Sanded some cherry color change
Forum topic by McFly posted 07-19-2016 12:27 AM 759 views 0 times favorited 11 replies Add to Favorites Watch
View McFly's profile
McFly
273 posts in 1083 days
07-19-2016 12:27 AM
Topic tags/keywords: cherry
Had to down a cherry & maple panel a little further than I had intended and managed to scrub all the nice deep color right out of the cherry.
Short of staining it, what are my options to get that color back before I seal it with oil?
Do I just put it in the sun and hope for the best?
11 replies so far
View WDHLT15's profile
WDHLT15
1755 posts in 2531 days
#1 posted 07-19-2016 12:35 AM
If the cherry was natural, it will turn darker again when exposed to sunlight.
McFly
#2 posted 07-19-2016 01:48 AM
How long should it take to darken? Don’t want to hit it with a UV protectant until it gets back to the right color.
View bbasiaga's profile
bbasiaga
1236 posts in 2050 days
#3 posted 07-19-2016 02:51 AM
I made some cherry tables. They were white after milling and sanding. I put two coats of natural danish oil on them, then 3 coats of wipe on poly. You can see what they looked like after finishing in my projects. About a month later, they are 5 or 6 shades redder.
I believe it is oxygen that turns them red, not UV light. I only say that because I have piles of wood in my basement that get very little light and all are much darker than they were when I got them.
Brian
bbasiaga
#4 posted 07-19-2016 02:53 AM
In fact, if you look at the pictures of my end tables, they are now almost the same color as the TV stand. That TV stand is faux wood cherry. The tables are that dark, but more of a brown tint. Its been a year, but all the color change happened in the first few months, and under the finish.
Brian
View jwmalone's profile
jwmalone
769 posts in 758 days
#5 posted 07-19-2016 03:20 AM
Yep that color will come back, matter of fact don’t know of a way to stop it.
-- "Boy you could get more work done it you quit flapping your pie hole" Grandpa
McFly
#6 posted 07-19-2016 10:42 AM
So it’s more oxidization than a UV light reaction? This will work for me, as the project is a bathroom pullout cabinet and won’t see much, if any sunlight at all.
Guess I’ll just plow forward and hope for the best!
View jdh122's profile
jdh122
1024 posts in 2873 days
#7 posted 07-19-2016 11:50 AM
According to this article (http://www.popularwoodworking.com/techniques/adding_age_to_cherry) in FWW, it’s primarily a reaction to light, but it needs oxygen to happen:
“Why? The color change that takes place in cherry exposed to the sun is a continuous thing that’s going on, explains USDA Forest Products Laboratory expert Mark Knaebe.
“It’s a logarithmic rate of change, kind of like a nuclear half-life. It starts out fast and then slows down,” which gives the “untanned” area time to catch up, he said.
While all wood is in some measure chromophoric (meaning it changes when exposed to light), cherry has a more immediate and noticeable reaction to ultraviolet (UV) light than do most other domestic hardwoods. But, says Knaebe, moisture and oxygen are also necessary for the reaction to occur. If you were to build in a vacuum, the color of your wood wouldn’t change.”
-- Jeremy, in the Acadian forests
bbasiaga
#8 posted 07-19-2016 12:29 PM
Interesting article. Thanks. I guess the UV glass in my windows doesnt work! The tables are in the living room, across from a big window. They turned in a few months. The stuff in the basement gets no direct sun, and turned as well. So I think your bathroom cabinet will turn dark again even if it doesn’t get much light. Perhaps my wood pile and tables would have turned that much faster out doors.
Brian
View crank49's profile
crank49
4032 posts in 3026 days
#9 posted 07-19-2016 02:36 PM
More light = faster reaction. But it all changes with time.
I bought 500 BF of green cherry about 3 years ago.
Some of it sat outside for 3 or 4 days before I got it all stickered and stacked.
That outdoor exposure for just a few days made a huge difference.
After a few months they all evened up.
McFly
#10 posted 07-19-2016 04:30 PM
Think I’ll mill it to size and wing it. If the client gripes, I’ll just quote the article to her.
View pintodeluxe's profile
pintodeluxe
5726 posts in 2869 days
#11 posted 07-19-2016 05:00 PM
One of the many, many challenges working with cherry.
Ever try to dry a stack of it and keep it flat? Burns, warps, changes colors, and blotches.
Cripes, how did this ever become furniture wood.
It does look beautiful when finished.
I am too impatient to let cherry age naturally, so I use a pre-stain conditioner made from 3 parts denatured alcohol to 2 parts bullseye sealcoat. Then it can be stained with oil based stain without fear of blotching.
It continues to get darker with time. Each new clearcoated cherry project looks very different than the next one, so the stain really helps to even things out.
