 times favorited 8 replies Add to Favorites Watch
View Todd Clare's profile
Todd Clare
67 posts in 2916 days
05-17-2010 09:25 PM
Topic tags/keywords: bandsaw
Hi all,
I’ve got an older Delta 10” bandsaw. Inside the door is the diagram of blades, part numbers, and the different radii the different blade widths can cut. On that sticker it says they are 72 1/2” blades.
Now everywhere I look, I see 72” blades (conceptually 1/2” short)... I’m wondering if those will work or if i really need to chase down 72 1/2”?
In my (simplistic) mind, a 1/2” shorter blade would still work, I would just have more tension at a lower setting than with the slightly longer blade. Of course my simplistic mind also doesn’t want its not so simplistic fingers cut off, so I thought I’d poll the group.
-- Todd (Denver, CO -- Highlands)
8 replies so far
View TheDane's profile
5384 posts in 3594 days
#1 posted 05-17-2010 09:31 PM
72” blades would probably work okay … you would just lose some of the range of your tension adjustment.
View Michael Murphy's profile
Michael Murphy
453 posts in 2936 days
#2 posted 05-17-2010 09:36 PM
It probably depends on how much adjustment you have in the upper wheel tensioning. My Powermatic 14” can use from 95 down to about 93 1/2. the smaller limit is pretty tight and you have to kind of work it on there. If you have 3/4 ” of travel or so on the tensioner then your lower limit is around 71” I would guess.
-- Michael Murphy, Woodland, CA.
View SCOTSMAN's profile
5851 posts in 3516 days
#3 posted 05-17-2010 09:37 PM
I agree with that too Lombardi.If you don’t have a spare half inch of tension in your machine free then there is a badly designed bandsaw.I figure you will be fine however.Alistair
16273 posts in 4149 days
#4 posted 05-17-2010 09:46 PM
I cannot imagine it being a problem.
View richgreer's profile
4541 posts in 3005 days
#5 posted 05-18-2010 12:16 AM
I can state as an absolute fact that if your saw requires a 137” blade and you make a mistake and buy a 133” blade you will never get it on. For me, another lesson from the school of hard knocks.
I don’t think this is particularly relevant to the question at hand where the discrepancy is 1/2” instead of 4”.
Michael Murphy
#6 posted 05-18-2010 12:55 AM
I keep my Blade stretcher on the shelf with the Lumber stretcher and skyhooks. I use my left handed frying pan in the kitchen.
View jim C's profile
jim C
1472 posts in 3029 days
#7 posted 05-18-2010 01:17 AM
Just for reference, I have a Jet 12” bandsaw and it uses a 82-!/2” blade. There are a lot of 80” blades available, but not a chance they will fit. A 1/2” difference may work, but any more than that probably won’t.
Give it a try and let us know.
View Reuben's profile
4 posts in 2864 days
#8 posted 05-19-2010 08:09 AM
You only need a 1/4” travel in your adjuster to accommodate a 1/2” shorter blade. The missing half inch in blade length is split between the up-going and down-going sides. Unless you’re completely out of travel, it’ll fit fine.
