Boiled Linseed Oil and Polyurethane
Forum topic by monkeyman83 posted 07-26-2016 05:22 PM 6795 views 1 time favorited 18 replies Add to Favorites Watch
View monkeyman83's profile
monkeyman83
34 posts in 2205 days
07-26-2016 05:22 PM
Topic tags/keywords: question finishing
I have a question for anyone who can answer it out there. I love using boiled linseed oil as it really enriches the color of the wood in my opinion. My question is, though, is can I apply polyurethane over the top of boiled linseed oil? Thanks for the help.
-- It may not be pretty...but it's functional.
18 replies so far
View Kirk650's profile
Kirk650
524 posts in 713 days
#1 posted 07-26-2016 05:57 PM
I’d be more inclined to pop the grain with Minwax Antique Oil or Watco Danish Oil, rather than BLO.
View joey502's profile
joey502
525 posts in 1482 days
#2 posted 07-26-2016 06:01 PM
I have used that finish, boiled linseed oil underneath oil based polyurethane, many times without issue. I usually thin the polyurethane 50/50 with mineral spirits. I have never had an issue
View TheTurtleCarpenter's profile
TheTurtleCarpenter
1032 posts in 1030 days
#3 posted 07-26-2016 06:23 PM
Yes; The base to oil finishes is BLO, it is a binder for solids and pigments and creates flow. Polyurethanes and varnishes have Blo in them to dilute and make the finish flow out. Finishes also have thinners, (carriers) to reduce and extend drying times as in regular poly and quick drying polys.
You can change the way stains take by thinning Blo down and applying before staining. If you are unsure always do some test peices first.
-- "Tying shoelaces was way harder than learning to Whistle",,,,,member MWTCA area K. Kentucky
View Jon Hobbs's profile
Jon Hobbs
147 posts in 669 days
#4 posted 07-26-2016 06:25 PM
Here’s a finish that I learned from a guy with 50 years professional experience:
Wipe/rub on the boiled linseed oil
Immediately wipe on dewaxed shellac
The oil will do its enriching thing that it does so well. The shellac dries the oil almost immediately and adds a tiny bit of toughness. Quick, easy, almost foolproof.
I’ve followed up with several coats of Minwax wipe-on poly with good effect on surfaces that are high wear (e.g. table tops). I hit surfaces that don’t see much wear and tear with some furniture wax.
-- Jon -- Just a Minnesota kid hanging out in Kansas
4951 posts in 2457 days
#5 posted 07-26-2016 06:35 PM
If you let the BLO set up enough, there won’t be any problem. That should take at least a day, and maybe more.
View Bill White's profile
Bill White
4902 posts in 3924 days
#6 posted 07-26-2016 06:58 PM
Once you get past MinWax products, you’ll have better results.
Bill
-- bill@magraphics.us
View jwmalone's profile
jwmalone
769 posts in 666 days
#7 posted 07-26-2016 07:03 PM
I use that technique fairly often works well.
-- "Boy you could get more work done it you quit flapping your pie hole" Grandpa
View TMGStudioFurniture's profile
TMGStudioFurniture
55 posts in 783 days
#8 posted 07-26-2016 08:10 PM
I’m pretty sure Watco Danish Oil is exactly that, a blend of BLO and polyurethane.
-- https://www.etsy.com/shop/TMGStudioFurniture
View OSU55's profile
OSU55
1630 posts in 1954 days
#9 posted 07-27-2016 01:13 AM
Yes you can but there really isn’t a need for blo. Here is some info on oils and varnishes. I find MW poly works just fine. Tested others, don’t see a discernible difference. I actually like it better than the non poly varnish Sherwin Williams has.
View Mojo1's profile
Mojo1
265 posts in 2654 days
#10 posted 07-27-2016 11:16 AM
Once you get past MinWax products, you ll have better results.
Bill
- Bill White
Can you elaborate on this?
View tomsteve's profile
tomsteve
771 posts in 1183 days
#11 posted 07-27-2016 01:58 PM
BLO thinned about 25% with mineral spirits, let dry for aday or 2, the topcoated with poly is one of my favorites and great results even with minwax poly.
View OggieOglethorpe's profile
OggieOglethorpe
1276 posts in 2074 days
#12 posted 07-27-2016 03:22 PM
I do similar, all in one step, mixing 33% each of BLO, Sealcoat, and Pine Turpentine. Do NOT substitute paint thinner, “turps”, or any other similar solvent.
Keep it in a squeeze bottle and keep shaking to keep it mixed. Wipe it on, wipe it off, move on in just a few hours with solvent or oil clears.
I also use this under water based finishes on certain woods with fantastic results, letting it dry over night.
View Jim Finn's profile
Jim Finn
2647 posts in 2886 days
#13 posted 07-28-2016 12:55 AM
Yes you can but there really isn t a need for blo. Here is some info on oils and varnishes. I find MW poly works just fine. Tested others, don t see a discernible difference. I actually like it better than the non poly varnish Sherwin Williams has.
- OSU55
OSU55 Thanks for that link. I learned a lot about wipe on finishes there.
-- Website is https://craftingcouple.com/
View ChefHDAN's profile
ChefHDAN
1057 posts in 2814 days
#14 posted 07-28-2016 08:59 PM
I’ve also had success with WB poly over BLO, usually give the piece 3 or 4 days to dry well then use my HF HVLP gun to shoot light coats, then once the poly cures a light rub with 0000 SW and a coat of johnsons paste wax. It’s a good looking finsh that stands up to having kids, especially girls and the dammned nail polish
View blackcherry's profile
blackcherry
3337 posts in 3787 days
#15 posted 07-29-2016 12:42 AM
Here my favorite hand rub finish
1/3 blo
1/3 wood filler
1/3 fast drying varnish
Mix ingredients to a paste consistency
Apply with terry cloth , let set than buff off.
Any one hear of Harding furniture it one of their case good finishes.
This finish has a satin soft look and very smooth to the touch.
Let’s keep it our secret, cat out the bag, haha.
