Coping saw defective?
« back to Hand Tools forum
Forum topic by jimmy J posted 07-26-2016 05:21 PM 533 views 0 times favorited 3 replies Add to Favorites Watch
View jimmy J's profile
jimmy J
229 posts in 2554 days
07-26-2016 05:21 PM
Just received a new Olson coping saw and am wondering if it is defective and worth returning/exchanging. When viewed from the blade side with the C shaped frame behind it, the blade and support are not parallel. It seems the frame is not really straight. The blade of course is straight since it’s just stretched between 2 points.
Is this a big deal? This is my first coping saw. Seems that I could adjust my saw stroke to compensate, but that’s probably not a good answer.
3 replies so far
View waho6o9's profile
waho6o9
8482 posts in 2751 days
#1 posted 07-26-2016 05:45 PM
Hence the Knew Concept Coping Saw.
I haven’t purchased one but my coping saws aren’t that great as well.
It must be nice cutting without compensating.
View ColonelTravis's profile
ColonelTravis
1917 posts in 2069 days
#2 posted 07-26-2016 05:50 PM
The Knew saw is worth the money. I held off for a long time thinking it wasn’t. If you’re gonna use one of these things a lot, buy it.
View Mark Shymanski's profile
Mark Shymanski
5623 posts in 3887 days
#3 posted 07-26-2016 06:40 PM
How ‘not straight’ is it? Is it visibly kinked, in which case I would return it, if it is the sort of thing you have to put a straight edge up against I maybe wouldn’t worry about it. How does it cut?
