Forum topic by dmoney | posted 05-16-2010 01:06 AM | 2244 views | 0 times favorited | 21 replies | ![]() |
Topic tags/keywords: question biscuit joiner ok there are 4 reviews of biscuit joiners in the review section but I know there are probably more out there. I think I might really use one for miters and tabletop making, do you guys use yours a lot? Is the porter-cable 557 the best in the home workshop price range? what do you guys think? -- Derek, Iowa |
21 replies so far
#1 posted 05-16-2010 01:29 AM |
My opinion on biscuit joiners has changed over the years. I used to use one a lot, but now I only use it in certain situations. I’m convinced that if you are gluing up boards side to side and you have good clean, flat surfaces a biscuit adds no additional strength. This would apply to tabletops. There are only 2 situations where I use biscuits now – If I am gluing end grain to something or, in some situations the biscuits can help with alignment. Gluing up miter joints is one place where the alignment benefits of a biscuit can help. OTOH – there are other ways to “skin this cat”. If you are starting out and just beginning to acquire tools I think there are better ways to spend your money. Just my opinion. -- Rich, Cedar Rapids, IA - I'm a woodworker. I don't create beauty, I reveal it. |
#2 posted 05-16-2010 02:34 AM |
I love biscuits, not for strengthening the joint but for the alignment aspect. We built a new home 5 yrs ago and I used them on all the trim for the windows and doors, worked like a charm. |
#3 posted 05-16-2010 02:36 AM |
Like Rich, I used to use mine a lot but now I haven’t touched it in months. I glue up solid wood panels edge grain to edge grain without any other reinforcement. I agree that two well jointed edges glued to each other appear to be just as strong as the wood itself. I also now find it’s easier for me to align panel boards to each other without the biscuit. About the only place I use mine now is to glue the edge of plywood to solid wood. if I had it to do all over again, I would have spent the $150 elsewhere. Greg -- Greg, Severn MD |
#4 posted 05-16-2010 02:39 AM |
I had a DW682k for several years. It’s a well tool, but I found myself using biscuits less and less over time. I tend to use pocket holes instead. On the rare occasions I do use biscuits, I cut a slot with the router. -- Happiness is like wetting your pants...everyone can see it, but only you can feel the warmth.... |
#5 posted 05-16-2010 02:53 AM |
I have the Ryobi, and it works great for alignment of panels when doing glue ups, but honestly, I use my pocket hole jig more… -- Please like and subscribe to my YouTube Channel https://www.youtube.com/c/daves-workshop |
#6 posted 05-16-2010 03:02 AM |
I’ve got the porter cable and have no complaints. I use it a ton, because I do glue hardwood to plywood regularly. but, hardwood to hardwood, not much. I do different joinery or just glue by itself. I didn’t believe that the glue was stronger than the wood until I took a hammer to some off cuts. The wood gave way but not the glue every time. -- measure once, keep cuttin' til it fits |
#7 posted 05-16-2010 05:03 AM |
I do very little with plywood but I would agree that if I was gluing plywood along the edges I would use biscuits. OTOH – why would anyone glue plywood along the edges? btw – If you have followed the evolution of the New Yankee Workshop you may have noticed that, at one time, Norm was very pro-biscuit. However, in the last few years he has really downplayed the use of biscuits. -- Rich, Cedar Rapids, IA - I'm a woodworker. I don't create beauty, I reveal it. |
#8 posted 05-16-2010 07:14 AM |
You know, I didn’t LOVE my 557. It was a nice tool, but I didn’t really like the weird grip or the overly complicated fence system (which eventually broke). I like my Makita a little better, but I don’t use it all that much. YMMV. |
#9 posted 05-16-2010 08:45 AM |
I have a Virutex. Works about the same as any. Use it for alignment of parts more than strength but it is handy. I wouldn’t spend a bunch on one if I had to do it over. I think I have seen them (Pc or ryobi, makita etc) on Craigslist for $40, $60 . Virutex, at the time, was one of the only ones around, Lamello was another. I think mine cost almost $200.00. -- Michael Murphy, Woodland, CA. |
#10 posted 05-16-2010 10:21 AM |
dmoney, don’t waste your money on a ryobi. I’ve got one, and then I got the porter cable. As a matter of fact, if you want the ryobi, i’ll give you mine . -- Wish I were Norm's Nephew |
#11 posted 05-16-2010 01:58 PM |
sounds like most of you could live without a biscuit joiner. Based on your opinions, I won’t be getting one. thanks! -- Derek, Iowa |
#12 posted 05-16-2010 02:00 PM |
also the reason i was thinking about getting one was because I see Norm use one on NYW fairly regularly. -- Derek, Iowa |
#13 posted 05-16-2010 02:41 PM |
I have a DeWalt DW682k … wouldn’t part with it. I don’t use it on every project, but anytime I am gluing panels, I use biscuits for alignment. As Rich pointed out, biscuits don’t add strength (in most cases the glue is actually stronger than the wood), but the biscuits keep joints from slipping while you are clamping your panel. -- Gerry -- "I don't plan to ever really grow up ... I'm just going to learn how to act in public!" |
#14 posted 05-16-2010 02:42 PM |
I just got a 557 a few weeks ago for my birthday. I am not super experienced with it, but I do a lot of smaller projects including picture frames. the FF biscuit capabilities makes this guy pretty nice. I was able to do a pretty solid set of frames that were well aligned because of this little guy. It all comes down to what you want to do and how you want to do it. -- Every neighborhood has an eccentric neighbor. I wondered for years "who was ours?" Then I realized it was me. |
#15 posted 05-16-2010 03:04 PM |
I thought I wanted a biscuit joiner for edges and miters a while back but instead decided to try splines. Mostly because I’m cheap and had other uses for the money but also because I had plenty of scrap wood around and the splines were easy enough to make and did the job well. Just my .02. -- Kenny... The man who needs a tool he doesn't have is already paying for it. |
Forum | Topics |
Woodworking Skill Share
12027 |
Woodturning
2105 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4902 |
6691 |
28047 |
CNC Woodworking
211 |
Hand Tools
5404 |
Jigs & Fixtures
1417 |
Wood & Lumber
6232 |
1387 |
Focus on the Workspace
2153 |
1186 |
Woodworking Trade & Swap
4754 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8844 |
