Lord Forgive Me, I Rushed it
« back to Joinery forum
Forum topic by McFly posted 07-21-2016 11:00 AM 1082 views 0 times favorited 17 replies Add to Favorites Watch
View McFly's profile
McFly
273 posts in 1082 days
07-21-2016 11:00 AM
Topic tags/keywords: question maple walnut joining
Made a cuttingboard from some edge grain maple, added walnut stripes and glued up before realizing the table saw I was using trailed off at the end of each board, leaving some significant gaps in a few places as wide as 3/32”.
Any chance I could get away with using West Systems 205/207 epoxy to fill these bacteria grabbing eyesores?
17 replies so far
View dbray45's profile
dbray45
3320 posts in 2831 days
#1 posted 07-21-2016 12:17 PM
If already glued – don’t know how it will hold up. 3/32” is a pretty good gap.
I would make a new one and dry fit before assembly.
-- David in Damascus, MD
View Kazooman's profile
Kazooman
1066 posts in 2007 days
#2 posted 07-21-2016 12:20 PM
I would cut off the bad section and use the board for another purpose like a cheese board or serving tray.
View bbasiaga's profile
bbasiaga
1236 posts in 2050 days
#3 posted 07-21-2016 12:55 PM
You could slot all the glue lines to 3/32 and insert some shims of a contrasting wood. Then it would look like you did it on purpose.
Brian
View bondogaposis's profile
bondogaposis
4834 posts in 2406 days
#4 posted 07-21-2016 12:57 PM
Cut the ends off and make a shorter board.
-- Bondo Gaposis
View JayT's profile
JayT
5730 posts in 2266 days
#5 posted 07-21-2016 12:59 PM
Another option would be to make breadboard ends to cover the gaps.
View Underdog's profile
Underdog
1133 posts in 2090 days
#6 posted 07-21-2016 01:46 PM
Were you using a glue line rip blade? If not, I’m wondering why didn’t you joint the edges?
View jwmalone's profile
jwmalone
769 posts in 757 days
#7 posted 07-21-2016 01:51 PM
Brian has my favorite idea, that’s a true wood worker, use youre screw ups to your advantage they will never know.
-- "Boy you could get more work done it you quit flapping your pie hole" Grandpa
View JBrow's profile
JBrow
1365 posts in 975 days
#8 posted 07-21-2016 02:17 PM
McFly,
If a couple of ifs are true, then flipping the strips end for end should cancel out the 3/32”, assuming my geometry is correct. 1) If the trailed off by 3/32” means the strips are tapered from one end to the other. 2) If flipping the strips end for end does not spoil the look you are going for.
Flipping strips end for end would put a narrow end between two wider ends along one end of the cutting board and at the other end, the same strips would be a sandwich of a wide end between two narrow ends.
jwmalone
#9 posted 07-21-2016 02:35 PM
Next time I have a math question I’m asking Jbrow, That’s pretty slick thinking there
Kazooman
#10 posted 07-21-2016 06:39 PM
McFly,
- JBrow
That cannot be the case here. If the individual pieces were all tapered from end to end then gluing them side to side would not create any gaps, but would result in a piece that was not rectangular. The OP has to mean that the very end of some pieces have a taper to them. Hard to understand how it happened on the table saw unless he was doing something like using a push stick and failed to keep the work against the fence as it cleared the blade.
View bonesbr549's profile
bonesbr549
1564 posts in 3122 days
#11 posted 07-21-2016 07:15 PM
you could rip a 1/4 groove and put some inlay in. I’ve found in the long run when I have an opps some times it’s best to just chuck it start over. Do you want to have that mistake with your name on it?
Experience is a great painful teacher. Do it over.
View ChefHDAN's profile
ChefHDAN
1070 posts in 2904 days
#12 posted 07-21-2016 09:56 PM
+1 to Bones, it’s fire pit time, charge it off to the cost of education and rest assured the next one is going to be nice! Think I might edit my sig line to “Know when to burn it” LOL
McFly
#13 posted 07-21-2016 11:02 PM
Oh, jeez. I fat-fingered my keypad this morning. It’s a 1/32” gap, but they’re EVERYWHERE!!
I’ll go snap a few pics of the atrocity.
McFly
#14 posted 07-21-2016 11:05 PM
McFly
#15 posted 07-21-2016 11:28 PM
Many thanks for the lively discussion. To address some of the high points;
Slotting to 3/32” and inlaying another species is genius. Well done!
The hasty decision that started all this was my not planing all components to the same dimensions after cutting them. Would have produced a perfect board!
Laying wide ends to skinny ends is more genius. However, in my application, it was ramdom end pieces cut from longer stock. It’s a known isssue with this particular belt-fed ripsaw. In any event,Well Done!
I decided to embrace my hasty glue up and went with the fix of pressing tbiii glue & walnut wood flour into the gaps and immediately sanding it off w/100g. Should dry up nice & dark.
I’ll wrap things up this weekend by sanding up to 220g, wetting it down and starting up again from 120-400g before I oil & wet sand to 1000.
