Shellac and humidity
Forum topic by bbasiaga posted 07-23-2016 06:01 PM 750 views 0 times favorited 2 replies Add to Favorites Watch
View bbasiaga's profile
bbasiaga
1240 posts in 2193 days
07-23-2016 06:01 PM
It’s a warm (90F) and 80% humidity day. Was planning to spray shellac on a project outdoors. I know this is a no no with laquer…should I hold off with shellac the?
2 replies so far
5171 posts in 2691 days
#1 posted 07-23-2016 09:06 PM
The blush in lacquer in cause by the solvent evaporating (the finish dries) faster than the moisture can escape. Shellac can do the same thing. I’d hold off if at all possible. There are some way to slow the drying process down with shellac, none of which I’ve ever tried. Maybe someone else has the skinny on them.
bbasiaga
#2 posted 07-23-2016 09:58 PM
Thanks Fred. I was worried about just that. I went outside to figure out what I’d set up, and decided I didn’t want to deal with the heat anyway. It’s too gross out there for me, let alone the finish!
I set up a makeshift spray booth and vent system in the basement. Humidity controlled, if a bit dusty.
Brian
