| Forum topic by USCJeff | posted 258 days ago | 564 views | 1 time favorited | 6 replies | ![]() |
258 days ago |
Dock posed a question within one of my projects that had a custom inlay. He was wondering about the method I used. Here’s my reply if anyone else is curious how to do this. It is really very simple and IMO, adds a ton to otherwise plain projects. My method is based off of a couple podcasts. One is from Woodworking Online. Here is the episode Router Inlays same method is used in a Marc’s WoodWhisperer podcasts. Check his archives for the episode. A router inlay kit consists of a guide bushing, a bearing, and a bit. I bought a CMT kit around $30. The included bit is a 1/8” spiral bit. ~The first step is to cut a template for the design. The material must be 1/4” thick. The goal is to cut away the desired design. It is helpful to leave several inches around the hole that is the design. This helps to balance the router when using the template. This will leave a near perfect fit, with the only exception being details that are more narrow than the 1/8” bit. A little minor chisel work takes care of those. Another helpful pointer is to chamfer the bottom of the inlay material slightly so as to ease installation. I like to make the inlay slightly thicker and then sand it flush. -- Jeff, South Carolina |
