3-Phase 220 vacuum system?
Forum topic by Marleywood posted 07-22-2016 12:57 PM 945 views 0 times favorited 26 replies Add to Favorites Watch
View Marleywood's profile
Marleywood
15 posts in 729 days
07-22-2016 12:57 PM
Hi Folks,
New to the forum. I recently bought some “pre-owned” woodworking equipment and included was a vacuum cart system which is 3-Phase 220. Can this be (easily) adapted to run on regular 220, or 110?
Thanks!
26 replies so far
View toolie's profile
toolie
2135 posts in 2683 days
#1 posted 07-22-2016 01:14 PM
Nope. You’ll need a VFD or a rotary phase converter(?).
View bigblockyeti's profile
bigblockyeti
5157 posts in 1775 days
#2 posted 07-22-2016 01:18 PM
Easily – yes, inexpensively – that’s subjective, figure ~$250.
View splintergroup's profile
splintergroup
2153 posts in 1277 days
#3 posted 07-22-2016 02:02 PM
I’d price out single phase replacement motors of the same HP, or if you see buying other 3-phase equipment in the future, a phase converter could be a worthwhile investment.
View TheFridge's profile
TheFridge
9711 posts in 1541 days
#4 posted 07-22-2016 02:19 PM
A 3 phase motor is damn near bullet proof when compared to single phase motors.
View Plain's profile
Plain
157 posts in 753 days
#5 posted 07-22-2016 02:24 PM
Any 3 phase induction motor can run from a 1 phase grid albeit with reduced by about 30% power. That sure wold work for items like a saw where the load is variable. It will not work with dust collectors where the load is constant.
I am unsure about vacuum pumps.
View bonesbr549's profile
bonesbr549
1564 posts in 3122 days
#6 posted 07-22-2016 02:30 PM
- TheFridge
Agreed! Made to run 24×7x365. Get a converter
Marleywood
#7 posted 07-23-2016 03:35 PM
Easily – yes, inexpensively – that s subjective, figure ~$250.
- bigblockyeti
$250 isn’t the end of the world if it works right, what do you envision doing with the $250? New single phase motor as mentioned or the “converter” mentioned? I’d rather have the option of going back to the 3-phase if my location ever allows for it.
MrUnix
6829 posts in 2253 days
#8 posted 07-23-2016 03:49 PM
You can get a VFD for under $200 to run it on standard 240vac, but that would be overkill for an application like a DC, and you would only be able to take advantage of a fraction of its capabilities. A static converter could also be used, but will reduce HP by about 1/3. Without three phase available at the shop, it would probably be more economical and easier to just swap out the motor with a single phase one. You can then use the three phase motor and VFD combo on something more appropriate that can take advantage of the added benefits, like on a drill press or lathe.
Marleywood
#9 posted 07-23-2016 04:25 PM
Brad, (or anyone)
If I decide to swap out the motor, would you suggest still getting a 240v motor? I’m guessing the 240v motor spins up faster? I can see why this would be desirable for a dust collection system. My table saw runs on “regular” 240 as well. Do I just try to match the specs of the motor? I know a lot about a lot of different stuff, but electricity isn’t one of them. I know enough to have health respect for for it.
MrUnix
#10 posted 07-23-2016 04:37 PM
If I decide to swap out the motor, would you suggest still getting a 240v motor? I m guessing the 240v motor spins up faster? I can see why this would be desirable for a dust collection system.
- Marleywood
240v will not spin up any faster (or make it last longer, or run cooler, or ….) – internally, the motor only sees 120v regardless of how it’s wired. But since that is a 3hp motor (and I’m guessing you would want to replace it with the same HP motor), you will not be able to run it on a standard 120v circuit, so you are looking at 240v as your only option.
PS: 14 amps for that 3hp motor is a LOT – rule of thumb for three phase is about 2.5 amps per HP.
Marleywood
#11 posted 07-23-2016 05:23 PM
Please forgive my ignorance on this subject. What is the significance of the 14 amps being “a lot”?
Also, where does one shop for a replacement motor? (I know I can use Google, but a trusted source would be appreciated).
toolie
#12 posted 07-24-2016 09:37 AM
- Marleywood
Doesn’t seem like a lot to me. My 3hp Unisaw drew 30amps @. 120v and 15 amps at 220v.
MrUnix
#13 posted 07-24-2016 11:47 AM
- toolie
Which was a single phase motor, not three phase :)
Apples and Oranges.
PS: No significance really, more of an observation. For a 3-phase motor, they typically run about 2.5-3.5 amps per HP or thereabouts depending on efficiency. The 3hp Baldor in mine is rated at 7.4A (@230vac 3-phase), and I have a 7.5hp Baldor that is rated at 18.8A (@230vac 3-phase).
Shawn Masterson
1325 posts in 2003 days
#14 posted 07-30-2016 12:08 AM
Here is my 3-phase story, And I love it. The only reason I would use a VFD is if I would benefit from the speed control aspect of it. ..http://lumberjocks.com/topics/49761
Marleywood
#15 posted 07-30-2016 12:12 AM
- Shawn Masterson
Well, thanks Shawn, but you have obviously seriously overestimated my understanding of this stuff, that post was WAY over my head.
