help!! ironwood table
Forum topic by drako18 posted 07-23-2016 02:12 PM 578 views 0 times favorited 10 replies Add to Favorites Watch
View drako18's profile
drako18
6 posts in 726 days
07-23-2016 02:12 PM
Hello I am new to this site an I hope I can get help I need for this project.
This is going to be ironwood table with top being made of 4×4 an legs 8×8s. Issue is they don’t want any screws so I can only think of mortise an tenon but this is going out side 24/7 about 100 feet from ocean in hawaii so even using special glue will eventually braked down.
I worry even if I did do it the legs would be way to unstable.
Can anyone give some suggestions an even links or photos thanks.
10 replies so far
View KYSean's profile
KYSean
119 posts in 3650 days
#1 posted 07-23-2016 02:45 PM
Tennons and peg with dowels.
-- http://editedwrite.com
View AandCstyle's profile
AandCstyle
3094 posts in 2311 days
#2 posted 07-23-2016 10:35 PM
Drako, I agree with Sean that a drawbored tenon is the way to go-no glue needed. Also, be certain to include the cost of a crane to move the table. :D Good luck and please post pics.
-- Art
drako18
6 posts in 726 days
#3 posted 07-23-2016 11:17 PM
Ok I will look that up as link he posted was not good. Yes I know it will be built on site an stay where it’s put together. The wood alone will cost them 3 grand.
Best part for me is that all wood will be cut to length as per my specifications so saves me alot of blades.
With using a drawbored tenon style (as you can tell I have not done it before) how would you secure the table top to the legs. Any photos will be very helpful, thanks
View bondogaposis's profile
bondogaposis
4830 posts in 2405 days
#4 posted 07-24-2016 01:50 AM
Draw bore the tenons and you won’t need glue. The top could be attached with buttons. or z clips. For a salty environment I would prefer buttons using stainless screws. Oh yeah, welcome to LJ.
-- Bondo Gaposis
drako18
6 posts in 726 days
#5 posted 07-24-2016 02:10 AM
Thanks bond, I use 316ss or silicon dronze for everything out here.
Good info I will check all this out an see what new tools I need for any of this.
drako18
6 posts in 726 days
#6 posted 07-24-2016 02:13 AM
For any of the knowledgeable wood workers our there what the expansion an contraction of iron wood… I ask as the owner wants the top to have no gaps (all 4×4s which are 13 of them to be flushed with each one)... I felt with the wet conditions here that’s not good idea an doing them with 1/4 gaps would be best any suggestions???
View Woodknack's profile (online now)
Woodknack
12055 posts in 2434 days
#7 posted 07-24-2016 05:43 AM
“Ironwood” is used for quite a number of woods.
http://www2.ctahr.hawaii.edu/forestry/trees/
drako18
6 posts in 726 days
#8 posted 07-24-2016 06:34 AM
Sorry I know the type of wood it’s ipe
bondogaposis
#9 posted 07-24-2016 08:58 PM
For any of the knowledgeable wood workers our there what the expansion an contraction of iron wood… I ask as the owner wants the top to have no gaps (all 4×4s which are 13 of them to be flushed with each one)... I felt with the wet conditions here that s not good idea an doing them with 1/4 gaps would be best any suggestions???
- drako18
You don’t need to know the expansion rate, and it would largely depend on how the boards were sawn. No gaps are fine just allow for movement when attaching the top to the base. Here is a link to some tips.
-- Bondo Gaposis
drako18
6 posts in 726 days
#10 posted 07-24-2016 09:08 PM
Thanks again bondo, I only done indoor tables so this is first an I want it to be done right
