LVLP and Minwax Helmsman Spar Urethane
Forum topic by jhillyer posted 07-26-2016 02:38 AM 1140 views 0 times favorited 7 replies Add to Favorites Watch
View jhillyer's profile
jhillyer
8 posts in 2749 days
07-26-2016 02:38 AM
Topic tags/keywords: lvlp spar urethane
does anyone have any experience spraying Minwax Helmsman Spar Urethane? i am not spraying a large area, just small signs. i use the Spar Urethane cause is leave a nice glossy finish and lasts in the weather. i know they have the spray cans of this, but it is expensive when you spray a lot of signs, (just not at once) it is cheaper to buy it by the gallon, i currently brush it one but it is a pain sometimes and i was wondering about switching over to LVLP. any thoughts? i don’t need a real thick coat cause it is not going to be in the water just outside.
-- Jason Hillyer, Decatur IL
7 replies so far
View bondogaposis's profile
bondogaposis
4842 posts in 2408 days
#1 posted 07-26-2016 03:25 AM
Urethane is not a good choice for outdoor use and Helmsman is not the best brand. I’ve had a lot better luck w/ Mcloskey’s Man O War varnish for outdoor applications.
-- Bondo Gaposis
View jwmalone's profile
jwmalone
769 posts in 759 days
#2 posted 07-26-2016 05:30 AM
I have spayed lots of helmsman with a hvlp no problems but if your only doing one or 2 signs at a time, the set up and clean up is not worth it, properly cleaning you’re hvlp is time consuming and you need lots of thinner or kerosene. much faster to brush. What you need is a bunch of cheap throw away foam brushes or even chip brushes 50 cents apiece nice finish on those small signs throw em out when you’re done, trust me been doing it a long time.
-- "Boy you could get more work done it you quit flapping your pie hole" Grandpa
View AlaskaGuy's profile
AlaskaGuy
4255 posts in 2366 days
#3 posted 07-26-2016 06:23 AM
Urethane is not a good choice for outdoor use and Helmsman is not the best brand. I ve had a lot better luck w/ Mcloskey s Man O War varnish for outdoor applications.
- bondogaposis
What he said.
http://www.askhlm.com/Articles/ArticleViewPage/tabid/75/ArticleId/1/Marine-Varnish.aspx
5018 posts in 2550 days
#4 posted 07-26-2016 11:51 AM
If you’re selling those to customers, consider using something else.
View OSU55's profile
OSU55
1739 posts in 2046 days
#5 posted 07-26-2016 11:53 AM
You might look into waterbased finishes developed for exterior use. One is Target Coatings EM9300. They spray well, almost no smell, and dry (not cure) more quickly than solvent based varnishes. Another option is exterior house paint with no pigment. I think it’s the higher “base” numbers that will dry clear.
Using water based, spray guns are easy to clean – warm/hot water and maybe some DNA and things are clean.
View splintergroup's profile
splintergroup
2155 posts in 1279 days
#6 posted 07-26-2016 03:25 PM
Epifanes varnish (Amazon or jamestowndistributors.com).
The longest lasting non-paint finish I have found for outdoors (even is doing better than some west systems epoxy).
jhillyer
#7 posted 07-28-2016 01:29 PM
Thanks everyone, I think i will try to find a different product. does anyone have any luck with some Water based outdoor finish (clear gloss)?
