Forum topic by hObOmOnk posted 05-16-2010 09:36 PM 2276 views 0 times favorited 48 replies Add to Favorites Watch
View hObOmOnk's profile
hObOmOnk
1381 posts in 4125 days
05-16-2010 09:36 PM
-- 温故知新
48 replies so far
View trimmer's profile
trimmer
90 posts in 3438 days
#1 posted 05-17-2010 03:30 AM
a.
View DaleM's profile
DaleM
958 posts in 3381 days
#2 posted 05-17-2010 03:45 AM
C. 1.66 lbs.
-- Dale Manning, Carthage, NY
27250 posts in 3819 days
#3 posted 05-17-2010 03:52 AM
I am with Dale.
TopamaxSurvivor
18269 posts in 3673 days
#4 posted 05-17-2010 05:39 AM
a
View DrB's profile
DrB
16 posts in 3291 days
#5 posted 05-17-2010 01:23 PM
C
-- Something like a swiss army knife..that's my life. JB
View Dan Lyke's profile
Dan Lyke
1520 posts in 4122 days
#6 posted 05-17-2010 02:37 PM
C
hObOmOnk
#7 posted 05-18-2010 12:47 AM
The answer is, of course:
C. 1.66 lbs.
-- 温故知新
TopamaxSurvivor
#8 posted 05-18-2010 02:34 AM
I would have said, 1.6 #, but I do not know how much the dry shellac changes the weight of the liquid as it dissolves since I have never done it. If a pint is a pound the world around, the answer shouldn’t be 1.66 ;-)) But I don’t know the weight of a gallon of alcohol.
View Sawdust4Blood's profile
Sawdust4Blood
404 posts in 3019 days
#9 posted 05-18-2010 02:58 AM
a 2 lb cut is by definition 2 lbs of shellac in a gallon of alcohol. However, the mass of the shellac would displace some of the alcohol in a 1 gallon container. Therefore, if then end result of the mixture is a ratio equivalent to a 2 lb cut in a 1 gal container, then the original weight of the shellac would have to be a number less than 2 (though probably not all the way down to 1 lb). I don’t know the weight per gallon of alcohol or the displacement value of shellac in alcohol to say what the exact number is…I’m good with 1.6
-- Greg, Severn MD
Dan Lyke
#10 posted 05-18-2010 03:04 AM
Since it’s been a day or so and people are asking for spoilers:
WARNING: SPOILERS
It’s not the weight of the alcohol, it’s the volume of the shellac. A 2lb cut means that 2lbs of shellac flakes have been added to 1 gallon of alcohol. The only way the resulting solution would have 2 lbs of flakes in a gallon is if the flakes were infinitely heavy and thus took no room (I’m no chemist, but there may be things in full solution that do this).
So, falling back on our high school SAT test options, we know the answer is less than 2, so it’s not A or B. D seems unlikely, whence my C guess.
Working backwards from that, now we want to find the volumes of shellac flakes and alcohol in the final solution. If we take 1 gallon of the final solution of a gallon plus 2 lbs of shellac flakes we end up with .83 of the shellac flakes, so we end up with .83 of a gallon of alcohol, and .17 of a gallon of shellac flakes.
If the answer is correct, this also means that 2 lbs of shellac flakes occupies 0.2125 gallons of space, or about 9.4 lbs/gallon (weighing a gallon of flakes will give you a much lower number because of packing).
Unless I made some boneheaded arithmetic error somewhere up there.
And the net assures me that alcohol is about 6.5lbs/gal, although that doesn’t really come into this problem. But that would explain why you need to stir your shellac before you use it.
END OF SPOILERS
TopamaxSurvivor
#11 posted 05-18-2010 03:36 AM
I’m no chemist either and I have never made my own shellac. As it disolves, does the volume of the liquid increase? If it does not increase, then the answer would be 2 and the total weight of a gallon of 2# shellac would be aproximately 8.5 #.
Bullseye Shellac says their 2# cut is 7.25 pounds per gallon. Therefore, it appears the correct anwser is some where in the neighborhood of 1.8 # of shellac in a gallon which is slightly closer to 1.66 than it is to 2 ;-))
TopamaxSurvivor
#12 posted 05-18-2010 04:45 AM
We are all shellacked in unknowns ;-))
hObOmOnk
#13 posted 05-18-2010 05:15 PM
Many thanks…
-- 温故知新
View PurpLev's profile
PurpLev
8535 posts in 3646 days
#14 posted 05-18-2010 05:33 PM
A 2 pound cut shellac formula is 2 pound shellac flakes per 1 gallon of alcohol.
The resulting mixture is more than 1 gallon in volume (since it’s 1 gallon of alcohol + the shellac flakes), and thus if you take 1 gallon of the total mixture to fit into a 1 gallon container, you’ll be left with slightly less than 2lbs shellac in the container but not so much that it’s half (1lbs). therefor the 1.66 would be the closest answer, but may not be exactly precise.
TopamaxSurvivor
#15 posted 05-18-2010 11:52 PM
hobomonk, Why did you add the last .06 on 1.6 in the original question?
showing 1 through 15 of 48 replies
