Need Help Fitting Dowel to Hole
« back to Joinery forum
Forum topic by pcox posted 07-19-2016 11:16 PM 714 views 0 times favorited 10 replies Add to Favorites Watch
View pcox's profile
pcox
26 posts in 733 days
07-19-2016 11:16 PM
I am trying to install folding legs to an extension table I am making and I have run into an issue. I drilled holes with a 3/8” bit and I purchased 3/8” dowels. And when I went to insert the dowel into the holes it was very tight. I am afraid of splitting the wood if I just hammer it in. When I measure the dowel with my calipers I get 3/8”. And then when I measure the holes I am getting 23/64. So I have a 1/64 difference. Doesn’t seem like much but it is making an impact. So should I sand the dowel just a bit? Or maybe add wax to the dowel? OR just hammer it in? The dowel will be through solid poplar and plywood. The dowel will also be a moving joint for folding and unfolding the legs. Here are some pictures. Thanks for your suggestions.
10 replies so far
View waho6o9's profile (online now)
waho6o9
8168 posts in 2545 days
#1 posted 07-19-2016 11:50 PM
Sand and wax
View TheFridge's profile
TheFridge
9249 posts in 1454 days
#2 posted 07-20-2016 12:06 AM
Draw some hair around it :)
View pcox's profile
pcox
#3 posted 07-20-2016 12:36 AM
- TheFridge
Funny!
View Woodknack's profile
Woodknack
11486 posts in 2348 days
#4 posted 07-20-2016 12:48 AM
Many dowels are metric. Metric drill bits will solve your problem.
View rwe2156's profile
rwe2156
2884 posts in 1449 days
#5 posted 07-20-2016 12:55 PM
Chuck the dowel material in your drill press and sand it while spinning.
Or ream out hole with 13/32 drill.
View jwmalone's profile
jwmalone
769 posts in 671 days
#6 posted 07-20-2016 01:14 PM
Metric I knew it, those bastards. rwe2156 is correct or that’s the way I do it , simple and fast also gives a nice uniform job stays round. Well I don’t use the press I have a jig rigged up put a screw in the dowel us edrill to turn it same principle.
-- "Boy you could get more work done it you quit flapping your pie hole" Grandpa
View Aj2's profile
Aj2
1361 posts in 1766 days
#7 posted 07-20-2016 04:58 PM
If you have a drill press.Drill a 3/8 hole in some thick metal.And pass the dowel thru the hole several times.Weting the dowel to raise up some fiber helps too.
Or sand if you like sanding. :)
Aj
-- Aj
View jmos's profile
jmos
823 posts in 2338 days
#8 posted 07-20-2016 05:12 PM
Did you use a regular general purpose twist bit, they often leave a hole that’s not quite round. A different type 3/8” bit (forstner, auger, or dedicated wood bit) may give you a true round hole that is 3/8”.
-- John
Woodknack
#9 posted 07-20-2016 05:25 PM
Metric bits are not that expensive.
View pcox's profile
pcox
#10 posted 07-20-2016 05:31 PM
Did you use a regular general purpose twist bit, they often leave a hole that s not quite round. A different type 3/8” bit (forstner, auger, or dedicated wood bit) may give you a true round hole that is 3/8”.
- jmos
Yes I did and I suspect this was the problem. I was planning to use a forstner bit but the thinner shaft would not work with my drilling guide block. I don’t have a drill press yet so used a hand drill with the guide block.
