| Forum topic by itsme_timd | posted 687 days ago | 3140 views | 0 times favorited | 20 replies | ![]() |
687 days ago |
Topic tags/keywords: question router Hi All, I’m looking to upgrade my router soon and am looking at a Milwaukee 5616-20. It has pretty good reviews and I know Milwaukee to be great tools – I worked for them for a few years. I know there are many features, brands and price points on any tool so I’m making sure I maximize my money. Right now I see my main use as making dovetails and also basic profiles. Any info is appreciated! -- Tim D. - Woodstock, GA |
687 days ago |
Tim, Regards, PS-I have 5 different routers-use them all and like them all! -- Gerry |
687 days ago |
I got the PC with 2 interchangable bases. That way I can leave the fixed base in my router table and still use the plunge base, separately. I leave the fixed base attached to my table and when I need to use my table, I just screw the motor to the affixed base. The Milwaukee with both bases got real good evaluations in the testing of different woodworking magazines, so I think you would be real happy with their twin base unit. The twin base unit is like getting two routers for the price of one. God Bless, -- Saving barnwood from the scrapyards |
687 days ago |
On your main question, it depends upon how you use one. For most people a fixed base unit is probably the way to go. Dovetails and other edge treatments do not require plunge capabilities, so you can stick with the shorter/better balanced fixed base. Plunge routers work well in joinery work and other application where the cuts are in the middle of the work piece. They can do edge work too, of course, but are taller and less stable out there. This is why many companies sell the combo kits with both bases. “Theoretically” this is the best of both worlds…and for a home hobbiest, it might be. For the more serious, the professional, or the tool junkie, seperate complete units are more convenient. Your second point, The Milwaukee is an excellent router and a very well designed product as a whole. The case is genious. You can put the router back on the clamshell’s base right-side-up with the bit still adjusted to where you were using it. The collet wrenches are great.They are solid forged pieces, that sit in a molded pocket in the case. There are even a few holes that will hold 1/2” shank router bits, right there in the base plate of the case. The body-grip and strap are really great, especially for edge work. The first one of these I bought was the 1 3/4 hp version, though I am considering another in the larger rating. I already have several routers but for most jobs this one is my pick. |
686 days ago |
Tim, try this site when you decide on a router and want to buy one: Toolking Anyway, I hope that helps. The Milwaukee looks like a dandy router that should give you years of service and could then be passed down to your children. God Bless, -- Saving barnwood from the scrapyards |
686 days ago |
Thanks a lot for the info, you guys are always a huge help when I have questions! -- Tim D. - Woodstock, GA |
682 days ago |
I have both plunge and fixed base routers. I find that I use my plunge like a fixed base and am more finicky about setting router bit depth so I like the fixed base concept. As mentioned earlier, if you have to cut circles/elipses/curves or joinery where the router will be sitting in a jig on the workpiece, a plunge router is really the right tool for that job. The multi based systems are nice, but with routers, you may find as many do that a stable of them is of great convenience. Have a couple of fixed base 1 3/4HP…especially for dovetail jits and edge treaments, a couple of plunge in the 2HP range for joinery..nice to have the power when plunging for morises, a fixed base permanetly mounted in a table in the 3 1/2 HP range because you’ll want to spin a panel raising bit a some point, a trim router because they are easy to handle and wonderful for edge trimming and flushing pieces, and a portable router with a plunger that can go in it when using multiple bits sequentially is a great setup. I’m no minimalist though and if I was, one of the mixed kits would do you great. -- You can discover more about a person in an hour of play than in a year of conversation. (Plato) |
682 days ago |
My suggestion from personal experience, I’d go with the dewalt that has both a plunge and fixed base. Dewalt bought PC and Delta a couple of years ago. So that technology goes into there routers now, I’m not sure but they may be made at the same plant. The Dewalt comes with a built in dust vac system on the plunge base, which makes a huge difference with routers. -- Joey, Magee, Ms http://woodnwaresms.com |
682 days ago |
I have a dual base Bosch in my table. It has taken a beating and the few times I’ve used it out of the table it has been a joy to use. I also have a 3.5 horse Makita plunge, a fixed base Miwaulkee, another fixed base Makita, a Bosch Colt, there’s even a 1/4 inch Craftsman and a router base for the Dremel tool. I like the Bosch and the price was right. -- Thos. Angle |
681 days ago |
Well I ended up buying a Porter Cable 9690LR, haven’t had a chance to try it out yet. It’s a fixed-base model but I can buy a plunge kit for it as well, which I’ll probably do soon. Another nice bonus with this router… HD had a special going where I got a 5 1/2 RO sander free, also Porter Cable. -- Tim D. - Woodstock, GA |
681 days ago |
Here is a Combo Router Review for basic information on a few. I personally have 4 (and need 3 or 4 more) routers. I have a Milwaukee single speed fixed router and it is limited to edge trimming due to the single speed. I have a Hitachi vairable speed 1 3/4 hp fixed based router used mainly for dovetails a Ryobi variable speed plunge router for mortises and a 3 1/4 hp variable speed plunge router for raised panels. From now on all of the router I purchase will be 3 hp or bigger, variable speed plunge routers because when it gets to a point where one person only wants 1 router to do all of their routering , I want to be knowlegable about all of the Big Names to give an educated opinion. At this time I would recommend the 3 1/4 variable speed plunge router by Hitachi. All the others have limitations and for the all around router you need one that will do everything. (Just an opinion) |
681 days ago |
I have the 1 3/4 hp version and I love it! The only thing I regret is I bought it when they first came out and I wish I waited. Now they sell a multi base kit which is the same router with a plunge base also. I would recommend that set. Porter-Cable also makes a similar two base kit but I love the ergo hand grip on the Milwaukee! I hear the PC has good dust collection features though. -- David, South Windsor, CT "I love the smell of sawdust in the morning" |
680 days ago |
There must be a reason that only plunge routers are allowed to be sold in Europe. Regards Jerry -- jerry,mlchigan |
680 days ago |
680 days ago |
I have 6 or 7 routers and only one of them is a plunge router. It very rarely gets used. I have one combo set but I have never even taken the plunge base out of the case. Not that it matters but all of them are PC’s. -- Gary, East TX -- The longest journey begins with a single step. |
680 days ago |
Thanks again for the input. I think the fixed-base PC will serve me well for now and I’ll add the plunge base when the need arises. I am curious as to why they would only allow plunge routers to be sold in Europe??? I could see them being preferred over fixed-base units but I wonder what the reason for ‘outlawing’ them is? -- Tim D. - Woodstock, GA |
680 days ago |
Probably a CE safety thing in europe. The cutter always being exposed. They have some, IMO, extreem safety things, like a tablesaw blade being required to stop within 10 seconds No Stacked dado blades allowed either. Go Figure. -- Gary, East TX -- The longest journey begins with a single step. |
677 days ago |
One more question… The router I bought (PC 9690LR) is a 1 3/4 HP model. I have a router tips book that says you should get at least a 3 HP model. Does anyone else have any input on this? Will I notice a HUGE performance difference if I upgrade? -- Tim D. - Woodstock, GA |
677 days ago |
Unless you are using very large cutters you shouldn’t notice any difference. I do most of my work with a 690. I have even cut panels with a large raised panel bit with it. Just ran it slow. You will also pay 2-3 time the price. -- Gary, East TX -- The longest journey begins with a single step. |
677 days ago |
I have a DeWalt that has the fixed and plunge base and is 1 3/4 hp. It works just fine for my needs. Like Gary said, the 3 hp would be for large cutters, and probably in a router table. You should be pleased with your router as is. -- Bill, Turlock California, http://www.brookswoodworks.com |
677 days ago |
That’s what I was hoping to hear! Thanks. -- Tim D. - Woodstock, GA |
| Forum | Topics |
Woodworking Skill Share
2810 |
3771 |
246 |
895 |
211 |
Woodworking Trade & Swap
593 |
Coffee Lounge
2277 |
LumberJocks.com Site Feedback
505 |
