Which Iron to choose for a No. 3 Stanley
« back to Hand Tools forum
Forum topic by GregTP posted 07-25-2016 12:54 AM 762 views 0 times favorited 13 replies Add to Favorites Watch
View GregTP's profile
GregTP
62 posts in 850 days
07-25-2016 12:54 AM
Topic tags/keywords: no 3 plane iron restoration question
I picked up an old Stanley No. 3 at the flea market this week for $15, not old-old but probably from the 60’s. Its complete and in pretty decent shape though it needs a good clean up. Has anyone had luck with choosing a replacement iron? I’m hoping to get something thicker than the originals to cut down on chatter.
I’ve heard Rob Cosman promote IBC irons, but at $90 it is a bit hard to justify in a $15 plane.
-- From exercise machine warning label: "Step ladders can cause injury and even death; the ROM machine is more dangerous than a stepladder"
13 replies so far
View JayT's profile
JayT
5523 posts in 2118 days
#1 posted 07-25-2016 01:07 AM
Thicker irons shouldn’t be necessary on a well tuned plane. The only time I replace an iron is if it is extremely pitted. If you are getting chatter, it’s usually a result of either not being sharp enough, trying to take too thick of a shaving or poor frog fit. Proper fettling and sharpening will take care of the problem.
View Kirk650's profile
Kirk650
524 posts in 655 days
#2 posted 07-25-2016 02:19 AM
I replaced all my plane blades (except the Veritas and LN planes) with Hock blades. Don’t know if you can still get them. The thicker iron makes a big difference. I think Veritas or LN can supply you, and the new PMV11 metal, though more expensive, would be a good choice. But if Hock is still in business, I’m very pleased with them
View tshiker's profile
tshiker
23 posts in 1216 days
#3 posted 07-25-2016 02:29 AM
I agree with Jay, mostly. You’re not getting chatter because the blade is thin, you’re getting it because the plane is not set-up properly. There is lots and lots of info online about how to set-up and fine tune an old handplane. If I was you I would spend some time to get the plane set-up and tuned correctly and then decide if a thicker aftermarket blade is needed. I think there are some legitimate reasons to replace a vintage plane iron (I’m going to order one for my Stanley 4 1/2 this week) but chatter ain’t one of them.
View ColonelTravis's profile
ColonelTravis
1744 posts in 1801 days
#4 posted 07-25-2016 02:54 AM
I’ve never noticed a difference in performance between new and vintage blades. In fact the new, thicker ones can, without modification to the plane, sometimes limit the use of an old Stanley because Stanleys weren’t made for thick blades. The Hock in my #8 can close the mouth opening completely if I lower the blade too much. Even after frog adjustment. Have not filed back the mouth in that one yet but I’ve had to file back the mouths in a few of my planes because of this. Also, securing a Hock blade on an old chipbreaker is difficult on a couple of my planes because they screw is a tad short. I have to push the blade and chipbreaker really hard together to get the screw in the hole. Minor annoyance but it’s annoying.
I think you must have seen a chipbreaker added to that IBC blade. The blade itself doesn’t cost $90. You don’t need to replace the chipbreaker if you get a new blade. However, I do like the newer chipbreakers out there because there is absolutely no way anything can get stuck under them. I don’t see them performing better than an old one, but I think they were engineered better.
Primary reason I own Hock blades – they’re for standard angle planing. It’s only a visual thing, I’m not getting better results. For higher blade angles, I use vintage. All I do is look at the blade and know what job it’s for, vs. screwing up the wood with tear out after a few passes and me saying – oh yeah, moron, wrong blade for this job.
View MikeUT's profile
MikeUT
170 posts in 1266 days
#5 posted 07-25-2016 04:39 AM
Jay is right. You can get an old blade sharp enough to circumcise a gnat (Sorry for the John Candy reference). The only real advantage to new blades is that they can be harder so you can go longer without shaving them. IMO, it wouldn’t be worth it to buy a new blade for a 3. The only reason to use a #3 is if you don’t have a #4. Save your money for a #4 or a #4 1/2.
View Mark Kornell's profile
Mark Kornell
1169 posts in 2437 days
#6 posted 07-25-2016 05:18 AM
Greg, I bought a Lee Valley PM-V11 iron for my #3. It is a type 19 (1948-1961), so one of the later ones.
The original iron was pitted too badly to rehab, otherwise I wouldn’t have replaced it.
I decided to buy the matching LV cap iron but ran into a snag with it. When trying to set the cap iron at a very close distance to the edge of the blade, the cap iron screw hits the frog casting. I have to grind a bit off the head of the cap iron screw to allow it to fit where I want it. But the original cap iron works well with the LV iron.
-- Mark Kornell, Kornell Wood Design
View rwe2156's profile
rwe2156
2803 posts in 1387 days
#7 posted 07-25-2016 02:56 PM
Depends on what you’re doing and whether maximum performance is a must.
After trying one, I think an upgrade iron performs better than the strandard thin blades.
Cheapest I know of is Veritas around $65.
You have to weigh the cost:benefit based on my first sentence.
Never had an issue with thicker blades blocking mouth. You do have to back frog off a little.
View DoitRightorNotatAll's profile
DoitRightorNotatAll
7 posts in 1368 days
#8 posted 07-25-2016 03:13 PM
Greg, A woodriver blade from woodcraft will fit.
View Julian's profile
Julian
1268 posts in 2597 days
#9 posted 07-25-2016 04:01 PM
I have an old Stanley #3 that I purchased on Ebay awhile ago. I kept the original blade; just cleaned and tuned the plane. It works fine and no chatter. A thicker blade may not solve the chatter issue.
-- Julian
View bondogaposis's profile
bondogaposis
4609 posts in 2258 days
#10 posted 07-25-2016 04:03 PM
I think replacement irons are worth the money especially on a smoothing plane. I’ve used Hock irons w/ excellent results. When working w/ used planes and flattening the soles will make the throat opening a little wider. A thicker blade will compensate for this and having more mass in the blade is not a bad thing.
-- Bondo Gaposis
View bandit571's profile
bandit571
19215 posts in 2590 days
#11 posted 07-25-2016 06:34 PM
nhplaneparts.com, an Ebay store…...has the iron and chipbreaker for $11.95, plus $3.40 S&H and it is a Buy it Now sort of thing. iron has the “V” logo, looks to be a decent length. it is a 1-3/4” wide cutter assembly made for the Stanley #3 and the Stanley #5-1/4…same size used in both…
bandit571
#12 posted 07-26-2016 02:24 AM
Happen to have a Millers Falls No. 8, and a millers Falls made for sear #3…..both have their original irons, and chipbreakers in them…they are both very nice smoothers, and have had zero chatter, or other problems.
There is also a Millers Falls No. 11 in the till. Uses the same size iron as a #3 smoother, but is in a #5-1/4 size. 11” long, a junior jack plane size. Also has it’s OEM iron and chipbreaker. No chatter, and will make see-through shavings with the best of them. Does not take all that long to tune a plane up, time wise…...just a little elbow grease.
GregTP
#13 posted 07-26-2016 02:37 AM
Thanks guys, sounds like good advice all around. I have a Stanley #4 and a Freud #4 both in good shape that work well with their original blades. The No. 3 looks like the iron is in good shape but I haven’t had the time to even take it apart yet so its hard to say what I will find.
I have rehab’ed all the planes I use now (and have about 20 others that I haven’t, and some that I probably won’t, rehab later) so I’ve gotten comfortable, if not good, at getting them back in fighting shape. I invested in some good water stones that get them plenty sharp so I’m not so worried about the sharpness, more the heft that a thicker iron might offer.
