Hawk Scroll Saw
« back to Scrollsawing forum
Forum topic by Rockytime posted 07-21-2016 12:01 AM 1120 views 0 times favorited 12 replies Add to Favorites Watch
View Rockytime's profile
Rockytime
16 posts in 918 days
07-21-2016 12:01 AM
A little late to post this but I’ll give it a try. Tomorrow I am to travel 65 miles to hopefully purchase a Hawk scroll saw. I has been on Craig’s list for about three weeks. The Hawk is 14”, SN321, MOD SS14. This tells me it is an old saw. Asking $300. Size dose is OK since I will perhaps never be a serious scroller. I looked up the manual on line but the illustrations are so poor I can’t see any detail. I am wondering how convenient the blade changing is and of course it is not VS. Perhaps a router speed control will work. I don’t want to drive 130 miles for a pig in a poke. Also wonder if $300 is a bit pricey. Any input will be appreciated.
12 replies so far
View Redoak49's profile
Redoak49
3739 posts in 2226 days
#1 posted 07-21-2016 12:46 AM
My opinion is that it is too much for such a small throat and not variable speed. It looks in good condition but being older parts may be a problem.
runswithscissors
2924 posts in 2262 days
#2 posted 07-21-2016 02:55 AM
I have the 220 VS which I found on CL. It is an excellent saw. Blade changing is similar to any pinless scroll saw setup. I’m not sure how the VS is achieved. If the motor is a universal one, then a router speed controller should work. A foot controller is nice too. 14” is a pretty small throat. $300 seems somewhat high, considering the limitations. Depends on condition, I guess, and whether it would meet your needs.
View Jim Finn's profile
Jim Finn
2688 posts in 3159 days
#3 posted 07-21-2016 11:41 AM
I have a single speed 15” Jet scroll saw, a 20” three speed Hegner and a 25” single speed Hegner. I use the Jet the most and the 25” saw is stuffed under my bench. All these saws have induction motors so no speed control is reasonably available for them. The Jet saw was made in 1988 and I bought it a few years ago for $15. I am cutting small items, like toys with this 15” saw. It all depends on what you will be using the scroll saw for. Hawk has a good reputation.
-- No PHD just a DD214 Website> craftingcouple.com
5236 posts in 2730 days
#4 posted 07-21-2016 11:51 AM
Seems awfully high to me for that saw. Last summer I bought a 220VS and paid $200. Since then I’ve seen 2 others in the $250-$300 range and they are a much nicer saw. As Jim said, you won’t get a speed control to work, although some parts should still be around….the company has changed hands a couple of times but they are still in business (quite helpful as well). I’m not sure what blade clamp arrangement they have on that saw, the ones on mine are not too bad. Good luck with your decision.
View bigblockyeti's profile
bigblockyeti
5315 posts in 1958 days
#5 posted 07-21-2016 12:05 PM
I saw one for sale for $100 that went pretty quick and it looked brand new, the price isn’t horrible, but there are better deals to be had.
Rockytime
#6 posted 07-21-2016 04:35 PM
WOW! Thanks for the quick responses. I’ve negotiated to $200, can live with that. What I really will use it for is cutting wheels (clock gears). I have repaired antique clocks for over 40 years and occasion have a wooden movement to repair, often with wheel teeth missing. I think this will work adequately. Again, thank you for the responses.
bigblockyeti
#7 posted 07-21-2016 05:07 PM
When making wooden gears, do you use plywood like baltic birch to reduce the chance of future tooth failure or use the same species that’s already in the clock?
Rockytime
#8 posted 07-23-2016 10:05 PM
When making wooden gears, do you use plywood like baltic birch to reduce the chance of future tooth failure or use the same species that s already in the clock?
- bigblockyeti
Sorry for the late response. I try to use the birch however, when not immediately available I will use whatever I have. I do not do very many wooden works. They seldom come into the shop. I would like to make a wooden clock when ever that may happen.
Rockytime
#9 posted 07-23-2016 10:20 PM
I did get the Hawk scroll saw that was advertised. I spent three miserable hours traveling 90 miles in terrible heat. The destination was only about 65 miles but due to interstate stoppage for an accident or what ever I took back roads and finally arrived. My air conditioner failed for some reason which made it a sweltering trip. After arriving I found the saw was not as I had presumed. Not only was the saw single speed but it had no motor. It never had. It had been powered with an outboard motor with a belt. I had down loaded the earliest version I could find on the Hawk which showed it as having a motor. This unit was pre-that version. I paid $100 and took it home. I has ended up being a sweet little machine. I had a motor and even had a red matching foot switch. So all is well. The baby Hawk is working just fine.
bigblockyeti
#10 posted 07-23-2016 11:18 PM
- Rockytime
Was the saw previously owned by tournament bass fishing Amish? Can’t imagine running a scroll saw with an outboard motor for any other reason.
Rockytime
#11 posted 07-24-2016 02:15 AM
- Rockytime
Was the saw previously owned by tournament bass fishing Amish? Can t imagine running a scroll saw with an outboard motor for any other reason.
- bigblockyeti
I don’t think so because he lived too far east to be Amish.
View MrUnix's profile
MrUnix
7106 posts in 2436 days
#12 posted 07-24-2016 02:23 AM
Slap a treadmill motor on there and you can turn it into a really nice variable speed machine.
