Craftsman 113 Table Saw - Need new motor
Forum topic by Ardubya posted 07-26-2016 07:43 PM 2904 views 0 times favorited 10 replies Add to Favorites Watch
View Ardubya's profile
Ardubya
53 posts in 1228 days
07-26-2016 07:43 PM
Topic tags/keywords: tablesaw table saw craftsman 113
Anyone out there own a Craftsman 113 table saw and had to replace the motor? I’m getting conflicting information and could use some advice.
The motor that came with the saw (circa 1987) appears to have given up the ghost. Since I have to replace it, I thought I might as well upgrade to a 2 or even 3 hp. I’m told these Craftsman saws can handle up to 5 hp but that just makes me a little uncomfortable. Not sure I need that kind of hp anyway.
So I’m looking for a new motor, finding several reasonable options on Ebay, but I’m concerned about compatibility, not just in power and RPMs, but the simple mounting of the motor.
Anyone have a suggestion on what I should be looking for?
Thanks.
10 replies so far
View WhyMe's profile
WhyMe
1034 posts in 1644 days
#1 posted 07-26-2016 08:06 PM
Get a motor of the same HP and RPMs and shaft size and frame. I know, easy for me to say. Have you checked the capacitor?
View Chas7715's profile
Chas7715
38 posts in 970 days
#2 posted 07-26-2016 08:10 PM
I haven’t replaced the motor on my series 113 table saw but I did have to replace a motor on my Porter Cable band saw. Check out Grizzly. They have a crap ton of motor options.
-- Perfection is highly overrated!
View TMGStudioFurniture's profile
TMGStudioFurniture
55 posts in 902 days
#3 posted 07-26-2016 08:11 PM
Have you checked to make sure the capacitor on your motor is good? That could be an easy fix – much easier than replacing the whole motor.
-- https://www.etsy.com/shop/TMGStudioFurniture
View Woodbum's profile
Woodbum
819 posts in 3149 days
#4 posted 07-26-2016 08:22 PM
My ‘86 Craftsman TS motor finally gave it up in ‘09. I bought an exact match for it from Grizzly when I bought my 1023 TS. I sold the Craftsman saw with the new motor and the guy that bought it was happy with it.
-- "Now I'm just another old guy wearing funny clothes"
View MadMark's profile
MadMark
979 posts in 1536 days
#5 posted 07-26-2016 08:36 PM
Frame sizes are standardized as NEMA numbers. All motors with the same frame # are identical mount even if RPM, voltage, etc. are different. Grizzly, mcmaster.com, Grainger etc will have compatible motors. This would be a great time to upgrade to 220vac.
M
View MrUnix's profile
MrUnix
6845 posts in 2282 days
#6 posted 07-26-2016 09:56 PM
Unless you let the magic smoke out of the motor, it’s probably a simple and cheap fix – but more info is needed other than just “given up the ghost”. Since you have already written it off, you might as well see if you can fix it – certainly won’t hurt and you may be pleasantly surprised.
WhyMe
#7 posted 07-26-2016 11:32 PM
M
- MadMark
And while you’re at it, upgrade to an 8 track tape player. 220V is no longer available. It’s now 240V. :)
View TheFridge's profile
TheFridge
9857 posts in 1569 days
#8 posted 07-26-2016 11:54 PM
Grainger is expensive
View MikesProjects's profile
MikesProjects
172 posts in 1985 days
#9 posted 07-27-2016 08:19 AM
Grizzly G2535 1.5 hp Single-Phase Motor with 3450 RPM read the reviews here…
https://www.amazon.com/Grizzly-G2535-Single-Phase-Motor-3450/dp/B00DQJOZ94
more on this subject here at lumberjocks
http://lumberjocks.com/topics/69777
http://lumberjocks.com/topics/61057
http://lumberjocks.com/topics/40888
http://lumberjocks.com/topics/90298
-- -Mike, Southern California, YouTube User ( Give & Take )
View knotscott's profile
knotscott
8100 posts in 3459 days
#10 posted 07-27-2016 09:36 AM
Whoever told you they could handle up to 5hp is taking a wild guess, and adding risk. I suppose it depends on how you define the word “handle”. Even 3hp will push every limit of the saws support structure, pulleys, arbor, etc. They’d work for a while, but it would sure increase the chances of complications from the added weight and torque. Going with an original 1hp to 1.5hp is prudent. The most I’d consider is 2hp. Anything more will require 220v (aka 240v) supply.
