What is it?
« back to Woodturning forum
Forum topic by mike02130 posted 07-24-2016 01:47 PM 1006 views 0 times favorited 5 replies Add to Favorites Watch
View mike02130's profile
mike02130
170 posts in 875 days
07-24-2016 01:47 PM
Topic tags/keywords: lathe
I just picked up an old Delta “Double Duty” lathe built in the 1930s. With it came this contraption. I know nothing about it and am hoping someone here can help me. There is an old tag attached to it that hat “Atlas” written on it.
-- Google first, search forums second, ask questions later.
5 replies so far
View MrUnix's profile
MrUnix
7050 posts in 2401 days
#1 posted 07-24-2016 02:08 PM
That is the tailstock from an Atlas turret lathe.
Here is a video of one in use: Spacing, drilling, and tapping with the tailstock turret
View bigblockyeti's profile
bigblockyeti
5286 posts in 1923 days
#2 posted 07-24-2016 02:10 PM
It looks like a turret lathe where in each of the different tool holders would be the next operation. It also appears that when you rotate to the next tool, the turret is geared to a corresponding depth stop just for that tool. For example, it could be for turning a specified diameter, drilling, counterboring, then countersinking.
MrUnix
#3 posted 07-24-2016 03:06 PM
Do you have a serial number for it? Would help date it and determine what it might have been at one time… right now, it appears to be parted from several different machines. It’s hard to tell from those photos, but the headstock looks like it might have been from a 46-111 or 46-230 lathe. The tailstock obvously is from an Atlas lathe, and the bed doesn’t doesn’t look like anything that Delta ever produced.
mike02130
#4 posted 07-24-2016 07:13 PM
Thanks guys. From my research I think it’s a Delta 930. The beds were made from steel until 1940 or so. Afterwards they were made from cast iron. I searched all over for a serial number but found nothing.
I picked it up from a guy who said his father was a machinist and pattern maker. He already sold a metal lathe, which the Atlas contraption may have been used for.
Here is a link to the lathe, http://www.old-woodworking-tools.net/delta-930-wood-lathe.html
MrUnix
#5 posted 07-24-2016 10:30 PM
Thanks guys. From my research I think it s a Delta 930. The beds were made from steel until 1940 or so. Afterwards they were made from cast iron. I searched all over for a serial number but found nothing.
- mike02130
Think you are correct… here is the catalog listing for the 930 from the 1939 Delta catalog:
