Miller's Falls Plane
« back to Hand Tools forum
Forum topic by Chas7715 posted 07-19-2016 10:27 PM 1096 views 0 times favorited 17 replies Add to Favorites Watch
View Chas7715's profile (online now)
Chas7715
38 posts in 1127 days
07-19-2016 10:27 PM
While perusing Craigslist I saw an ad for “Planner” and thought I would check it out. Turns out the “planner” was a Miller’s Falls plane.
It needs a bit of TLC. The iron has some significant nicks, plenty of rust, and the front knob and the tote are both loose.
How much did I pay? $10.00!
So, what do I have here? Any info is appreciated.
-- Perfection is highly overrated!
17 replies so far
bandit571
22020 posts in 2923 days
#1 posted 07-19-2016 10:35 PM
Along the left side of the base, there should be an etch of sorts…..something like Millers Falls No.14?
Appears to be a type2 or 3 sometime around WWII?
Length of the base = Model Number. If it is 14” long, it is about the same as a Stanley #5 Jack plane. If it is a 11” long plane…then it is the same as the Stanley #5-1/4.
Width of the iron? 1-3/4” would be an #11, if it is 2” wide, then it is a #14. There was a era where Millers Falls did not have red paint on the lever cap…...sometimes, they were cleaned up too much, and the paint was removed.
View Combo Prof's profile
Combo Prof
3746 posts in 1518 days
#2 posted 07-19-2016 11:05 PM
What bandit said. Measure the length. Clean the side shown and see if you can read the model number. Get back to us. But I will bet its a Miller Falls 14 wich is the most common. It is probably worth $20 or maybe $30 once its is cleaned up. Maybe more. But don’t sell it is a nice plane to have. It will work a little better then a Stanley number 5.
-- Don K, (Holland, Michigan)
View Don W's profile
Don W
19050 posts in 2808 days
#3 posted 07-19-2016 11:23 PM
Check out oldtoolheaven.com
That’s a great plane, and $10 is a steal.
Chas7715
#4 posted 07-19-2016 11:45 PM
Thanks for the info. I cleaned some grunge from the left side and found the etch. It is indeed a No. 14. I forgot to include the measurement in my original post. Toe to heal it’s 14 inches.
I popped the lever cap off to look at the chip beaker and iron. The iron will need some serious work! It looks like someone used a round file on it. The bevel will have to be reground.
What’s the best method for rust removal? Is a brass wheel in my bench grinder safe or should I go with something like electrolysis?
Don W
#5 posted 07-20-2016 12:08 AM
I prefer the wire wheel
http://www.timetestedtools.net/2016/02/29/restoration-technique-comparisons/
bandit571
#6 posted 07-20-2016 12:18 AM
I prefer the wheels and cups in a drill press, you can get into all the nooks and crannies that way.
View Johnny7's profile
Johnny7
411 posts in 1331 days
#7 posted 07-20-2016 12:24 AM
- Chas7715
The bit about the round file makes me wonder if the OP is describing a hollow ground bevel.
Pictures of the iron would be useful.
Combo Prof
#8 posted 07-20-2016 01:02 AM
Show us a picture of the iron.
You won’t need electrolysis. Wire wheel, wet dry snd paper, and a metal polish like auto-sol.
View cbass's profile
cbass
15 posts in 953 days
#9 posted 07-20-2016 02:15 AM
Not sure if this is already common knowledge or not a preferred method, but I have had good luck cleaning rust by soaking in a white vinegar and salt solution. Once the rust is removed make sure to neutralize with baking soda. It’s not as quick as other methods, but it is effective and cheap. Basically works like this video demonstrates
https://www.youtube.com/watch?v=TlcL_vHODkc
bandit571
#10 posted 07-20-2016 03:20 AM
This is the one I have at the moment..
Use the drill press and a brass wire cup brush. Set the drill press table so that the base will barely pass under the brush. You can then slide the sides under the spinning cup..slowly until all rust is gone, and a shine remains.
Cut a 100 grit sanding belt, lay it out flat on a smooth, flat surface. Have the plane fully assembled, but the iron retracted up as far as it will go, you want to “sand” the sole without the edge of the cutter getting involved. Then just “plane” away until all the sole looks the same. You can even made a bunch of lines across the sole with a black sharpie, when the lines are gone, you are done.
Simple Green on a wash cloth, give the handles a good rub down. Dry them off, and add a coat of wax.
Sometimes, the iron will have a curve to it, called a camber. That is what being a jack plane is all about. How much or how little camber is up to you, Schwarz prefers an 8” radius on his, I don’t. Maybe a bit on the corners is all. Grind the bevel at 25 degrees, make sure the back is flat. Hone to about 2500 grit Wet-or-dry paper.
Make shavings.
View rance's profile
rance
4267 posts in 3401 days
#11 posted 07-20-2016 03:48 AM
Rust removal: Molasses & water. Less likely to damage it than any wire wheel or electrolysis IMO. But it can take a couple 2-3 weeks.
View Aidan1211's profile
Aidan1211
198 posts in 1066 days
#12 posted 07-20-2016 11:20 AM
Very nice, I’d definitely own that old girl! I can’t buy enough Millers Falls and have slowly replaced all the stanleys in my user stash with Millers Falls. If you tune that plane clean it up and hone the iron you will be hard pressed to buy a better Jack! Congrats on the find and price!
-- its better to plan on the task at hand than actually doing it........ You look smarter.
Chas7715
#13 posted 07-21-2016 01:43 AM
As requested here are some pictures of the iron.
The business end is pretty beat up.
Aidan1211
#14 posted 07-21-2016 02:08 AM
All it needs is some elbow grease and you’ll be on your way!!!
bandit571
#15 posted 07-21-2016 02:09 AM
Not so much beat up…as it was hollow ground awhile back, then a few sharpenings later, middle was honed a bit too much.
Just grind a new bevel, and sharpen from that. The iron shows no sign of any camber. Up to you IF you want to add a bit on the corners, or not.
The M-F No. 14 I have, has almost no camber to it. I use it more as a smooth plane.
