What finish to use for Baltic Birch?
Forum topic by Michael J posted 05-14-2010 09:11 PM 12249 views 1 time favorited 14 replies Add to Favorites Watch
View Michael J's profile
Michael J
103 posts in 3207 days
05-14-2010 09:11 PM
Topic tags/keywords: baltic birch finish boiled linseed oil danish oil
Hi All,
I was just looking for advice/suggestions on what to finish baltic birch shop cabinets and tool stands in. I’m in the process of completing my Ultimate Tool Stand which is done in baltic birch and I wanted to put a nice finish on it. I’ve read many different concoctions of linseed oil/turpentine/Mineral spirits and danish wood oil, etc. I don’t really know which way to go as there are so many options and I’m not sure what the benefits of each finish are.
If anyone has any insight, advice and/or examples of baltic birch/finish combinations, I’d love to hear and see them.
Thanks,
Mike
-- Mike Minneapolis, MN
14 replies so far
View SCOTSMAN's profile
SCOTSMAN
5849 posts in 3585 days
#1 posted 05-14-2010 10:03 PM
Polyurethane varnish, not necessarily high glosss . That will last for years, whereas oils will not last anytime before needing a redo.MY£ 3cents.Alistair
View MyFathersSon's profile
MyFathersSon
180 posts in 3313 days
#2 posted 05-14-2010 10:10 PM
DITTO Scotsman’s comment.
Thats what I did for my router table.
I’m sure there are fancier ways that all have their benefits—but I just put about 5 good coats of poly.
Why so many? If it gets scratched or otherwise messed up == a quick buff with steel wool or fine wetsanding paper—and it’s good as new.
-- Those who insist it can't be done - should politely refrain from interrupting those who are doing it.
View MrsN's profile
MrsN
986 posts in 3526 days
#3 posted 05-14-2010 10:19 PM
i’ll out another vote in for polyurethane. It will out last most other finishes and on shop projects that is a real plus. I would hate to have to unload my work bench to refinish it every few months.
View Gene Howe's profile
Gene Howe
10479 posts in 3428 days
#4 posted 05-14-2010 11:04 PM
I use a varnish product from McCloskys called Man-O-War. It’s very tough!
View ND2ELK's profile
ND2ELK
13495 posts in 3774 days
#5 posted 05-14-2010 11:30 PM
I use baltic birch for all my drawers and finish them with two coats polyurethane and then wax them. I like them to be natural in color. Thanks for asking.
-- Mc Bridge Cabinets, Iowa
Michael J
#6 posted 05-15-2010 05:56 AM
Thanks for all the advice! How are you guys applying this finish? Would it be ok to dilute and make it a wiping varnish?
27250 posts in 3822 days
#7 posted 05-15-2010 01:03 PM
Mike, you can certainly apply the poly as a wiping varnish. I generally suggest making your own as opposed to buying a commercial product. I buy it in gallon containers and cut it roughly 50:50 with mineral spirits. While you can get commercial products basically you will be paying a premium price for mineral spirits. Bear in mind also that, as a wiping varnish, you will need to apply more coats to get a protective build since it is a diluted product. But the application and drying speed of a wiping varnish more than offset the time needed to apply additional coats.
View HTown's profile
HTown
104 posts in 1186 days
#8 posted 04-16-2015 02:07 AM
Not that you asked, but I was playing with stained finishes on BB. I used clear poly followed by a tinted poly. No blotchiness. It was just a test, but I would have gone back to clear poly once I had the color I was after.
18200 posts in 1856 days
#9 posted 04-16-2015 02:21 AM
I’ve used BB one time and I was not as happy with the stain as I would have liked. If I could go back, knowing what I know now, I would use prestain conditioner first. Then stain, then poly.
HTown
#10 posted 04-18-2015 02:43 PM
Firefighter. I used the minwax preconditioner and it didn’t work for me. That led me to poly over poly. I also used shellac and then minwax oil stain over it. I gave the sample away; otherwise I’d give it the adhesion test with masking tape. The shellac method gave the best results. I mainly use lacquer, but didn’t have time to try it on the sample.
View Dark_Lightning's profile
Dark_Lightning
3161 posts in 3109 days
#11 posted 04-18-2015 03:08 PM
I’m making a tool chest using BB, and was considering oil based paint, since I want some designs on it.
Question- If polyurethane is so much better, maybe I can get it tinted? I’m looking at black…
-- Random Orbital Nailer
#12 posted 04-18-2015 04:58 PM
Hmm, it worked great on pine. Maybe BB is different. On the big pine bed project, I used the prestain, then stain, then dewaxed shellac and then water based polycrylic. I was really happy with that finish.
Dark lightning, you can get tinted water based lacquer from target coatings. I used white and it worked well.
Dark_Lightning
#13 posted 04-19-2015 12:54 AM
- firefighterontheside
Thanks!
View boatz's profile
boatz
92 posts in 1651 days
#14 posted 04-20-2015 01:04 AM
I used Arm-R-Seal on my version of the UTS. The torsion box base is regular birch ply, the rest is baltic birch:
-- You can't always get what you want. But if you try sometimes you just might find, you'll get what you need
