Best way to add this decorative trim to flag case
« back to Joinery forum
Forum topic by Mrowell posted 07-19-2016 01:22 AM 599 views 0 times favorited 9 replies Add to Favorites Watch
View Mrowell's profile
Mrowell
86 posts in 1016 days
07-19-2016 01:22 AM
Topic tags/keywords: wood trim finishing flag case molding cope miter question shaping
Hey guys I’m trying to make a flag case and struggling on how to add this name plate to the front? Any suggestion on the best way to do this? I’m using a different profile but same design
-- Matt R
9 replies so far
View jwmalone's profile
jwmalone
769 posts in 578 days
#1 posted 07-19-2016 01:39 AM
Are you attaching a name plate to the one in the picture or are making another one, I didn’t understand different profile same design?
-- "Boy you could get more work done it you quit flapping your pie hole" Grandpa
Mrowell
#2 posted 07-19-2016 02:17 AM
Jwmalone sorry I guess I could have been more clear. I’m trying to make the same case with the raised portion for a name plate (same design). I’m using a different profile router bit for the molding. I am thinking the trim was all added after the name plate spot was put on, originally I was thinking it was all routed edges.
-- Matt R
jwmalone
#3 posted 07-19-2016 03:16 AM
I think you’re right. looks like its placed on then trimmed out. How far have you gotten.
Mrowell
#4 posted 07-19-2016 03:27 PM
I have the main pieces of the frame cut and I had some trim cut but It wont work with the name plate spot (Name plate was an add on for my mother in law).
-- Matt R
Mrowell
#5 posted 08-02-2016 02:19 AM
Here is a look at the almost finished product. Thanks for the input
-- Matt R
View ChefHDAN's profile
ChefHDAN
1007 posts in 2726 days
#6 posted 08-02-2016 11:57 AM
Matt, that’s some mighty fine work, did you have to build a sled for those miters?
Mrowell
#7 posted 08-02-2016 12:09 PM
ChefHDAN I actually used my Incra miter gauge set to 67.5 degrees with an auxilliary fence. Took some test cuts and patience but finally got it.
-- Matt R
ChefHDAN
#8 posted 08-05-2016 01:50 PM
Ah, incra, thanks, another reason to keep considering one…
View marshallmosby56's profile
marshallmosby56
18 posts in 556 days
#9 posted 08-13-2016 07:21 PM
Are you considering to engrave the Name plate on the raised portion? Like it is 3 lines max with 40 word per line? If yes then I think you have already make the raised portion 5” wide and 1.4” high.
