dovetails - clearing out the corner of thin tails
« back to Joinery forum
Forum topic by jimmy J posted 07-21-2016 06:12 PM 489 views 0 times favorited 7 replies Add to Favorites Watch
View jimmy J's profile
jimmy J
229 posts in 2314 days
07-21-2016 06:12 PM
Google failed me! lots of great how-to’s regarding dovetailing on the web, here included.
But I am trying to find some references / videos on the best way to clear out the waist when cutting very thin dovetail tails for a half blind drawer. i find that the bottom of the tails, in the corner, is very hard to clean up without the side of my chisel banging into the side of the tail.
7 replies so far
View Aj2's profile
1310 posts in 1733 days
#1 posted 07-21-2016 06:25 PM
Hi Jimmy,I use a left and right skew chisel.Lie Neilson makes fish tail chisels that look nice.
Someday I plan on getting a set of Japaneese fishtail chisels even though I don’t need them.
I admit t having a weakness to Japaneese chisels.
Good luck
-- Aj
View bondogaposis's profile (online now)
4640 posts in 2287 days
#2 posted 07-21-2016 06:27 PM
They make skew chisels and dovetail chisels for such things, but I am able to get by w/ my 1/8” bench chisel for tight corners in dovetails.
-- Bondo Gaposis
View diverlloyd's profile
2592 posts in 1793 days
#3 posted 07-21-2016 06:29 PM
Try a fishtail chisel or adjust the angle of the sides of the dovetails or chisels to match each other
View CharlesNeil's profile
2361 posts in 3806 days
#4 posted 07-21-2016 06:38 PM
I agree, I use a 1/8 chisel, the slimmest I have found are Ashley Isles
View rwe2156's profile
2844 posts in 1416 days
#5 posted 07-21-2016 07:25 PM
Careful on fishtails make sure its not a double bevel chisel.
Lie Nielsen sells a single bevel fishtail chisel perfect for this work.
Rob Cosman makes a dovetail chisel. You can make one, too.
Really any 1/8 chisel with a very low side bevel height like the brand Charles mentioned.
AL and LN have the lowest side bevel heights of any chisel going.
FWW has a very good chisel review PDF download with all the specs.
View shipwright's profile
7940 posts in 2733 days
#6 posted 07-21-2016 07:34 PM
I cheat and cut the waste away with my chevalet. Works like a charm.
-- Paul M ..............If God wanted us to have fiberglass boats he would have given us fibreglass trees.
View tubaforewilly's profile
11 posts in 618 days
#7 posted 08-05-2016 12:20 PM
If you have any chisels that you would consider junkers you could grind a skew into it, re-bevel somewhere in the 25-30 degree range and it would work after sharpening. I did that and all of a sudden two chisels that I thought were garbage became prized!
-- I am the Way, the Truth, and the Life. No man comes to the Father except through Me. John 14:6
