10" Table saw blade with flat top
Forum topic by Dee1 posted 07-27-2016 02:51 PM 4582 views 1 time favorited 17 replies Add to Favorites Watch
View Dee1's profile
Dee1
294 posts in 1854 days
07-27-2016 02:51 PM
Any of you guys have a favorite 10” blade with a flat top. I have been looking for one for a while with 0 results
Forrest makes one that is very close to flat. but just close.
Thanks
Dee1
17 replies so far
View HerbC's profile
HerbC
1743 posts in 2824 days
#1 posted 07-27-2016 03:01 PM
I like this blade by Kempston.
It is true FTG grind which produces a flat bottom cut.
And it’s only $33 from Amazon Prime.
Good Luck!
Be Careful.
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
View Dutchy's profile
Dutchy
2850 posts in 2133 days
#2 posted 07-27-2016 03:01 PM
A rip cut saw blade should be flat.
-- https://dutchypatterns.com/
View splintergroup's profile
splintergroup
1979 posts in 1187 days
#3 posted 07-27-2016 03:15 PM
I have a Freud rip blade that was part of a three blade set. Nice 1/8” wide flat bottom grooves.
For excellent dead-flat bottom grooves also look to some of the ‘box joint’ blade sets (I also have the Freud brand).
The usually are set to make either 3/8” wide of 1/4” wide cuts when the blades are used in pairs. Singly they are about 3/16”, but I have never measured to confirm.
View joey502's profile
joey502
525 posts in 1482 days
#4 posted 07-27-2016 03:16 PM
I have a freud industrial 24 tooth rip blade that leaves a flat bottom cut. I think it was about $40 – 45
View xeddog's profile
xeddog
182 posts in 2972 days
#5 posted 07-27-2016 04:07 PM
I have a Forrest WW2 with their #1 grind. I would have to go get it, but if I remember correctly it is essentially a TCG grind with the tops all leveled out and flattened. It cuts cleanly and leaves a flat bottomed kerf.
Wayne
View ShaneA's profile
ShaneA
6909 posts in 2563 days
#6 posted 07-27-2016 04:17 PM
I have a Freud 24 Tooth FTG Rip blade that produces flat bottoms, and I also have the Forrest WWII 40 Tooth with the special “flat” grind. While it is pretty flat, mine is not perfectly flat like the rip blade produces.
4951 posts in 2458 days
#7 posted 07-27-2016 04:32 PM
It’s my understanding that Forrest can/will grind one for you that way, but it’s special order. No idea what that might cost, but I have one on my “dream” list.
View DirtyMike's profile
DirtyMike
637 posts in 866 days
#8 posted 07-27-2016 07:08 PM
freud all the wall
View Scott C.'s profile
Scott C.
158 posts in 2016 days
#9 posted 07-27-2016 11:15 PM
I was recently looking for a FTG 10” blade. After a lot of searching, I found the Freud LU87R010 was the least expensive, true FTG I could find. Not all ripping blades are FTG, especially the cheaper ones.
https://www.amazon.com/gp/product/B0000225UH/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
-- measure twice, cut once, swear and start over.
View knotscott's profile
knotscott
7980 posts in 3340 days
#10 posted 07-28-2016 09:44 AM
Any of the flat top grind (FTG) blades should be fine. Infinity 010-024/124, Forrest, Ridge Carbide, Freud Industrial LU87/LM72, CMT Industrial 201.024.10/202.024.10, Amana Tool RB1020, Delta Industrial and DeWalt Precision Trim all have them in a rip blade configuration – range is 18T to 24T.
View rwe2156's profile
rwe2156
2881 posts in 1445 days
#11 posted 07-28-2016 12:06 PM
Freud industrial (the chrome one) best rip blade I’ve used. LM74M010
or
CMT 24 tooth
View RandyinFlorida's profile
RandyinFlorida
248 posts in 2032 days
#12 posted 07-28-2016 01:53 PM
Lowes Irwin Marples 50T ATB-R. I had to order it ($39.98) and have it delivered to my local Lowes. I have used it several times to make box joints. Does a fine job. Every third tooth is flat so it flattens the bottom. And being a Marples, made in Italy (I think), its a higher quality than the standard Irwin products. I had to go to IRWIN.com to research it’s capabilities. They have a 60 tooth version also. Also that “ATB+R” identifies any blade as flat.
-- Randy in Crestview Florida, Wood Rocks!
View BenjaminNY's profile
BenjaminNY
128 posts in 1367 days
#13 posted 07-28-2016 02:02 PM
http://www.infinitytools.com/sawing/table-saw/table-saw-blades/ripping-saw-blades/10-ripping-saw-blade-24t-125-kerf
This is the one I use. Works very well for making flat bottom grooves. Think Infinity charges about 50 bucks for it.
knotscott
#14 posted 07-28-2016 06:26 PM
Lowes Irwin Marples 50T ATB-R. I had to order it ($39.98) and have it delivered to my local Lowes. I have used it several times to make box joints. Does a fine job. Every third tooth is flat so it flattens the bottom. And being a Marples, made in Italy (I think), its a higher quality than the standard Irwin products. I had to go to IRWIN.com to research it s capabilities. They have a 60 tooth version also. Also that “ATB+R” identifies any blade as flat.
- RandyinFlorida
Because the non-raker bevel top teeth protrude slightly above the flat rakers, ATB/R grinds aren’t truly flat….they’re only “flatter”. Only an FTG (flat top grind) will leave a truly flat bottom.
knotscott
#15 posted 07-28-2016 06:30 PM
Freud industrial (the chrome one) best rip blade I ve used. LM74M010
- rwe2156
LM74 and LM75 are TCG grinds and aren’t truly flat either.
