Table top tolerance.
Forum topic by Plain posted 07-22-2016 02:19 PM 979 views 0 times favorited 13 replies Add to Favorites Watch
View Plain's profile
Plain
157 posts in 603 days
07-22-2016 02:19 PM
What tolerance would you expect from a good cabinet table saw when it comes to the table top flatness ? Mine is convex 0.025” out of the box, enough to for the wood to hit the extension/table step when sliding left-right and t spin due to having only one point of contact with the table. But I admit I could have been spoiled by my previous saws that had tables flat enough to not cause any worries. Please do not bring Ford better than GMC here.
13 replies so far
View bonesbr549's profile
bonesbr549
1493 posts in 2971 days
#1 posted 07-22-2016 02:35 PM
Most saws and it varries by brand but you will see 5 – 10 thou per foot. It also mattters where its at. If it’s away from where the blade hits the wood probably not a deal killer. Not quite getting from you description whet it might be a problem. Is it a wing thats got a high spot?
Have you called the manufacturere? I recently bought a jobsite saw that was out and sent it back.
View HokieKen's profile
HokieKen
4611 posts in 1043 days
#2 posted 07-22-2016 04:32 PM
If it’s crowned enough to allow wood to spin freely, IMHO, that’s an un-usable saw. I’d get in touch with the manufacturer or the retailer and get it replaced if it’s new. My TS is 25 years old and has less than .015 out-of-flatness. A new one should be no more than .005-.010 depending on the price point.
And Ford IS better than GM ;P
-- Kenny, SW VA, Go Hokies!!!
View diverlloyd's profile
diverlloyd
2509 posts in 1761 days
#3 posted 07-22-2016 08:03 PM
Very nice comment Kenny, I knew someone would keep it going.
View Aj2's profile
Aj2
1272 posts in 1702 days
#4 posted 07-22-2016 10:38 PM
I’m curious what others say about their saw tops.Mine has a .008 gap across the middle of the throat plate.Front to back is very flat .001 to .002.
My saw is over 50 years old.
I get very good rips cuts not glue ready but I make due.
-- Aj
View unbob's profile
unbob
801 posts in 1808 days
#5 posted 07-23-2016 05:53 PM
I looked at a tag on a new Powermatic 66 some years ago, it read, the top not to exceed .010” for flatness. That is the only reference I have ever seen regarding any specification on a table saw. My own Delta 12-14” is better then .004” for its 38” X 48” surface with wings.
View Redoak49's profile
Redoak49
3076 posts in 1893 days
#6 posted 07-23-2016 06:07 PM
You are just beating this to death….didn’t you get enough on your Sawstop threads
View knotscott's profile
knotscott
7872 posts in 3280 days
#7 posted 07-23-2016 06:55 PM
It really depends on where the deviations are on the table and whether are not they affect the cut. Cut quality is the real test IMO. Flat is fine, but if the saw cuts well, all is good.
Lots of people drive themselves crazy because their saw table isn’t perfectly flat, but don’t even bother to do some test cuts first. If it looks flat and cuts right, don’t even bother to try to measure for flatness.
View jbay's profile (online now)
jbay
2041 posts in 803 days
#8 posted 07-23-2016 07:11 PM
I never have checked my Unisaw. (20 or so years)
I’ve never had any problems, but then, maybe that’s why I can’t cut straight… :>/
However my wings ARE flush!
-- If anyone would like to see my Portfolio, PM me and I would be glad to send you the link.
View Aj2's profile
Aj2
#9 posted 07-23-2016 07:37 PM
- unbob
Hi Bob do you or are able to get glue ready cuts from your saw.
Some say they do but i have never owned or ran a saw that was acceptible to me.
I think I saw one once it belonged to Sam Maloof.
Maybe I’m too picky but I almost always clean tablesaw edges.Sometmes my foreplane sometimes my jointer.
I think maybe my saws top has sagged over time since the trunnions and motor all hang from the underside of the top.
I have a Davis and wells with 3/4 inch arbor 12 inch 2hp.Its a nice compact saw that runs very smooth.It also has a very unique rack and scroll gear to raise and lover the blade.
-- Aj
View joey502's profile
joey502
520 posts in 1422 days
#10 posted 07-23-2016 08:53 PM
like others have said, I think where the dips and bumps are will effect how much of an issue it is. .025” is a large tolerance in my opinion though.
What measuring tools are you using to get these results?
Plain
#11 posted 07-23-2016 09:00 PM
- joey502
Just got this replaced. Seems to be damage in shipment. The new one is about 0.006”.
I just looked at the specifications. The accepted tolerance is 0.10” measured diagonally for the table only. For table with wings 0.025” considered acceptable.
Plain
#12 posted 07-23-2016 09:09 PM
Maybe I m too picky but I almost always clean tablesaw edges.Sometmes my foreplane sometimes my jointer.
- Aj2
I do not think a curved table is to blame. Most probably a dull or misaligned blade. I noticed when a 10” thin kerf blade is misaligned 0.010” or more the teeth start catching up the wood on the back side and create marks. Besides that bring some safety concerns.
unbob
#13 posted 07-23-2016 11:22 PM
- Aj2
- Plain
I have to say, I get the best edges with a hand plane, so I usually just use a general purpose blades on my saws and finish by hand for the most invisible glue lines that I can get.
