Attaching panel side of French cleat?
Forum topic by juanabee posted 05-12-2010 10:39 PM 1891 views 0 times favorited 1 reply Add to Favorites Watch
View juanabee's profile
juanabee
109 posts in 3037 days
05-12-2010 10:39 PM
Background: I am making a hybrid presentation board for an office, and plan to use a French cleat to mount it on a concrete block wall. The panel is actually two frames, mounted two deep and connected along a vertical edge with a piano hinge. Panels within these frames are .25” ply with magnetic (metal) white board glued to them. Both frames with panels are about three wide feet by 3.5 feet tall.
Here’s my problem. I cannot attach the cleat to the back of the panel as the panel is too thin. I can only attach the cleat to the stiles and possibly the top rail, which are about 2”” wide and 1.1 inch thick.
Here’s my plan: make the cleat from .75” oak (some scrap in my shop) about 6” wide. Put three pocket holes in each end of the cleat and screw them into the stiles with good qualtiy pocket screws. Six screws should hold the weight, but I am only guessing. I don’t yet see a reason to attach the cleat to the top rail.
The frames are made of healthy-looking red oak about two inches wide and 1.1 inches thick, joined with mitered half-laps. The wall side of cleat will be mounted in concrete block with lag screws or maybe some of those self-threading Tapcon concrete screws.
Can anybody see a serious flaw in my plan? I am mostly worried about the strength of the pocket screws holding the weight of the swing-out panel. Your comments and suggestions are appreciated.
-- "Life's nonsense pierces us with strange relation." Wallace Stevens
1 reply so far
View Gene Howe's profile
Gene Howe
10548 posts in 3457 days
#1 posted 05-13-2010 12:24 AM
One idea that comes to mind, and it may not be feasible, would be to mount a metal disc about 2” in diameter on the wall near the extent of the panel when opened. then mount a 1” dia. rare earth magnet on the back side of the fold out panel.
You could slightly recess the magnet. Not sure how to “pretty up” the disk on the wall.
If you research rare earth magnets, you’ll find varying thicknesses and diameters and different shapes. Many are of a strength to keep the panel from sagging. An added bonus would be the magnet holding the panel open.
Also, you can get piano hinges that will hold a considerable amount of shear weight.
Pocket screws in the ends into the stiles is the best option. I’d glue the ends also.
